Oops, this is gonna cost $$$
/ Oops, this is gonna cost $$$ #1
MotorSeven
Elite Member
NE TENN (Hancock Co)
Kioti DK40SE Hydro
I know what happened even though i didn't know that it was possible. I was grubbing out a possible house site(wife still is undecided{sigh}) and i had the box blade down & tilted slightly forward. I pushed some brush into a small creek bed & up the other side. I forgot to raise the box & it caught as the front of the tractor went up the bank. I reached down & moved the top link lever & the box came all the way up, then flipped on end smashing into my tail lights & jamming in that position. The top link, caught in the bind, bent. Drove it back to the house while listening to every "shift" as it grated on the tail lights.
It was interesting trying to get it un-clustered...removing pins, jumping back as the 7' box slammed into the ground.
New tail light assemblys- $140
Top link- still waiting for a $
Learning experience- not priceless because i haven't figured out how to keep this from happening again:mad:
So, when i get it all back together, i am going to weld something somewhere to prevent further embarrassment:cool:
Pic's for your enjoyment:
/ Oops, this is gonna cost $$$ #2
Wow.
It must have caught something pretty hard.
I'm still trying to figure out how it flipped up that high with a toplink attached.
/ Oops, this is gonna cost $$$ #3
Yow ! Thanks for the pictures, but i can't say theres any enjoyment in looking at them. I'm also puzzled at how the BB flipped up that far. At least it wasn't worse?:rolleyes:
/ Oops, this is gonna cost $$$ #4
Wow! That's pretty interesting. Looks like the cylinder just couldn't handle it. How's the rest of the 3 PH? Did the box scraper linkages also get damaged?
Not sure how you'd prevent it (other than don't do that no mo). Maybe a heavier top cylinder.
No, no damage to the 3 point or the BB....at least none that i could find. My dealer has seen this with a manual top link, i am first with a crumpled hyd link:(.
RD
/ Oops, this is gonna cost $$$ #6
Yikes! Bummer. On the positive side (Yes I am one of those annoying "on the positive side guys"), no major damage.
Nice looking place you have there.
/ Oops, this is gonna cost $$$ #7
Well if thats all the damage you did,none to tractor,looks like you are lucky,you need to put same brand hydro top link back on,it coulda saved you from worse.
Oh yeah,forgot to say,go rent you a dozer.
Ha, check my signature....it's broke too(I swear i had nothing to do with it!), just waiting for the $ to replace the spring track tensioner & housing.
RD
/ Oops, this is gonna cost $$$ #9
Thats a good little dozer,I used to try and run one of them about 25-30 years ago,the word here was try.
/ Oops, this is gonna cost $$$ #10
I have not managed to flip up the boxblade as dramatically but I did manage, in a similar fashion, to put a slight bend in my hydraulic toplink while using the boxblade and backing into an unseen but large rock. Luckily for me the toplink still works and I'm the only one who notices the asymmetry.
The stealth rock was dug out of it's hole, severely punished, and then waterboarded (dumped into the ocean). That'll teach it.
/ Oops, this is gonna cost $$$ #11
No enjoyment seeing the pics but thanks for sharing them. You have no doubt saved someone else from the same problem. Its amazing how strongly and heavily built tractors are and how you can tear parts up in a quick minute.
Warhammer
Kivel Quick Hitch Mini Skid Steer Attachment (A61572)
Kivel Quick Hitch...
UNUSED WOLVERINE QUICK COUPLER 8 (A64281)
UNUSED WOLVERINE...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A59823)
2017 FORD F-350 XL...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
Cat CB24B (A60462)
Cat CB24B (A60462)
Pull-Behind Spreader Tractor Attachment (A61572)
Pull-Behind...
