TRUCK AND TRAILER TEAM.
/ TRUCK AND TRAILER TEAM. #71
Does anyone make a deck-over with the back half tilt down?
Yes, I believe PJ does. I know a lot of others do too.
Kyle
/ TRUCK AND TRAILER TEAM. #73
This is the trailer I was looking for, Deckover with back half tilt.
/ TRUCK AND TRAILER TEAM. #74
Nice trailer, but I believe that is overkill for LB and his little BX.
LB I think you are making this a way more difficult decision than what it really is. If you were commercial hauling lots of different heavy equipment everyday, but for an occasional hauling of something small like a BX.
I think you are kidding yourself if you think you will be hauling buildings on a trailer anyway - how often are you going to do something like that? Unless you are going to start building a selling them. Then there is a reason why the guys that do it use the big roll back trucks. Too much wind resistance/top heavy. Unless you move up to a really big trailer or something like what J J posted.
/ TRUCK AND TRAILER TEAM. #75
/ TRUCK AND TRAILER TEAM. #76
That trailer I posted is only 20 , or 22 ft. Here is the link. What is the total length of a med size trsctor with a bush hog attached?
PJ Trailers- Ferguson Trailersales Dover MN And Rochester MN Locations Offer PJ Trailers, Dump Trailers, Car Haulers, Utility, Deckovers, Pintle, Tilt Bed Trailers, And Tow Dollys
First, that's a hydraulic dove trailer. I thought you meant a tilt trailer with 4-5' in the front that are stationary.
Second, a BX is VERY small. A garden tractor with ROPS. And, I don't even think he has a bush hog, but he does have backhoe that is a little smaller than a bush hog, and it's maneuverable. He'd be fine with 14ft. it'd be tight, but it'd work.
Kyle
/ TRUCK AND TRAILER TEAM. #77
LB, (JMHO)
If you are wanting to haul your tractor, car, lumber, etc...and no buildings, then this is all you need.
*Truck---1/2 ton, auto, 4x4, V-8
*Trailer---16ft. to 20ft. Car Hauler. (brakes on trailer)
*Use a weight distribution hitch with sway control.
___________________________________
If you listen to other people on (another thread) they will have you trying to haul 26000lbs. with a pickup truck and trying to make you into a "Hot Shot Trucker" which will get you killed. I think you said that you had never hauled anything with a trailer before.
I won't tell you here how much weight i hauled with my F-250 or my F-150, when i needed to haul a load in one trip and not two, but i don't tow that much anymore,
The two tractor trailer company's i use to drive for was a flatbed division, and sometimes i would have a load that if i had extra chains/binders i would be over weight.
What a couple people on (another thread) don't realize is, that there is probably teenage kids or someone that has never towed/hauled before, and has already viewed their post. So they probably figure if someone is towing 26000lb. with a pickup, than they will be able to haul that much.
I have had the best training in hauling with tractor trailers, and i used what i learned to haul with a pickup truck but follow the (GVWR) and don't go over that, and don't brag about going over the (GVWR) for everyone to see.
If you get a trailer with brakes,(use them) and a weight distribution hitch with sway-control will help, some of the others don't think so since they are experts in boat towing.
Hope you find the best setup for your needs.
____________________________________
/ TRUCK AND TRAILER TEAM. #78
LB,
If you decide to haul bigger loads, then get a bigger truck and the trailer that J_J found would be the best, for hauling buildings__etc...
/ TRUCK AND TRAILER TEAM. #79
Kyle
Kyle.
The trailer I posted above is still called a tilt bed because it doesn't have fold up ramps. All dovetails have fold-up ramps. The trailer that I have now is an 18 foot deck-over, with a 7 foot add on dovetail with ramps. I may change it to hydraulic dovetail in the future, or hydraulic ramps
/ TRUCK AND TRAILER TEAM. #80
J J-
It technically does have a dovetail. Just looks like a normal flat deck while driving on the road. But I don't want to start any arguments.
P.S.-
I've seen that 2nd pic on here before. I wonder if LB can see what's wrong with it...:rolleyes::D
Kyle
2015 TROXELL 130BBL STEEL (A58214)
2015 TROXELL...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
2004 Bulter Pole BP-2080-A T/A Pole Trailer (A60352)
2004 Bulter Pole...
2011 FREIGHTLINER M2 (A60736)
2011 FREIGHTLINER...
2004 VOLVO VHD TRI/A CEMENT MIXER TRUCK (A59906)
2004 VOLVO VHD...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
