Tractor-powered Log Splitter on B7100HST?
   / Tractor-powered Log Splitter on B7100HST? #1
jas67
Central PA
Kubota B7610 + Kubota G1800-S
   / Tractor-powered Log Splitter on B7100HST? #3
Any comments on using the following on my B7100HST?
Harbor Freight Tools - Quality Tools at the Lowest Prices
It is rated for a max pressure of 2500PSI. The B7100HST relief valve is set for 1500PSI. Will i still be able to split logs? I'd like to avoid having yet another small engine that only gets used once or twice a year.
Thanks,
Jay
I downloaded the owners manual. It has a 4" dia hydraulic cylinder.
If you do the math Pie x radius squared = area of cyl.
3.14 x 4 = 12.56 square inches
then area times pressure = force
12.56 X 1500 = 18840 pounds of force
18840 divided by 2000 = 9.4 tons of splitting power at 1500 psi.
Plenty of power to split most wood.
The small gallons per minute output of the b7100 hydraulics might make the splitter a little slow to run.
   / Tractor-powered Log Splitter on B7100HST? #4
Yeah, just do the simple pi math thingy...sheesh
   / Tractor-powered Log Splitter on B7100HST? #5
I was all set to make a splitter for my B7100 last year. I did the math for power and speed and tried to come up with a decent compromise on the cylinder size. Then I picked up a 6 ton electric splitter for $125. It seems to work fine for my purposes and takes up very little space. I split a load of hickory last fall. The wood pile is a lot tidier now a days.
   / Tractor-powered Log Splitter on B7100HST? #6
running log splitters off old/small tractors is not a good idea. The stroke speed is SO slow that you'll need to be a very patient person.
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
1985 International X Con Semi (A50514)
1985 International...
2019 FORD F450 TOW TRUCK (A51222)
2019 FORD F450 TOW...
New JMR Skidloader Boom (A50774)
New JMR Skidloader...
2018 VOLVO VNL SLEEPER (A51222)
2018 VOLVO VNL...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
