Chains Chains on front tires only VS. rear only
   / Chains on front tires only VS. rear only #31
Yes it will ride rough!
Kinda hopity-hopity--
Why not look at studs? many snow contractors around here use them.
Bigger studs are available for tractor tires tha you see on cars plus you can keep them on all year long.
I know of one contractor that has over 1300 hrs on his and ALL his time is on asphalt surfaces as well most of his drives are very hilly and short= much stop and go.
Also he does about 3 miles on a paved highway to service his clients.
can you tell me of a supplier that carries studs for tractor tires for a tc45d
   / Chains on front tires only VS. rear only #32
Yeah it seems like something like this would work fine for what I need which is basically somthing to give me traction when the driveway is glare ice so I can get out there & sand it without getting killed.
Which ones did you order??? I'm thinking the off road or the next ones down.
Sorry for the late reply Bill.
I went with the "Low Profile C". I'm just putting 50 in each tire to see how they do over the next year. If they hold up then I may put more in next winter.
I still think the chains are more useful in the bad stuff. I have studs on my SUV but when it's bad I drive my F350 with V-Bar chains.
   / Chains on front tires only VS. rear only #33
   / Chains on front tires only VS. rear only #34
You already have the rear chains. How much would spacers for the rears cost versus front chains?
   / Chains on front tires only VS. rear only #35
   / Chains on front tires only VS. rear only #36
I have a 2oo6 Kub L28oo. It seems to have lotsO traction plowing in the snow, even when it is deep. However using an angel plow when making the first plow after a heavy storm keep a line is tough. Also when re plowing the piled up snow on the berm in order to give the next new snow someplace to be moved to also is a tad difficult to keep a line on. I now lift the plow half way up the depth of the berm n just plow it twice, so more time n fuel/ware an tare.
So I also am considering adding chains to only the front, more so for steering vs additional traction. I keep my hoe on the back all winter/the time so the rear set of wheels seems to get plenty of traction due to all the weight. However, with only a 28hp motor that probably does not weigh that much, thus not keeping the front wheels from spinning in the snow n ice I suppose compared to the rear.
I also have AG tires on all 4 corners that still have lots of lug remining.
I like the one person's suggestion to put studs in the front tires. I may check into buying a set of both wheels n stud tires. Than just change them out in the fall n spring when the loader bucket mounted is remounted in order to lift the tires off the ground for easy change over (I remove the loader bucket for snow plow lifting and replace the bucket with a 4 foot + - wide by 6" square piece of box steel mounted on both the end of the loader arms and hydro ram ends thinking this will help keep the ends from twisting and being bent back if only one arm should take big hit sometime, see below foto).
   / Chains on front tires only VS. rear only #37
6 year old thread in case you were hoping for a response. I run 2 link v-bars on an L3400 and have had really good luck with them.
   / Chains on front tires only VS. rear only #38
I wouldn't stud tires unless I had a spare set of tires and rims to swap out after winter - I'd go chains - way cheaper. I run 2-link v-bar ladder chains on my L4200 front wheels only to push my snowblower around. I'm not worried about stressing the front end since load requirements are fairly light - much less that those plowing a field anyway, and my tractor is designed for that. You move slowly in the snow, and the fronts are just assisting whatever traction the rear (turfs) can muster. My chains were about $110 for the pair from tirechains.com.
   / Chains on front tires only VS. rear only #39
I have been running chains on the front tires of my B7800 for many winters now. In order to accommodate the chains I have to reverse the rims of the front wheels. Last spring I found that several of the right side wheel's bolts had unscrewed from their wheel-some partially and 2 completely had fallen out. I bought new bolts and now check all my wheels regularly. I have no doubt it had something to do with the chains and reversing the wheels
   / Chains on front tires only VS. rear only #40
After all the years think I would chaco out how old a topic was, thnnks for cluing me in......
The blower on your Kub looks like it does a great job. My Kub probably could only travel with the plow up 100% in that deep of snow (if that). How deep was that and U live in western PA n get that much snow? Lake effect area I suppose? I live in the NE corner, 9o miles west of NYCity in the Poconos.
Sorry I do not know what link v-bars are. Have a foto by chance?
2013 Nissan Juke SUV (A59231)
2013 Nissan Juke...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
2019 Dodge Charger Sedan (A59231)
2019 Dodge Charger...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
2015 Ford F-350 4x4 Service Truck (A59230)
2015 Ford F-350...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
