Flail Mower Experiences
/ Flail Mower Experiences #1
ditchseeder
Omaha, NE metro area
2007 JD 7720, 2007 JD 5225, (2) 2008 JD 4120's, JD 4255, JD 5' Z-trak coming (model # unknown)
I currently have an 8' Land Pride 3596 rotary mower on a JD 5425 and have some other additional mowing jobs to do so looking at putting a John Deere 390 or 25A flail mower on a Deere 4120 tractor that is weighted down. I have never been around a flail type and looking for comments. Wondering if anyone has been around these and how they are for reliability, how they handle debris and how maintenace needs are on them? Thanks for your comments...
Ryan
/ Flail Mower Experiences #2
Flails don't throw debris and do a great job . They are however a very high maintanance item , belts , knives , bearings etc. all require a lot of attention . Any out of balance will see the machine destroy itself quickly . They are very safe , i slash beside houses and cars with little worry of damage .
/ Flail Mower Experiences #3
The 390, at 7.5' cutting width, may be a little large for the 4120. JD specs fot the 390 say 40 PTO hp min, 4120 is 35 or 35.5, depending on whether it is hydro or gear. The 25A, 360, and 370 should be fine as they have min 30 hp rating.
/ Flail Mower Experiences #4
The 390, at 7.5' cutting width, may be a little large for the 4120. .
I doubt it would be a problem but might require going a bit slow in really thick grass or brush. It doesn't take much HP at all to turn a flail mower so the rated HP required really depends more on what you are trying to cut and how fast you want to cut it.
/ Flail Mower Experiences #5
They are however a very high maintanance item .
Well, I cannot argue that when compared to box blades, rakes, boom poles and bush hogs;). Rather than call them very high maintenance though I think of the flail as requiring regular maintenance the same way the tractor itself does. Lube the tractor before each use and then hit the bearings on the flail. Check belt tension per manufacturer's recommendations pretty much the same way you'd do that on a tractor or other belt driven piece of equipment. Check the knives periodically and replace or sharpen when you no longer like the performance. I am using the same knives going into my third season and haven't even reversed them yet but that obviously depends on what type of cutting, what type of terrain and how many hours of use.
I do agree with IronHorse that flail mowers need more maintenance than a bush hog/slasher and perhaps more than a finish mower but I wouldn't characterize them as "very high maintenance" at least not in the sense that they might be considered delicate or fussy.
/ Flail Mower Experiences #6
The cut will depend a lot on the type of knives or cutters you have on it. If you expect a level cut be sure you don't use the "Y" cutters. No idea on the cutter you are talking about but many offer a good selection of knives to match the work you will be doing.
/ Flail Mower Experiences #7
I agree with the comments above. I have two and wouldn't be without them again. My bushhog almost never gets used. Both of mine have Y blades but on a high density spindle ( 99 pair on my 6') and on a level field it looks like a finish cut. I no longer have a finish mower as a result.
I grease mine just about everytime I use it ( 3 zerks, no big deal). The belts really don't need maintenance. If you are not going through heavy brush or hitting rocks, the blades last well, I end up replacing or turngin the whole lot every two years and a replacing a few several times a season (rocks).
I currently have a Caroni 5' and a Mott 6' (resurrected from a junk pile) and also had a Ford 917. The Ford 78" was a power hog and used every bit of my 42 PTO hp.
The only disadvantage to me about flails is the entry price, otherwise they are the cat's meow.
/ Flail Mower Experiences #8
I wonder why some manufatures have way different hp requirements for these unit. I had been thinking of a JD flail until I saw the specs. I only have 25hp @ the pto so I figured I was out of luck. Well the more I looked the more manufacture's I found that make 6'or 7' unit that work with 20-25 hp. So I wonder what's the big difference in build that varies the hp req's so much. I was looking at loftness cutters they seem to be quite hd. I think the 4120 would run any of the JD flails without issue. Of course I've never run one so I could say for sure.
Matt;)
/ Flail Mower Experiences #9
What are the thoughts on Flail vs Drum mowers? HayMaGNUM Disc Mower and Hay Mowers
Looks like the drum might have some advantages for taller grass and mowing above and below tractor level on banks. Looks like they can both run faster than a Bush Hog ?
/ Flail Mower Experiences #10
As I understand it, drum mowers are specifically designed for haying. They cut the hay but don't mulch it. The flail will mulch anything under the "hood" so you could not use it to cut a hayfield for harvest. On the other hand, you can drive a flail anywhere you can drive a bush hog.
/ Flail Mower Experiences #11
I don't think there is any standard so the companies pick a HP level that matches the gearbox (ie not greater than the rated capacity) but on the lower end there is a lot of variability. I would just guess that the higher rated (requiring more HP) flails are being rated for heavy duty service while the more modest HP requirements are taking into account a more typical mowing performance.
I have a 6ft Caroni flail on a tractor with 32.5 PTO hp. I rarely run it at PTO speed even when bush hogging in brush. I did manage to stall once or twice in very thick tall grass until I pushed the RPM up to rated PTO speed (2600). However it will cut lower grass all day loafing along at 1800rpm or even less. The point is that these mowers don't take that much HP to cut lawns or previously mowed pastures but you do sometimes need to either slow down or push up the HP in thick, wet stuff. I wouldn't hesitate to put the same mower (Caroni FM1900) on a 20-25 PTO HP tractor but I'd know that I'd need to go slow if I was in thick grass or brush.
/ Flail Mower Experiences #12
This is my "Fussy" $13,500 flail . It ran for 30 minutes before this happened . It was pre delivered , oil checked , bolts tightened and greased and brought to my house on their truck . The driver did'nt get back to the yard before i was on the phone going crook . The powder coat on the side plates chaffed and dropped out as powder after just under 30 minutes running . This made the bolts loose , one fell out as i backed up to a tree i had just mowed around . I put the mower down to go forward again , unknown to me the roller had swung under and i lowered the cutters straight onto it . I was told to check the bolts again after a few hours but it did'nt last 30 minutes . I have several flail mowers for my business and every time i go to use them , something has either broken , dropped out or is leaking . They are great for what they can do , but like i said they require a lot of maintanance . But if you only use it a few times a year in private usage tasks , they will give good service . (left click on expanded image)
/ Flail Mower Experiences #13
IronHorse, you should only purchase cheap used cutters.:D I recall you also had a battle with a new expensive bush hog/slasher (is that what you call them?) a few weeks ago.
/ Flail Mower Experiences #14
I'm just going to start building all my own attachments .:D
I spoke to the company owner in Italy , he rang me late one night to fix the problem , lovely guy . He asked me what i thought had caused it ? I told him that the side plates , bearing blocks , and even the washers had been powder coated . It would never rust , but the combined 30thou of powder coat should have been sanded off in that area so everything could be drawn up tight , metal-metal and then give it a squirt with a touchup gun . This is the way they do it now i'm told . They are a great company , CABE in Italy , he said don't you worry about anything . I will have a new mower at your house within two days , the new one turned up the very next day . I would recomend this company to anyone .:)
UNUSED RAYTREE RMDM72S - 72" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
2017 Mercedes Benz GLS450 AWD SUV (A61569)
2017 Mercedes Benz...
UNUSED JCT HYD TREE/POST PULLER (A62131)
UNUSED JCT HYD...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
2008 28ft. Regal 2565 Express Cruiser Boat with 30ft T/A Continental Boat Trailer (A61569)
2008 28ft. Regal...
UNUSED JCT HYD AUGER (A62131)
UNUSED JCT HYD...
