Hybrid Power Trac
/ Hybrid Power Trac #2
I like how some environmental writers can eviscerate facts with just a few words.
"Currently, all functions on the Weyhausen loader’s equipment side are still hydraulically driven. The next step will be to power the loader totally by a full hybrid drive system, delivering eventual emission-free operation."
Sure, magically that diesel is going to have no emissions because it is part of a hybrid drive. This hype is similar to the people that claim a plug in hybrid car can get 80 miles to the gallon, conveniently ignoring the energy used to recharge the batteries when the vehicle is plugged in.
/ Hybrid Power Trac #3
I agree that marketing guys can really hype, but the plug in hybrid does have an advantage since electrical generation from a stationary power plant is much more efficient than from a portable engine. I think 2.5 times is about right. The big trouble with hybrids is battery life and initial system cost. Better batteries have been the potential solution to electric cars for a century, but potential is still the right word. Also a battery holds about 1% as much energy as gasoline of the same weight.
They are not forgetting the energy form the power grid, it's just a lot cheaper.
/ Hybrid Power Trac #4
I don't think those figures are correct. Electric utility generation only converts about 35% of the energy from the fuel into electricity--a figure that I think is comparable to modern diesel engines conversion of btus in the fuel to usable power to the road.
I think the advantage of the stationary power plant is in the environmental controls that can be applied to large plants to reduce emissions as compared to doing it in small engines.
/ Hybrid Power Trac #5
Modern power plants with combined cycle (turbine run by natural gas, with steam generated by waste heat to run steam turbine) run above 60%. On a portable system you have to include the transmission loss, cold start running (which is much reduced by plug in hybrid) and not running the engine at optimal speed and power. With the plug in hybrid you can keep the engine at the most efficient engine speed and load during the charging and then shut it down. Since an engine on a normal vehicle is sized for acceleration horsepower it is not run at it's most efficient speed most of the time. That 35% is the best efficiency, not the average. There are many factors and variables, but this is where they get the claimed improvements.
I agree with your comment on pollution.
/ Hybrid Power Trac #6
Railroads are already using hybrid yard switchers.
Diesel electric locomotives have electric traction motors on the axles. They are conventionally driven by a diesel prime mover powering an alternator or generator to supply juice to the traction motors.
In the hybrid, a much smaller diesel is used to recharge a massive battery bank. The battery bank actually provides power to the traction motors. The diesel starts and stops automatically and runs at a constant speed when it is charging. It is much easier to control emissions on an engine that runs at a constant speed/load than it is to control them in variable speed/load operations. Hence, lower emissions to get the job done, but not zero emissions as some people would have you believe.
/ Hybrid Power Trac #7
In my post I was thinking of, and referring to, a coal or nuclear fired steam plants which are the dominant source of electricity in this country. I agree with your comment about turbines fired with natural gas and fitted with a secondary system to improve overall efficiency. My understanding is that such secondary systems can, in theory, be fitted to mobil applications but are not because of size, weight, and economic considerations.
/ Hybrid Power Trac #8
Dear Bob999,
Your numbers are accurate for the older generation of plants, but the current (80's onward) plants have efficiencies well over 35%, approaching 50+% in the best coal fired plants. You are right that nuclear powered plants are for the most part less efficient, as they run at lower pressures (and therefore temperatures, and therefore are less efficient).
Partly the improvements are improvements in design with better attention to heat flow, and partly they are due to scale. The largest plants now are in the gigawatt range. Additional heat recovery stages can improve the onsite efficiency well above these values. Technologies such as fluidized bed burners add another 10%, and integrated gas combustion cycle plants exceed 60%
Unfortunately, mobile internal combustion engines just aren't that efficient for a host of reasons that include not running at the optimal speed, varying load, startup losses, poor heat recovery/displacement, and, importantly, scale. They are just small.
One does have to weigh transmission losses of electrical power against the generation efficiency, but even so, it puts electric vehicles ahead, and way ahead, if one is considering environmental emissions per mile. Even adding in battery costs/disposal/recycling fees, you are still ahead.
Now we can have a serious discussion about just how much energy you could store in a battery pack on a tractor relative to the work needed. (Short answer, foggettaboutit). For forklifts, maybe, for Power-tracs....not the way I use one, which is high throttle, ripping along, but, as in most things, YMMV.
Further reading at
Carbon flow
US National Energy Flow
(Highly recommended diagram of how energy is used in the US.)
All the best,
Peter
/ Hybrid Power Trac #9
Pony,
I have done a little reading on some of the EV conversion sites and I think, for some, an electric Power Trac could work. I use mine commercially and , except for field mowing, I don't think I actually put more than 2 or 3 hours of run time on it during the day most of the time. It seems that the electric motors are very compact so after removing the engine and fuel tank, there would be lots of room for batteries. And unlike a road vehicle, where weight is a negative, it would be good in the tractor. I sure like the idea of a quiet PT. Might be a fun experiment if someone came across an old PT with a blown engine.
/ Hybrid Power Trac #10
An electric/hydraulic PT would be quite a challenge. I think finding an affordable DC motor of the size required to drive the pumps might be difficult. It would have to be fairly large. I don't think there would be enough room left for a decent battery bank. At least a 48 volt system would be required, but even that would probably be too low. 96 volt and 120 volt DC motors are available, but working with DC systems that high can be shockingly painful (pun intended).
An AC motor would be preferable, but then a high capacity inverter would be required. They aren't cheap, and they aren't small. Adding one to the mix would seriously increase the complexity of the conversion. And you still have the shock hazard.
Still, I would like to see someone attempt the conversion. It would be, umm, quietly entertaining. :rolleyes: ;)
/ Hybrid Power Trac
So what would be more efficient. Electric wheel motors and pto pump, or on big motor driving the master hydraulic pump? Could you get motors small enough to be wheel motors yet strong enough to move 2000 lbs.
I assume the consensus is the 425 would be the ideal platform given use times vs size?
/ Hybrid Power Trac #12
If you don't do mowing, I think you might have a shot at it, although 3 hours of run time is a long time for battery power, especially if you are trying not to deep discharge your battery pack.
You would have a great shot at really really lowering your center of gravity.
I can put you in touch with people that I know who have done everything from electric shopping carts to electric couches (big hit at Burning Man) and cars.
I am sure that quiet would be worth something to some of your customers. Let us know how much extra they were willing to pay. :)
All the best,
Peter
Pony,
/ Hybrid Power Trac #13
Electric motor hands down. And it would be worth it to you to replace your hydraulic power attachments in favor of electric motor driven attachments. Large digital controlled motors have efficiencies in the high 90s. See Electric Motors and Guide to buying electric motors
In the horsepower range that we are talking about efficiencies are in the 90% efficiency range, against 72% for hydraulics (85% pump x 85% motor).
Motors are no problem. Most electric cars use two, one on each wheel. With four, you would be ripping.
Now you are going to keep this clean, and dry, right? :)
Given your slopes, you might want to consider sealed AGM batteries for the 45 degree side slopes.
I think that green or red doesn't matter, it just changes the cost and the resulting performance.
All the best,
Peter
/ Hybrid Power Trac #14
The trouble with electric wheel motors is the needed controller. To be efficient, it would have to be some sort of chopper or pulse width modulator. (I'm assuming a bit here. I haven't looked into it.) That would let you get rid of the complicated drive pump, so it would be a trade-off.
You would probably want to keep the hydraulic steering, but you wouldn't want the pump running unnecessarily. That might require some tricky engineering. An accumulator with a pressure switch might work.
The more I think about it, the more I would like to see someone give it a try. Just not me. ;)
/ Hybrid Power Trac #15
Since you guys are talking in the theoretical, over my head, I thought I'd post this example of a gas-generator powered, electrically driven garden tractor conversion. Note, however, that it was done by a guy who designs/builds the controls for a living. This is not a "shade-tree engineering" type of mod, IMO. So, that leaves me out, for sure... :D
Simply Shocking?
/ Hybrid Power Trac
So you both brought something up that I had not considered...
How do you keep the controls and motors clean in such an environment? If you seal a motor the housing would have to be huge to dissipate the heat, and reostats really hate dirt of any kind...
You guys think the hypothetical electric PT platform would be best suited to the 425 chasis?
/ Hybrid Power Trac #17
The PT uses four hydraulic motors, one at each corner, in a series/parallel configuration. As you all know, standing still, if you turn the steering wheel right, the front right wheel rolls backwards while the rear right wheel rolls forwards. While that is going on, the left front wheel is rolling forwards while the left rear wheel is rolling backwards. How are you going to replace the hydraulic motors with electric motors and achieve that same motion and not spend a gazillion dollars doing it? It would require some very expensive controls.
/ Hybrid Power Trac #18
More to the point, how are you going to brake it? :) When the PT is still, the tram pum is centered, and I think there is a bit of a fluid path from one motor to another, which allows the wheels to move in your above scenario. You could do the same thing with electric motors, just by open circuiting them, but you would then have a roll away issue. You could also short circuit them and get considerable rolling resistance. It would not, I think, prevent the static turning scenario, so I think I just answered the question as I typed. :cool:
The real problem is braking. You could brake electrically, but it would complicate things. Drum or disc brakes could be added, but the PT's treadle control system does not lend itself to a foot brake, except for those among us with three feet. :p
/ Hybrid Power Trac #19
Guys, it really isn't that bad.
Rheostats are so last century. :) More to the point, they are horribly inefficient. Use a PWM controller, so, "Yes", you need one of those pulse width modulated controllers. In the same vein, you use the electric motors to brake and reverse, which is trivial, plus you get all of that energy back. Good news is that the controllers are widely available for car conversions. (I was amazed when my electric car buddy showed me his home brew design for his race car; it was a one million watt controller, but if you do the math, that would be what you need. A PT is just slightly ahead of golf cart power, way behind cars. And yes, Virginia, the controller is totally water proof and sealed. Ditto the motors, but I don't think that they are submersible in the normal configuration. With a little engineering, anything is possible.
As MR brings up, you will need to have a computer controlled differential, or wire the motors diagonally, but, again, the commercial car controllers do allow for it. You will need a new steering controller. (If you raid it off of a Prius, you would get some snazzy on wheel controls.)
Seriously, it might be a step above grandpa's shade tree engineering, but not much. There are lots of sites devoted to electric conversion.
There are even members amongst us with race records for electric vehicles... (No, not me.)
And no from an efficiency perspective, you don't want to have a hydraulically driven tractor power by an electric pump, although it might be the low cost solution and the easiest to implement. If you aren't religious about it, it is by far the simplest. The motor could easily be activated and governed by the hydraulic pressure in the various circuits. This is definitely something grandpa could do.
All the best,
Peter
/ Hybrid Power Trac #20
Dear Bob999,
Peter,
I would be interested in the source of your information about current producing power plants.
The following quote is taken from the Department of Energy web site:
Department of Energy - Electric Power
"Research is also underway to increase the fuel efficiency of coal-fueled power plants. Today痴 plants convert only a third of coal痴 energy potential to electricity. New technologies in Energy痴 Fossil Energy program could nearly double efficiency levels in the next 10-15 years. Higher efficiencies mean even more affordable electricity and fewer greenhouse gases."
2007 30ft. Regal 30 Express Cruiser Boat with 2010 Vantage T/A 33 Ft. Trailer (A64557)
2007 30ft. Regal...
2007 International 4300 S/A Dump Truck (A64556)
2007 International...
2014 Chevrolet Express Shuttle Bus (A64556)
2014 Chevrolet...
UNVERFERTH 2755 SEED RUNNER (A64278)
UNVERFERTH 2755...
LOT OF TRANSPLANTER PARTS (A64278)
LOT OF...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
Here are some similar links:
  • Article
  • Type: Trucks & Vehicles
Replies
0
Views
106
  • Article
Replies
0
Views
116
  • Article
Replies
0
Views
114
  • Article
Replies
0
Views
96
