Installing speakers in the headliner of the B3030
/ Installing speakers in the headliner of the B3030 #1
WaxMan
USA CT
Kubota Grand L 3240 cab BH 92 backhoe
When I put in the DVD/ stereo, / backup camera it sounded Ok but still something was missing even with two 6.5 inch speakers mounted behind the seat the sound is always competing with the tractor sounds.
After watching 4ahorts new tractor video last week and seeing his built in speakers in his headliner, I thought I can do that. With speakers up top I wouldn't need to blast the sound since they would be above the sounds of the tractor and closer to my ears.
Only one problem there was no flat spot to mount the 4 inch speakers. Problem solved I used the same plastic board that my gauge panel and running lights were made out of and made my own flat spot.
Easier said then done though I had to literally hand carve the plastic to fit the curves in the headliner allot of trial and error.
It's finished now and sounds so much better with the speakers in the headliner and speakers down below a complete full all around sound.
So if anyone was thinking about putting speakers in the headliner, it can be done.
/ Installing speakers in the headliner of the B3030 #2
Looks great! Must be hard to get out of the tractor once you are in it, lol. If you need to get out of the house you can always hang in the tractor and tune out... :D
/ Installing speakers in the headliner of the B3030 #3
Ah WaxMan that's pretty cool. Very nice workmanship. That's one thing that I love about my beast is the sound quality of the sound system. It's as good as anything I've ever heard. Now you'll have even more fun in your rig!
/ Installing speakers in the headliner of the B3030 #4
Geez I am roughing it driving a tractor with just a ROPS bar. You guys are driving limousines around! :eek:
Yeah I thought yours sounded great even in your video when you opened the door. And so another idea from viewing your tractor.
/ Installing speakers in the headliner of the B3030 #6
Hey Waxman. Your going to have to add front fenders to your rig next. A few of the Canadian "L" series Kubota's have them. I've added extention flaps to mine and they sure keep the front of the cab clean if you need to travel on a wet road :D
/ Installing speakers in the headliner of the B3030 #7
Waxman, great job, as usual!!!! I guess there is no reason why I couldn't move the (behind the rear seat) stock speakers that came with my HSDC to where you have them. What type of screw/bolt fasteners did you use to attach the foam then speakers? Again great job!!
Thanks Stanley
That's the speaker grills that I used from the factory Kubota speakers , only grills that will fit. 4 inch round ones are too big.
I didn't use foam but a hard 3/4 inch ABS plastic board.
But you could use some 1/2 inch gray foam instead, just trace the speaker grill onto the foam, once up there it will compress to fill in what you need. That would be a heck of a lot easier to do then what I did, it might even look better.
I would at least try it first.
As shown in the fifth picture I first bolted up the plastic piece where I wanted it , then used a hole saw 3 5/8 to drill the hole in the headliner using the plastic piece as a guide.
I use 8/32 stainless steel screws and nuts, I epoxied ( Plastic welder the best epoxy in the world) the nuts to back side of the headliner so the speaker can be removed and installed without taking the headliner down.
I would buy two more grills from Kubota and leave the factory speakers where they are. You need all four to get a really complete sound. You'll have sound below you and above you, the factory speakers are already there leave them. I bought two Alpine 4 inch speakers to put in the headliner much better then the stock speakers. I have two Kenwood 6.5 speakers shown where the Kubota factory speakers were, but until I did the headliner speakers there was always a fight in the cab between the tractor sound and the music. I don't want to have it blasting just to hear it.
Put two in the headliner and leave the factory speakers in the back you won't regret it, or even better buy 4 new alpine 4 inch speakers two in the headliner and two in the factory speaker boxes that are already there, small amount of work for a big big difference in sound. Or you can be even crazier with the 6.5 speakers but it may not be needed try it with the factory boxes.
You can only imagine the sound difference in my cab from factory, until you do yours.
/ Installing speakers in the headliner of the B3030 #9
Waxman, thanks for your reply and photo. After I had already posted I realized that you had used the hard plastic. I can imagine that was fun (not!) shaping the plastic to fit the tractor. I'll check into adding speakers and leaving the originals. Of course finding the time to work on this project is tough. thank you again.
Your tractor looks pretty mean in that picture 4shorts,
I been wondering when are you going to paint that fender?:D. my rigs a toy compared to yours.
SRS
Use the foam method, you'll get it done on a Sat morning and I'll bet you won't even see the foam it's not that much off being flat. I should have thought of that.
It's tough when you got a new tractor to start cutting this and that.:eek:
You might need some time just to get up the nerve to do it. It took me awhile.
I always price out what the part I'm cutting up before I do it, Headliner $285.00, that was my just in case I wreck it price:eek:
/ Installing speakers in the headliner of the B3030 #11
SRS
I don't know with your workmanship I find it difficult to believe you would screw up something like this. It takes a lot of thought to do what you've done to your 3030 and they ALL turned out perfect. This also applies to the projects that 4shorts completes, both you guys do a great service here to TBN members by sharing your knowledge.
Thanks srs, but to tell the truth when I do screw up,:eek: it just leads me in a new direction and I just make it look like that's what I had in mind when I started!:D
/ Installing speakers in the headliner of the B3030 #13
srs. Everyone screws up from time to time. I don't post my screw ups :D I appreciate your comments on our posts. I'm a member of a number of forums and post on all of them and it's always nice to get feedback on what I do. One thread on a bike I restored has over 44.000 hits on it now and that's rewarding to see there are those who are still enjoy viewing it.
I share most of my work online. Just the other day I was doing a little custom work on a Harley part a customer brought in to me. He had a pattern made out of plywood and needed a windshield trim made for the fearing. As you can see by the photo I made the trim and buffed it plus made the other aluminum parts. The trim is sitting on the same material the it was cut from. Just a small example of something else I do other than my usual automotive repairs. Thanks again for your kind words!
/ Installing speakers in the headliner of the B3030 #14
Would you mind taking the tractor out and then going back inside and taking pictures of those large pictures or posters on your walls and posting the pictures for our review?
Well OK Dave, but your supposed to be looking at my tractor,
Believe it or not but she's been hanging there since 1986 I never thought she would be in the picture until I posted the tractor.
For your review.
/ Installing speakers in the headliner of the B3030 #16
Hey! I've got a BelAire compressor... but I think I am missing a part!! I got cheated:mad:
/ Installing speakers in the headliner of the B3030 #17
Waxman- SLOW DOWN. I haven't even copied your light project yet and now you've done another one thats got me going. Did you do a previous post on how you sey up the dome light in your tractor and wired it?
/ Installing speakers in the headliner of the B3030 #18
Hmm, I love music as much as the next guy/gal (listening to a CD now, on a very good audio system), but I'm stuck with using an MP-3 player (the compact kind one wears at a gym or similar) and noise reducing headphones while on my tractor. I realize that your speakers, installed very well, are inside a cab - me, I'm in SC and only have a ROPS for mounting stuff. What is the ambient noise level in your cab - my L3410 runs about 80 db at idle, without a cab, much more when I rev up. At 85 db in a commercial setting one is supposed to have yearly hearing tests, and at 90 db a mandatory hearing conservation program (hearing protectors). I don't want to be a "stick in the mud", but when you combine the hearing loss that creeps up naturally with ageing to that of noise exposure, there's a huge number of our 60 plus year old peers who can't hear well at normal conversational levels, and are more or less clueless trying to follow conversations in noisy environments, such as a family gathering.
Without getting extreme about it, protect your hearing when it's easy to do so (yup, I don't use earplugs when hunting - heck 1 shot from my 7mm is all I usually need, and admittedly they "ring" for a bit, but my hearing loss isn't much, yet). It's worthwhile, and there's no good substitute.
/ Installing speakers in the headliner of the B3030 #19
Picked up my new B3030 HSDCC this afternoon. Spoke to my salesman earlier in the day about a Kubota radio mount. He tells me that his cost was in the $250 neighborhood because the mount and speakers are sold as a unit.
Rather than argue the point, I decided to just look elsewhere or possibly have a local audio place do an install sometime in the future.
I have more important things to learn about this tractor and the way it operates and the differences between it and the JD 790 that I traded in so I 'll get to the audio at a later date.
I understand what your saying and your right about hearing loss, I'm not sure of the noise in the cab but I know the tractor is a lot louder when you open the door probably twice as loud when the door is opened . The cab makes it much quieter.
The reason for the extra speakers in the headliner is not to turn it up louder but since the speakers are closer to your head they don't have to be as loud.
At least it seems that way, My Ipod earphones would have to be just as loud and I'm sure just as much damage or more can be done with the headphones up too loud.
In any case a cab tractor is going to be less noisy then a rops tractor.
I think i said a couple of times I don't want to have to blast the music in my cab to hear it and that is what you have to do when the speakers are on the bottom.
I might pick one of those meters up , maybe even custom install one in the headliner:D
The better the system is the less volume you need to enjoy it.
But I agree with you on that and maybe now I will be more aware of the damaged I could be doing to my ears if it's too loud . Thanks for that wake up call. I appreciate it.
2016 Nissan Sentra Passenger Car, VIN # 3N1AB7AP6GY307338 (A61165)
2016 Nissan Sentra...
Case 580 Super K Backhoe (A61166)
Case 580 Super K...
2002 Allmand Night-Lite Pro Towable Light Tower (A56857)
2002 Allmand...
2018 Jayco 264BH 29ft. T/A Travel Trailer (A61569)
2018 Jayco 264BH...
2025 Pabreak Hydraulic Vibratory Roller Skid Steer Attachment (A61567)
2025 Pabreak...
WACKER NEUSON LIGHT TOWER (A60736)
WACKER NEUSON...
