Quick Connects
/ Quick Connects #1
Highridge
Gold Member
Southeast, MA
Power-Trac 1430 and Craftsman DGT6000
Hi
I was wondering if anyone has found a source other than power-trac for the hydraulic quick connects? I broke one today and dont feel like buying $50 worth from power-trac.
thanks
/ Quick Connects #2
Hi
thanks
I matched up some of mine at the local hydraulic shop, but mine is an old PT.
Take one off and match it up. or change out the male and female coupler to whatever is available. Northern Tools has some, Baileys.com
/ Quick Connects #3
I went through this recently as well, and it was cheaper and quicker for me to just replace the connectors with Parkers than try and track down the crazy 3rd world connectors PT uses...
Also, I took the PT connectors in, and they looked close to other connectors, but never quite fit.
/ Quick Connects #4
I got some for an old wood splitter I converted to the PT, from Tractor Supply. I guess most of their stuff is from 3rd world though.
/ Quick Connects
Thanks Mossroad!
I'm pretty sure the quick-attach couplers are 1/2" or possibly 3/4?
/ Quick Connects
Hey guys,
I just found out that any 1/4" quick connect from a fisher plow will work. I bought a couple from the dealer and put them on and they are basically the same thing.
/ Quick Connects #12
When using Quick Disconnects, you should use one size larger QD's than the hose size. When using the same size QD's, you will restrict the fluid to some degree.
26120 (A56859)
26120 (A56859)
LILLISTON 8R ROLLING CULTIVATOR (A63291)
LILLISTON 8R...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A62130)
(INOP) 2013 MACK...
iDrive TDS-2010H...
2006 CHEVROLET 2500 SERVICE TRUCK (A63291)
2006 CHEVROLET...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63689)
Dual Tailwheel...
