'nuther question (suzuki tcase)
/ 'nuther question (suzuki tcase) #1
towmotor
I've been hearing alot about the Suzuki Samurai transfer case. It being a divorced unit has me interested in trying one to get a little more grunt for my anticipated tractor build.
Does anyone know what the torque capacity of these units is?
/ 'nuther question (suzuki tcase) #2
I dont know the capacity, however there are many web sights catering to Samurai's ( lots of aftermarket gears too). I'm sure one of those will know.
I have a transfer case left over from my build, if your interested?
I might be interested indeed. I guess it depends on how much it's worth to both of us...
My only alternative is to make an input shaft for the NP208 I already have. Not very attractive.
I'll let you know.
/ 'nuther question (suzuki tcase) #4
Geo Tracker and Suzuki Sidekick transfer cases are also divorced units.
/ 'nuther question (suzuki tcase) #5
Samurai
1,298 cc 1.3 liters 4 in-line front longitudinal engine with 74 mm bore, 75.5 mm stroke, 9.5 compression ratio, overhead cam and two valves per cylinder
- Unleaded fuel
- Fuel economy EPA highway (l/100km): 8.1
- Single-point injection fuel system
- 40 liter fuel tank
- Power: 49 kW , 66 HP @ 6,000 rpm; 76 ft lb @ 3,500 rpm
So approx 76 foot lbs. If your ganging transfer cases the weeker one should be in front. Samurai transfer case is all gear with aluminum housing. I still have one kicking around waiting for a project.
/ 'nuther question (suzuki tcase) #6
Samurai
- Unleaded fuel
I'm not quite sure that is what the gear case can take, I sure hope it will take a lot more than 76ft # of torque!
I'm willing to bet it will ( think about it, a guy with a breaker bar can easily apply 76#).
/ 'nuther question (suzuki tcase) #7
Those torque and power numbers for the Sammy engine are at the
crankshaft. Torque is multiplied many times before it gets to the xfer
case or the tires.
I have an 88 project Samurai and the Xfer is tiny and very easy to
rebuild.
/ 'nuther question (suzuki tcase) #8
Ya forgot about that part, so I think 1st is about 3.65 or 4:1 so you looking at 275-300 lbs input and with 2.23 low, approx 600ft lbs output torque. I used an SJ410 T-case with 2.5 low range, though I don't think they sold that model in the USA.
/ 'nuther question (suzuki tcase) #9
Tracker/Sidekick/Vitara are NOT divorced transfer cases. You can get gear sets for both types cases. Sami is neat because changing the gear set in a Sami case changes both the high and low range.
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
2010 Massey Ferguson 2625 (A60462)
2010 Massey...
2016 New Holland Boomer 47 (A60462)
2016 New Holland...
Atlas Copco Air Compressor & Air Dryer (A62613)
Atlas Copco Air...
2009 PALFINGER 11 FT SERVICE BODY (A62613)
2009 PALFINGER 11...
2025 Swict 66in Bucket Skid Steer Attachment (A61572)
2025 Swict 66in...
