08 F550 V10?
Status
Not open for further replies.
/ 08 F550 V10?
well I went down to the dealer and tested the truck and i dont think im going to pull the trigger on it the diesel is in my blood. From driving my unlces Dmax i might look at one of them
/ 08 F550 V10? #42
Its hard to get it out of your system. I love driving the F-150 when the weather is bad and we are going on a family trip but I always miss the F-350 for the fun of driving.
Chris
/ 08 F550 V10? #43
That plug spitting is pretty easy to fix. I've got a kit that puts a new threaded sleeve in there to fix it. So far I've fixed 12 or 13 of them. The tool looks like a wierd tap. It has small threads and larger threads. The small threads pull the tool in, then it starts cutting a bigger hold and finaly threads the bigger hole. You then use another tool to screw a threaded sleeve into the hole, install the spark plug and coil, and your done. Only thing that stinks is that cylinder is under the cowling and isn't fun to fix(my hands are claustrophobic):D.
/ 08 F550 V10? #44
I think you made a smart move. If you need a dumptruck, they really are complimented by a diesel. You rarely see a bigger dumptruck with a gas engine anymore. A DMAX will eat a V-10's lunch in probably every category except initial purchase price. Of course, diesel fuel costs more.
I'm curious what you probably would have to pay for that 550, but I'd bet you could get a real nice 26K diesel dumptruck for less. An over 26K air braked dump might cost even less.
/ 08 F550 V10?
I dont really need a dump per say it would be nice for salting/sanding though and for sure the Dmax will eat the V10 up in no time.
/ 08 F550 V10? #46
Wouldn't one think that opinions registered from a "Ford truck enthusiasts" website might be just a bit slanted in favor of Ford?
I would trust findings from a "consumer affairs" based forum over the opinions of a Ford truck enthusiasts forum.
I actually like the V-10, but it definately has a documented plug-spitting problem.
You're probably right...that would be like going to a tractor website and asking questions about different brands of tractors and expecting to get a straight answer....
The "plug spitting" problem was cured at least 3 years ago and is not an ongoing concern ....unless you want to make it one - which is apparently your mission.
/ 08 F550 V10? #47
Actually it wouldn't. Notice that the website in suspicion is a FORD enthusiasts website. This website, OTOH, is open to all tractor brands and lucky for us, has a few skeptics that are allowed to discuss the downside of things. If I logged onto a FORD enthusiasts site, I would realistically find a lot more glamourizing of Ford products than skepticism.
I think it's only fair to introduce a healthy dose of skepticism to anything, even the much heralded Ford V-10.
As the discuussion progressed, we of course got the usual dumping of compliments on the V-10 from the usual sources. I thought it would be objective to also point out well documented shortcomings as well from neutral consumer affairs groups. Is that fair to you?
Many people don't like to hear bad news, swines, but I think it's our duty as members of this website to point out the shortcomings. If we didn't, we would look like fools patting each other on the back telling each other "everything's perfect, no need for concern about anything".
I think some members of congress & senate did that right before the collapse of our country's financial system. Look where we are now.
/ 08 F550 V10? #48
No matter what truck brand you buy, I think that I can offer you some suggestions. I plowed snow & salted acres of parking lots for a long time. If I were looking for a truck for salting and needed to watch my budget, I'd consider a simple platform body on a DRW heavy truck. I'd mount a V-box spreader powered by a pony motor on the platform. You can get platform bodies made with wood decks, which are corrosive resistant. Even if you got a steel platform, it would be cheaper to replace later.
Salt in a steel dump body = big time corrosion.
/ 08 F550 V10? #49
I never knew about the plug issues on the Ford 5.4 and V10. I had a 5.4 and it was a good motor once I put the edge programing in it...
What gets me is that Ford has not fixed this issue over the years..... You would think it would be fixed by now...
/ 08 F550 V10? #50
3500DIESEL,
glad you didn't put yourself in something you probably would have regret later, that is a good looking truck, but for me when it comes to hauling i like a Diesel. that picture in your avatar is that your truck?
/ 08 F550 V10?
the truck in my avatar is my cuzs companys truck it was crap untill he did the DPF and EGR delete now he loves it, its a dodge 5500 cummins with 6speed auto and a Boss V xt plow. heres a bigger pic.
/ 08 F550 V10? #52
Really ashame isn't it?
They build a nice truck, then outfit it with an unreliable DPF system. Now you have an owner faced with the grim prospect of removing federally required pollution control devices to get a new truck to run right with a possible huge $$ fine if you get caught.
/ 08 F550 V10?
were we are at they dont do any testing so it dont bother us to bad, I hope the new diesel you can delete that Urea crap and dpf.
/ 08 F550 V10? #54
I'm in the same situation here in PA, no tailpipe testing. However, many states do test and the pollution controls are federal controls, not state, so even if they don't check, *technically* you're still breaking the law since it's a "federal" device. :rolleyes:
/ 08 F550 V10?
what they dont know wont hurt them. Im thinking of buy my cuzs old personly truck 2004 GMC 2500HD ext cab short bed with the lly dmax its a nice truck has 65,000miles on it.
/ 08 F550 V10? #56
Do some reading on that LLY. Its the least desirable of the Dmax enginge.
Chris
/ 08 F550 V10?
I have and all of the dmaxs that are in my family are LLYs besides dads LMM
/ 08 F550 V10?
there was only really two problems with the lly if you leave the intake stock it can over heat if you tow alot and i mean like over weight thats due to the turbo mouth piece its restriceted there two fixs to this problem a good intake or replace the stock LLY mouth piece with a LBZ or LMM mouth piece. The earlly LLYs had a little injecter problems but it wasnt a huge deal and if they go on the truck i buy it should be under warenty. The only thing the truck needs is the Dmax badge he took the old Dmax diesel one off and he wanted to debage the whole thing, but then he saw the new dmax allison badge but never got to put it on so its a little embaresing not showing the diesel pride but heres a few pics of it.
/ 08 F550 V10?
yea it is pretty sweet needs a few mods though. HAHA
Status
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
3pt Peanut Wagon QA Hitch (A64127)
3pt Peanut Wagon...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2017 Hyundai 53' Dry Van Trailer (A62613)
2017 Hyundai 53'...
6 Row Harrell Stalk Chopper (A62177)
6 Row Harrell...
2023 J&J TRAILER (A65643)
2023 J&J TRAILER...
