i have a Hesston 90-100 DT and a Kubota 3710 HST.
Hesston front tires are same size as Kubota rear tires. So Yeah, I use the same set of chains on both tractors. The Hesston is an awfully big sunuvabiotch and when I am chained up, it is usually to pull some plow truck out of a deep ditch on a back woods road somewhere or to climb an icy road up the side of a mountain.
FWIW, I use to use the Kubota for driveway plowing duties, with a fixed position 6' snow plow. The drive is 1/2+ mile long and changes elevation 300' over its length. Without chains she got away from me on ice a couple times and or would not climb the icy road. I purchased a set of front chains because they were cheaper and a lot easier to install. I was generally careful about not shock loading the drive train, but was pretty sure plowing up hill was putting a lot of stress ONLY on the front drive train. After several years, maybe 5 or 6, a right front wheel bearing just completely came apart......
I replaced the bearing set and have not run the front chains on that tractor, but maybe 3 times in the last 6 years. I think if you are a careful operator you can get ways with doing it on flat ground............ in hindsight, pushing a plow, uphill on icy pavement with front chains only, was just NOT prudent.
