winter tires
/ winter tires #1
mike123
Saskatchewan,Canada
Toolcat B 2004
I went a tire shop today to get the LT 235 75 15 in a michelin ice latitude. The most knowledgeable guy told me there is no way those tires or any other winter tire in a 15 inch is going to take that load?
He said I must move in to a 16 inch and 10 ply.
Anyone have any suggestions what to do?
Thanks Mike
/ winter tires #2
Take what load??? Im lost, dazed, and confused..
Brian
/ winter tires #4
the weight of the toolcat 8000 lbs
8000#...Really?..... Last year I used LT235/75-15's and I put them back on for this coming year just yesterday. I'm carrying about 700# of ballast and a 800# blower and I've not had problems. The single max loading for these 6-ply tires I'm using is 2000# apiece.
Having said that, if I were to do it all over again I would go to LT225/75-16 (Load Range E/10-ply) tires just for added margin. I would purchase 16" trailer wheels (6 on 5.5" bolt pattern...one of the most common) to save some $$$. Go to the trailer parts store...not necessarily the tire dealer for those. I used white modular trailer wheels for my 15" LT tires and they work super.
This link:
Tire Tech Information - Diameter Comparison of Light Truck Tire Sizes
will take you to TireRack's tire dimension page. There aren't too many size options for 16" tires that would seem to be Ok with the Toolcat height-wise; however, LT225/75-16/E's are very common and that's what I'd try if I did it over. Maybe next year I will depending on this year's performance.
/ winter tires
Thanks alot.
well 8000 with blade and balast.
Yes I am thinking of going with 235 85 16 (nokian lt )_but I am trying to find out if they will fit and how they will affect the steering.
Thanks Mike
/ winter tires #6
The subject of tires comes up often on these forums. It'd be helpful if you could post your results with whatever tire you end up with.
/ winter tires #7
That's interesting....
I have been running the 235 75 15's for what will be my fourth season with no problems. Does the B series weigh less than the other series?
I have 800 lbs of ballast, and a 1000 lb Blower on my TC's.
/ winter tires #8
New new 5600 weighs 5,500 lbs dry and empty. Load range E would give you stiffer sidewalls and little more puncture resistance. With no ballast, me, fuel, and the blower (72", SB200) I estimate my TC to run at about 6,760 lbs.
DEWFPO
/ winter tires #9
How tall are the 235 75 15's when mounted and aired up? I'd like a set at 29 or even 30 inches if it is possible. I went with the 27 inch bobcat tires cuase my dealer said the bucket wouldn't lay flat with the boom down. But for snow I don't care because it will have a blade, pusher or blower on it.
My 5610 weighs 7040# with ballast(750#) 66" bucket and an 8 foot protech compact snow pusher chained on.
/ winter tires #10
It really depends on the manufacturer of the tire. Nominally 235/75x15's should be 28.9" at proper inflation (for the vehicle) but some makes will be lower or taller.
DEWFPO
/ winter tires
Yes someone will hopefully chime in who has used taller tires or even 16 inch rims
/ winter tires
Tim I wanted to go this route but I only have 3/4 of an inch clearance in the tire well right now with AWS on.
/ winter tires
Tim
What exact tires are you useing? I cannot find a winter tire that will take the load of the tool cat and fit in the tire well. When the AWS is on I only have 3/4 of an inch clearance now.
Thanks Mike
/ winter tires #14
It is the first week of January, and we've had about 140" of snow so far (It is dry snow, or "champagne powder"). I promised a report on the Latitude X-Ice tires. So far, so good. I have never been stuck. The closest I came was trying to clear 6' of compacted snow that our street plowers left on the downhill entry (12% grade) to my driveway. I was blowing down hill and slipped trying to back up the hill. I took another bite into the bank, got some new road under me, and backed right out. I've got about 400 lbs of sand in the dump bed.
I was gone for two weeks over Christmas, so when I got here yesterday there was 30" of snow on my driveway areas. The set up works great. I had to keep it slow, maybe 1 mph, to keep the motors from being overwhelmed, but it was throwing the snow a good 40'. The tires never were a problem. My set up is a 5600D, high flow, with a 240 blower.
I do keep a set of 4 chains in the bed, just in case, but they are still unopened. I've used the machine 5-6 times for snow so far this season. I'll post again on these tires if I have a problem or at the end of the season. My neighbor with a Kubota CT is planning on trading his machine in for a Toolcat. The attachment changeover is his stated reason.
/ winter tires #15
Not for nothing, but all this is moot without PICTURES!:mad: The pic ****** require pics. Colorado, Tool Cat, Snow, Snowblowers etc... etc... all add up to awesome pics, I would presume?
Please feed the ******......:D
/ winter tires #16
Mike123,
I'm at the office at the moment but if memory serves me they are Mastercraft 235/75/15's. I think the "model" is Courser or some facimile. The are studded and while the really steep upslope drives (over 40%) typically need chains on the front, most of the time I only run the chains on the back.
This year I switched to a much better hardened cross link from White Mountain Chain in ID that appears to be wearing far better than my previous bulk cross link. I did use some of the old bulk cross link for the front chains and have already rebuilt some of the front chains that had the old stuff. I won't be buying bulk chain from the old company anymore.
/ winter tires
thanks timm
I looked at alot of tires this year and couldn't find the load recommended.
I finally fould some great tires, nokian HP 235 75r 15 but they won't fit on the rear. They hit the inside wall when AVS is on.
Mike
/ winter tires #18
thanks timm
Mike
Mike,
The tires are still available as I had to replace two of them after tearing out a side wall on one of the commercial sites on or about the 15th of December.
/ winter tires #19
One of our fellow toolcatters wanted some photos of snow blowing and tires. Here they are. This was accumulation of 36" of snowfall over 10 days that settled down to about 22" by the time I got back up. You can see the X-ice tires. This snow was pretty dense, but not wet. This machine is a joy on this task.
/ winter tires #20
Mtngrancher,
Nice photos!
That looks like one of my accounts!
Pallet of Chain Slings (A61166)
Pallet of Chain...
Railroad Maintenance Machine (A61570)
Railroad...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
2022 Behnke Trailer (A60352)
2022 Behnke...
832653 (A61165)
832653 (A61165)
2006 FRAC TANK 500BBL WHEELED (A60736)
2006 FRAC TANK...
