Lights, Camera, Action
/ Lights, Camera, Action
RussMan With each light, one rubber gasket and a wiring pig tail to plug into the light cost me around $30each so there shouldn't be much of a differance where your too.
Philscbx Cool handle. Do you ride a CBX? They are NICE bikes :D My daily rider is a GL1800 Wing but I haven't seen a bike I didn't like. Enjoyed reading your story. I'm not a hunter either but do enjoy snapping pictures of things in the wilderness. I also like the Miller gear. Although my main business is in automotive I do a good bit of machining and fabrickating. You can't go wrong with that new Mig you got there. Very nice machine.
I got the Miller 702 plazma. Miller Dynasty DX200 with the "Crazy Cart" I designed and built for it. Got the Millermatic 251 with aluminum spool gun and the mobile Miller Trail Blazer 302 with custom trailer I designed and built. Good thing I don't weld for a living :rolleyes:
Thanks for your reply and your kind words. Enjoyed it!
/ Lights, Camera, Action #32
/ Lights, Camera, Action #33
I am still looking for the one in the $30-35 range. does anyone have a link to that light?
Your not going to find a quality LED worklight for $35. Clear led are much more money than the coloured led in signal lights. On top of that LED worklights are still relatively new. Typical LED worklights by a major manufacturer are still in the $100 area, unfortunately. I wouldnt buy the one you linked to. Its only 350 Lumens. http://www.vehiclelight.com/970988.html has 2 times the lumens for not much more money. That being said , id still look to buy from a main (north american) manufacturer, like Grote or Trucklight rather than the company you linked to.
/ Lights, Camera, Action #34
Thanks Jason. I thought 4Shorts mentioned buying the light for LED light for $30 (I believe in #31) but perhaps I misunderstood Mr. 4Shorts.
The LED lights I was refering to was the ones in the video that I made the box's for and mounted on the snow blower. That's why the video was made. I just wanted to show how I did it just in case there were other tractor owners out there that may have wanted to do the same as I did.
The only other LED's on my tractor are the top of the cab signal lights. I removed the factory ones and put LED's in there place. The top emergency light is a strobe light and the custom built the light bar for it. Hope this clears things up for you.
/ Lights, Camera, Action #37
You can look to see how Christmas lights with LED's went up compared to the standard bulb.
I still don't think that tractor gets used as clean as it is. ;)
It just rolled up to the 50 hour mark and I did the complete full service. The Kubota service manual stated you only need to replace the Trans filter, Hyd. filter motor oil and filter but I changed out all the Hyd. fluid and front def. oils as well. It's only used for snow clearing and only plows clean snow :D
Not like in Lab City: D There you needed a magnetic seperator for the snow !
Man isn't that the truth. In the spring the snow would be black and looked awful. I don't think it's that bad there now seeing they changed over to a new system. I remember operating a 988 Cat loader over in the pellet stock pile one day when a seagull flue into all the dust and when it came out the other side It looked like a crow :D Oh the memories! Hey Happy New Year DraftHorse
159119 (A60430)
159119 (A60430)
Kubota L4701 (A53317)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 John Deere R-4038 (A61306)
2019 John Deere...
2016 Lawnhorn Utility Trailer (A60352)
2016 Lawnhorn...
2018 FORD F-250 XL SUPER DUTY EXT CAB TRUCK (A59823)
2018 FORD F-250 XL...
