Hybrid Power Trac
/ Hybrid Power Trac #21
My apologies for not citing references. And I wouldn't want to leave you with the impression that the Feds were consistent. :)
I do think that the DOE quote below is a little dated. Economic pressures have been pushing plant efficiencies upward, as has the general increase in scale in the industry.
My other numbers were from the DOE.
Coal and efficiency
and
IGCC
When all else fails, there are always google, and wikipedia... :)
The addon technologies are things like IGCC that I mentioned, and magnetohydrodynamics (adds upto 40% in efficiency, at an unknown capital cost unknown running costs.)
Hitachi recently commissioned a standard plant at 50%. I'm not claiming it is typical, just what can be done with standard technology. You could also check out the Danish plant, Nordjyllandsv誡ket, which is running at 47%.
One of the biggest improvements for traditional plants has been the use of finely pulverized coal for more complete combustion, but remember that the absolute heat (Carnot) efficiency is 77%, and you need non-heat technologies, such MHD to get better than that.
Sorry for not being clearer the first time.
All the best,
Peter
Peter,
I would be interested in the source of your information about current producing power plants.
The following quote is taken from the Department of Energy web site:
Department of Energy - Electric Power
"Research is also underway to increase the fuel efficiency of coal-fueled power plants. Today逞エ plants convert only a third of coal逞エ energy potential to electricity. New technologies in Energy逞エ Fossil Energy program could nearly double efficiency levels in the next 10-15 years. Higher efficiencies mean even more affordable electricity and fewer greenhouse gases."
/ Hybrid Power Trac #22
Coal and efficiency
and
IGCC
Peter, I looked at the two links to DOE and it appears to me that both refer to ongoing research and development--not on-line power plants. I do agree that fluidized bed is a mature technology and installed in a number of power plants. I didn't find a citation of efficiency for operating fluid bed plants.
The Hitachi link cites a 44% figure for one plant in Japan.
In any event I agree with your observation that the pressures are for higher efficiency and that technology exists to achieve higher efficiency. Perhaps where we still see things differently is what is in being today. I focused my comments on what I understand the installed base is achieving and I think you are focusing your comments on the leading edge.
/ Hybrid Power Trac #23
Bob999, I agree with your comments above and Peter's statement. My general experience is that a mobile automotive system can never achieve the efficiencies of a fixed system or even a very large mobile system like a ship. The extra equipment (basically many more stages of waste heat usage) are just too expensive, large and heavy to make sense. Electric system perform well over a large range of power, load and size, making them a good choice for automotive systems. So I think we are all converging our concepts.
Just to change the focus, right now no one pays road taxes on electricity. I expect governments will get around to that in a few years. This will of course reduce the advantages of electricity. "We just need a better battery." Quote from Thomas Edison
/ Hybrid Power Trac #24
I'm pretty sure a simple conversion with a couple of batteries and a DC motor in place of the existing engine would work just fine for all of those little jobs that account for about half of the times I start my PT - ya' know, the ones where I'm just moving stuff around - firewood, building materials, fertilizer, whatever.
I don't think it would work so well for mowing a couple of acres, plowing snow off the driveway, or drilling post holes all day, but for the short jobs I think electric would work fine.
Someday Real Soon Now, maybe I'll find a really cheap PT with a blown engine, along with a donor golf cart... OK. Maybe not me, but somebody could do it.
But there is that local tractor dealer that's been trying to sell that old 418 for over a year now. Maybe one of these days they will decide it's not actually worth 75% of a new 422. Maybe a really hot place will get really cold...
/ Hybrid Power Trac #25
One thing I haven't seen suggested is to use a DC motor to power the pump, whatever batteries that are appropriately sized and affordable (ha!) and an IC engine (maybe mini-turbine) to provide constant output for 30% or so of most operations.
Then use a control system to start and stop the engine/turbine as needed.
For mowing, though, this would be pretty inefficient if full power is needed because you have the loss of power generation at full throttle. The possible energy saving would be for times when using 30% power or less with stored energy being used for the extra needed for short times when lifting, starting to move, digging, whatever.
For the same money, or less, you could probably hire a live-in equipment operator with all the stuff needed for all your work.
/ Hybrid Power Trac #26
Theoretically, DC motors would be fine, but the market is AC and AC control, i.e. PWM controllers.
If you are good at finding salvage parts, you have a chance at it, but...
Yes, it is not going to be as efficient as a geared connection at high output, but don't forget hydraulic losses. Diesel electric trains do just fine, without direct connection.
And now, back to our regularly scheduled broadcast.
All the best,
Peter
/ Hybrid Power Trac #27
Time to 'fess up, I guess. I have an old PT180, with blown engine, a Briggs Etek motor and a pwm controller - all sitting deteriorating because I haven't put them together. I plan to run the hydraulics with the electric motor. It won't be efficient, but the objective is quiet and effective for an hour at a time. Since I have some deep discharge 6V batteries, I'll probably use those to start.
Tell me why it won't work.
/ Hybrid Power Trac #29
Put it together. Can you have this done by March 1? We are impatient.
Free advice will be given here as needed. Some of it will be worth more than you paid for it.:):):) A lot more.
Oh, I would put a 2 inch receiver hitch on the back so you can carry extra batteries if needed. Just a thought.
Good Luck.
/ Hybrid Power Trac #30
Unless I add to the advice, in which case it might be worth less than you paid for it. :):)
/ Hybrid Power Trac #33
Check this out:
Inside Bruce Crower’s Six-Stroke Engine: AutoWeek Magazine
This engine uses the concept of capture some of the energy normally wasted through the cooling system.
In my post I was thinking of, and referring to, a coal or nuclear fired steam plants which are the dominant source of electricity in this country. I agree with your comment about turbines fired with natural gas and fitted with a secondary system to improve overall efficiency. My understanding is that such secondary systems can, in theory, be fitted to mobil applications but are not because of size, weight, and economic considerations.
/ Hybrid Power Trac #34
I think an old electric forklift would provide all the motors and hydraulics you need for this project.
So what would be more efficient. Electric wheel motors and pto pump, or on big motor driving the master hydraulic pump? Could you get motors small enough to be wheel motors yet strong enough to move 2000 lbs.
I assume the consensus is the 425 would be the ideal platform given use times vs size?
/ Hybrid Power Trac
A friend of mine is an electronics wiz, not much of a mechanic, but he as come up with an interesting prototype design for boosting mileage using hydrogen.
As he explained it, you take the excess amperage available from the alternator (lets say it is free energy) then he an a friend came up with a different sort of metal to do the hydrogen breakup (am I beginning to sound like this is way over my head). A metal that is cheaper and supposedly more efficient (this is where he came into the project). Then you feed the hydrogen back to the engine, reducing the gas needed.
Initially it is only working on normally aspirated engines carbed (not fuel injected). He brought it to me thinking one of my vehicles was carbed but now all I have is fuel injected.
Wonder if it will work, he says it does... All seems like snake oil to me....
/ Hybrid Power Trac #36
There is no such thing as excess (free) energy from the alternator, unless it is a permanent magnet excited, shunt regulated alternator, which produces power whether it is needed or not, thereby wasting fuel part or most of the time. Most vehicle alternators are field excited and regulated, and don't put out any excess energy. Every bit that is generated requires engine power and a bit of fuel to do so. When the regulator dials back the amount of power being produced by the alternator, some amount of fuel is saved.
There are all kinds of hydrogen injection schemes being foisted off of the public these days. None of them have been shown to actually produce any useful amount of power with an accompanying fuel savings. Remember, generating hydrogen by breaking down water through electrolysis requires more energy than it produces -- always.
Point your "friend" to "Run Your Car On Water" Scheme Could Leave Consumers All Wet
Better yet, point his friends to it.
/ Hybrid Power Trac #37
Carl,
I'm with SnowRidge 110%. There is no such thing as a free lunch. This is 100% snake oil, at best he is fooling himself, at worst...
The alternator functions as SR describes, and it has been covered in other posts here. If the alternator put out excess energy, you would boil the water out of your batteries. (Which does happen when the regulator fails, but not otherwise.)
My short advice is if you hear the word hydrogen, and it isn't dihydrogen monoxide, run for the hills.
All the best,
Peter
/ Hybrid Power Trac
glad I sold my car with the carburator. I like this guy enough to have trusted his input...
/ Hybrid Power Trac #39
I never saw it, but heard of a boat that took fishing parties out on Long Island Sound - running on water. Nearly every trip, the engine would shut down. The skipper would grab a bucket & funnel and dump a couple of buckets of water into his fuel tank. What he had was a very high fuel pickup, just for the scam, and floated the fuel up to the pickup with water underneath. I never heard what happened to him if he encountered rough weather and sent a slug of seawater to his engine.
He didn't make any money selling water-fuel technology, but must have had a lot of fun.
/ Hybrid Power Trac #40
There are some ongoing discussions here on TBN regarding the hydrogen topic. There are some links in there to a few websites as well.
There are two different schools of thought on this.
1. Free energy. Consensus is pretty much 100% that there's no such thing.
2. More efficient fuel burn. This one is intriguing. A few of the sites suggest that by adding the gas (which is not pure hydrogen) to the air stream it helps the gasoline burn more efficiently. One site gives the plans away for free with a build list, so the guy doesn't appear to be dishonest.
Anyhow, it is fun reading and I don't want to start the arguments about whether it will work or not.
2020 BOBCAT MT55 STAND ON SKID STEER (A63276)
2020 BOBCAT MT55...
2007 Sterling L9500 Fuel & Lube Y22693 (A62613)
2007 Sterling...
Wolverine TCR-12-48H Skid Steer Trencher  (A62679)
Wolverine...
2014 FORD F-350 SUPER DUTY (A65643)
2014 FORD F-350...
2009 Wilson Hopper Bottom Trailer (A66285)
2009 Wilson Hopper...
2023 Stearling Trailer (A60352)
2023 Stearling...
