Flatheadyoungin
no, the corners i'm satisfied with......this is a large slanted square.......each side is approximately 1600ft.......when i stand on the line, i cannot see the corner markers and i want some pins on the line......this being the case, for example, i don't know if certain trees are mine......or if i were to put in a fence, i don't know where it should go....
I don't quite understand what you are having done. The property has been surveyed by a licensed surveyor recently and I would assume a stamped plat filed with the county. Plats here must note what the corner markers are, "11/2 galvanized pipe, 3/4" rebar, ect." The surveyor's magnetic spikes, pins, ribbons and wooden stakes are in place. Sounds like the corners are already marked.
Am I missing something or are you paying $1100 to have him drive some other sort of spike? I don't know why you would do that with the survey already done. If you are worried the existing marker will not last go drive some rebar 3' into the ground.
MarkV
