Another Homemade Backhoe
/ Another Homemade Backhoe #1
David Devuono
Brampton, On\lot Powassan, ON Canada
Kubota B4200\MF 135\Kubota B3200
I have a couple hundred hours into my backhoe project so figured it was time to start a thread on it. I had originally started collecting cylinders to build a FEL for my Massey 135. Since I already had a FEL on my subcompact Kubota I got to thinking a backhoe might be more useful, especially with digging up the stumps that currently determine the path of my roadway. Here is a short video on the action of my bucket mechanism and some of the other pieces. Since I am building the unit around some FEL cylinders I have resorted to some unusual design enhancements. The plan is to bolt it to the rear end of the massey which is pretty heavy cast unit and the backhoe will likely be 4-500lbs.
YouTube - Homemade Backhoe Project
/ Another Homemade Backhoe #3
Lookin' good, Dave! The crowd arm cylinder and bucket cylinder don't touch? I bet it's close!
/ Another Homemade Backhoe #4
Where on your tractor are you going to mount the compressor?;)
Boston rocks!
Nice work :)
/ Another Homemade Backhoe #5
Ductape, you don't need a compressor, just a really long air hose!
Some of the clearances are close but I have tested the main boom to dipper arm cylinder clearance with a 90 degree hose and I have about 1/4 inch to spare which will give me a 7 foot digging depth. Hoping I don't have to move up to a 3" cylinder for the main boom from the 2.5 inch.
/ Another Homemade Backhoe #9
Looks good!
I don't know much about backhoe design. But my first thought was how it appears a bit different from most BHs and recalled how even on factory one people sometimes bend that cylinder. The factory BH's tend to have some sort of moving bracket that I think tends to help keep the cylinder in line, I'm speculating that perhaps the purpose is to reduce potential bending stresses on the cylinder. It that something you had considered?
I have studied a lot of different backhoe designs and can't think of any moving bracket. The only real difference mine will have is that the dipper cylinder and bucket cylinders will only be using about 24" of their 36" stroke. Some day when I am in need of the long cylinders I will weld in brackets for some 24" stroke cylinders. For now the dipper cylinder will run underneath the main boom cylinder. The bucket cylinder to bucket brackets (will have to learn the proper names) will be H braced. The main boom is 1 1/4 pins, all other pins are 1" which is what the cylinder ends require. I surely don't have much room with just a 10x 20 garage that is full. I have a 10x10 heated shed that contains the lathe and band saw. So far I have not burned the house down, touch wood.
/ Another Homemade Backhoe #11
I was referring to a bracket such as the one in this picture. I don't know the purpose of it. But, I speculate that it provides a means to keep the forces more straight with the piston as the angle of the piston doesn't move much throughout the motion range. I see in your video that the piston moves from parallel to about a 30 deg angle through out the piston range and it does not have such a bracket.
Mine has that bracket, only instead of being arc shaped, mine is L shaped. It is made 1/2 inch thick and I will be adding an H brace to stabilize it. As well commercal backhoes have like 5,000 PSI and large cylinders so they don't need extra leverage. This piece is to allow the bucket to curl without having a large bracket produding off the back of the bucket. (I think :)) Since I have so much stroke available, I made this lever longer then normal to make extra dipper power. Its potentially an expensive mistake if the backhoe does not work but its keeping me out of trouble this winter.
/ Another Homemade Backhoe #13
I found when building my BH, the cylinders were not the major expense, but the steel, bushings, control valve and etc. I don't think I had over $300 in cylinders. I admire you using what you had on hand...but doing the re-design to make them work must be chore. I'm wondering how you will limit the stroke to be only 24 inches out of 36? I think I would have sold the long ones, and purchased ones a more common size for a backhoe.
/ Another Homemade Backhoe #15
We use an arm like that on our commercial payloaders for years: as you said it gives extra power where most needed, in other words, gives a constant curl torque over the full bucket motion. If you use bigger cylinders, you will have power where you dont need it (speed loss) when the cylinder is also capable to generate the bucket torque in the less favourable positions of the cylinder vs. hinge points.
Designing mechanisms like this, is allways a lot of fiddling with the geometry if you want to lay out the torque in the curl positions where needed, without slowing the speed so much where torque isnt needed.
/ Another Homemade Backhoe #16
Interesiting project! Looks like you've got it well thought out and you're well on your way.
The question I have is what sort of hydraulic rate pump will you need. I was told these things are pretty hungry when it comes to hydraulic fluid and you need a pump with substantial delivery capacity to run them.
My 50 hp tractor hydraulic pump tops out at 15gpm, so I can't operate the skid steer rotary front mount augers because they take close to 20 gpm.
Keep up the good work.
I don't see the long stroke as an issue because you should not use the internal stops in the cylinder to limit the cylinder stroke, you should use an external stop. As well a 36" stroke cylinder with 12" inside the cylinder would be more stable then the same dia cylinder with 24" stroke, fully extended, not that there should be much lateral force on the cylinder. As far as pump capacity, I would think that anytime you are using a hydraulic motor, you will require lots of GPM, operating small cylinders require a lot less. My tractor has about 5 gpm at 2300 PSI (+_ on a 40 year old tractor). The previous owner had a FEL on the tractor and it raised the bucket with 2 cylinders at a reasonable speed. Anyway as long as it works faster then a pick and shovel, I will be happy, plus will be safer cause I won't have to be in the hole digging :)
Things are progressing. I scored big time when looking for a control unit for the backhoe. Found with the help of a great young hydraulic counter person a discontinued BM40 6 spool for $199.99. Anyways mocked up the backhoe on the weekend and found a few clearance issues that require work. Its getting far too heavy so will cross my fingers I am not making a big pretzel.
I set things up using the built in receiver hitches I have on the back of my trailer.
/ Another Homemade Backhoe #19
These links are part of the four bar linkage that allows the bucket to rotate more than it would if the cylinder rod was attached directly to the bucket. A bucket with links can rotate 180 degrees and have more power as the cylinder reaches full extend or retract.
After a busy week of late evenings and using up a vacation day I finally got the backhoe together and installed on my tractor. I had fun routing the hoses as I originally planned on 1/4 hose, only to be told I could not go from 1/4 hose to 1/2 without using two adapters, so I went with 3/8 hose. Later the guy fingers out its not 1/2 but ORB 8 and he finds a single adapter. I should have made him redo $600 dollars worth of hoses. Anyway the 3/8 hose is tough to bend and all my hoses were 6" short due to the large bends required. I was able to make do with the short hoses. I also realized that I will have to reroute the exhaust as the old Massey 135 exhausts out the rear. My first project was to dig out a stump and after 20 minutes I realized the frost was still in the ground and I would need a jack hammer so that project will have to wait a few more weeks. I do have to run the tractor at high revs to get the flow needed for cylinder speed. Perhaps a 3ph pump will be in its future? I will post a video in a few days.
2020 Ford Transit 350HD Cargo Van (A61573)
2020 Ford Transit...
2006 Lexus ES 330 Sedan (A61574)
2006 Lexus ES 330...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A61572)
2023 Caterpillar...
2023 Kubota L6060HST Compact Utility Tractor (A63688)
2023 Kubota...
PALLET OF (24) 2" X 8" X 27" CHANNEL IRON (A64280)
PALLET OF (24) 2"...
