JD 5303 starting
/ JD 5303 starting #1
racer478r
This is my first tractor with a turbo and when starting up it cranks quickly but seems it is loaded up with to much fuel
. With some amount of dark smoke and the rpm will build up quickly and clean up. Question is this normal or do I have a problem. Tractor has 7 hrs.
thanks
/ JD 5303 starting #2
thanks
nah your tractor is fine. i have a 5203 with the turbo and mine does the exact same thing as what youre describing. it didnt do it as much in the warmer weather, just something about the cold that makes mine smoke a little bit more.
/ JD 5303 starting #3
Did they change them? My 5203 does not have a turbo. But starts the same way in the cold..... I make sure not to give it any throttle when starting.
/ JD 5303 starting #4
yeah they added them in 07 to meet emmisions I think. mines an 08 with MFWD and syncshuttle. all the 5003 series are turboed now(well in 07-08 anyways since they are changing the model numbers this year). i love hearing the turbo when i throttle up or down! it's now reccomended that you give it 1/3 throttle, then start it(due to the turbo i guess). when shutting her down, they want you to bring down the throttle to idle for a min. or so before shutting off.
/ JD 5303 starting #5
One more here.
On cold days my 2008 5303 smokes like the devil for a few seconds when first started.
2012 International Prostar (A63118)
2012 International...
2006 Mack Granite CV713 Dumping Flatbed (A62679)
2006 Mack Granite...
2024 ANKONA 54" HANG-ON WHEEL LOADER FORKS (A62129)
2024 ANKONA 54"...
King Cutter Rotary Cutter (A63116)
King Cutter Rotary...
2009 PETERBILT 367 KILL TRUCK (A63569)
2009 PETERBILT 367...
2016 JCB 510-56 10000 LB Telehandler (A64047)
2016 JCB 510-56...
