Another addition! Ambient Temp Gauge
/ Another addition! Ambient Temp Gauge
Thanks 4shorts and the same goes out to your boys!!:)
yep indeed your cab looks very warm.................hopefully this spring I can start building mine for the next season!!! I've already started gathering the materials! :) (steel, heater,weather striping, tubing, stereo.......) You gotta love Princess auto!! :D
I'm not as tough as you military people, I need warmth and a song playing to plow snow these days:D
Oh man that Princess Auto in something else. I could live there. You might say that I'm well known there :p I'll look forward to seeing the progress of your cab.
Really nice custom jobs you have done with that welding cart, tractor, and your motorcycle.
I really enjoyed the video of your motorcycle, just like the welding cart video from start to finish.
Looking forward to the forklift after it is finished.
_____________________
Glad you enjoyed the video's. I've been trying to put them together for a while now and it seems most enjoy seeing how I restore my old junk. In the last ten years I've restored so much stuff that I have 26.000 images on my computer. Yep. I snap photo's of all the stuff I do.
The fork lift is coming along very well. I looks much nicer than in the photo's I attached below :D It's now rebuilt and painted. Just the custom stuff to do with it next.
Dang Shorts, you done pimped your tractor. :eek:
Will it's sure starting to look that way for sure :eek::D
/ Another addition! Ambient Temp Gauge #42
I have that same sandblaster only in green, I haven't used it in 20 years ,
I used to own a body shop back in the 80's
Sandblasted all the time cars, scales, etc.
But i do remember it was pure **** sandblasting something that size. Sand in my ears (even with the hood) sand in my pants, my hair, my pockets.
But it does a good job. nothing like it.
Now I just have a little cabinet sandblaster for little things.
One thing I like to do with small parts is after sandblasting wash with soap and water and then paint the item, no primer, then I cook it either in a toaster oven that I have for that purpose or the heat gun, I heat it up to about 500 degrees for about ten minutes puts a hard scratch and chip free surface.
It only works good after sandblasting because of all the little pits the paint bites right in. Once cool I run it under cold water it's hard and dry and ready for use. That mirror bracket that you just painted I would of sandblasted it, then put a very thin coat of paint just to cover then heat it up, the paint shrinks and sinks into the sandblast pits and puts a nice slightly textured factory like hard finish. Actually works best with aluminum try it sometime.
My next project in my garage I want to build an exhaust hood over my welding bench , for welding and paint fumes to make life easier.
/ Another addition! Ambient Temp Gauge #43
Don't forget your bellybutton and butt ! I worked in a bodyshop in the 80s......:(
/ Another addition! Ambient Temp Gauge #44
So what's worse; Bondo dust in every nook and cranny of your body or sandblasting dust?
Guys when it comes to this restoration stuff and the tooling needed to do it safely I don't cut corners.
You'll notice in the photo's that I have a special sandblasting helmet on that's made by 3-M. It's hooked up to an ambient air blower in the shop that will pump fresh filtered air into the helmet plus it creates a positive pressure inside the helmet. There is NO dust that gets into the helmet at all.
As for the lift photo's. I never sandblast there in the open. This time I had to do it because the forklift was not running and pretty well dismantled at the time. I usually do my sandblasting in a container in another part of the property. It took the best part of the day to recover, clean that area and then it was all pressure washed down. Sometimes you got to do what you got to do to get'er done.
mjncad. I attached a couple of phot's of tools I made this past weekend. There two different size metal breaks. They work great and there strong. I built the big red press a few years ago. It's electric over hydraulic. There's also a photo of a tubing notcher I built and still use from a few years ago. I know you and WaxMan are extremely good at building stuff so I thought you might find it a little interesting.
As for the photo of me standing by the bead blaster. Have a look at what I'm holding. There's a story there as well :D
WaxMan I have baked some items in the past and your right, it works great. I've done it to motorcycle gas tanks after refinishing. I do all my bead blasting in a bead blaster that has it's own recycling and recovery system. Great unit and very efficient.
When it comes to the pressure blaster you see in the pictures. Well there's a bit of a story to that one and I mean that literally. I designed and built that one. It was featured in Welding, Design and Fabricating magazine in Cleveland a few years ago. This thing works better than good. I attached the story below to bore you with. :rolleyes:
Some more photo's for your viewing pleasure :rolleyes:
And a few more!:confused:
/ Another addition! Ambient Temp Gauge #48
What do you guys think about soda blasting instead of sand? I've only seen the reults on one car, clearly no expert here. It seemed to work just as well for removal with no immediate need for paint or primers. No special handling , just hose it down and it's eco-friendlier :rolleyes:
I bet it's a good system. Larger than what I've been using. Would really like to try it sometime. Some good systems out there.
Soda Blaster Sales Official Website
/ Another addition! Ambient Temp Gauge #52
Pretty cool. I'da sworn it was an S M MobilOil tanker looking at the pic. I sent two S Ms out to a guy in Cali who restores them. They were hand me downs from my brother, but were my favorite toys as a kid. Over the years I collected a bunch more, but sold off most of them before the market on them went south. I'll never part with the ones i had as a kid though.
Wow Ductape there super cool. I don't blame you for not selling the ones you had as a kid. I don't have one from when I was young but to tell the truth I never had many back then anyway :( I think I made up for it now though.
I'll have to post a few photo's tomorrow of the pressed steel ones I have in the office. Walls are full of them. Love this kind of stuff. Sure is funny how we can go from owning a tractor to enjoying old toys. Really enjoyed seeing yours. Thanks for posting the photo's
/ Another addition! Ambient Temp Gauge #56
4shorts - getting blasted yet?
You need a new gauge for yer dash. You know the one: rock held up by a string attached to a wooden sky-hook. Do you want to explain to others or should I.
Hope everything is well on your end. You will be getting another n'easter tonight.
Play safe...
lloyd
Play safe...
lloyd
Hey Lloyd. Going to be nothing for us here. We're supposed to get 2-4 CM and then 10 MM of rain. Wonder can you replace a cutting edge for a squeegee?
How's the new Kioti? You happy with it? She's a nice machine that's for sure . You can do the explaining :D
/ Another addition! Ambient Temp Gauge #58
4Shorts:
If you ever open up a Colorado branch, let me know so I can apply for a job. :D
I like your philosophy of quality.
4Shorts:
If I ever did you wouldn't need to apply. You would be the second person to get keys to the building :D My late Dad always said "If it's worth doing, It's worth doing well". I've spent the last 20 years working knowing he's looking down on me and I'm trying my best not to disappoint him. :) Appreciate your comments sir.
/ Another addition! Ambient Temp Gauge #60
Hi 4shorts , since this is your thread I thought I would ask here.
I installed a dome light in my b3030 I have the light installed but want to use door switches to operate it.
I was watching your youtube video YouTube - Specialty Repairs 2008 Kubota of your beautiful new tractor and notice when you opened the door the dome light came on. Did you hook that up or is it factory? Could I trouble you to post a close picture of your door switch, our doors are very similar and maybe I could use the same switch in the same location.
Also is your dome wired hot all the time like a car or only when it's running.
Thanks for any information.
John Deere 5075E Tractor w/ John Deere 520M Loader (A64047)
John Deere 5075E...
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A62129)
2019 VOLVO A45G...
SDLGC100 Golf Cart (A64047)
SDLGC100 Golf Cart...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A61569)
2014 Glasstream...
Skid Steer Flat Bottom Grapple (A64047)
Skid Steer Flat...
7500 Gallon Fuel Tank (A64047)
7500 Gallon Fuel...
