Yanmar YM240D
/ Yanmar YM240D #2
...1975 YANMAR YM240 Less than 40 HP For Sale At TractorHouse.com...
It's about a 1981. That external air cleaner and Model# medallion were only used in YM240's final year.
anyone know if $3500 is a good price? Says 46 hours
I think it's a fair price IF it checks out to be in good condition. That model is near indestructible but any machine can be trashed by neglected maintenance.
046 hours on a 3 digit meter is meaningless. The rusty wheels, the replacement muffler, and the missing tip on the throttle lever more clearly portray its 25+ years of use.
can you disengage the 4WD and can you engage a diff lock on this model?
Yes and yes.
The front tires look too large to me.
I don't see anything so far in the available information that is a red flag. Check it over carefully to verify that it is as good as it looks.
You might like to review the original Yanmar brochure referenced in my sig, below.
/ Yanmar YM240D
Thanks for the terrific info. Really appreciate it. I also think the front wheels look too tall.
If I get the money, i'll make sure it runs good before buying.
Can you change gears while rolling?
Thanks.
/ Yanmar YM240D #4
NO , you can't shift on the fly
/ Yanmar YM240D #6
If the front tires are too big. When in 4wd they may be out of sinc with thr rear
/ Yanmar YM240D #7
Fronts should be 5.00 x 15 according to the 'optional equipment' section in the brochure I referenced.
That ad says this tractor's fronts are 27x8.50-15. I'll leave it to somebody else to research if those have the same rolling diameter as the recommended 5.00x15.
/ Yanmar YM240D
I think we've discovered the problem. Brochure says a 20" Dia turf tire. Ad says it's a 27". If this is all correct, then the front end it 3.5" high. Also the drive ratio would be off. Is that a solid link to the front axle, or something hydraulic? Seems like the tire sizes should be specific so the front end is not trying to go faster that the rear end.
Thanks.
/ Yanmar YM240D #9
Somebody has cobbled together stuff that Yanmar never anticipated. On the rear, it has 24 inch turf tires on relatively narrow rims that I think Yanmar intended for ag tires. On the front, I see wide 15 inch rims, where Yanmar specified either a 10 inch diameter rim (for turf) or else a 15 inch diameter x 3 inch wide rim for the specified 5.00 x 15 tire.
This isn't a deal killer, but I would expect to replace the front tires with ones of the correct working diameter.
I'll bet the owner only used fwd rarely, when stuck, after mounting the first cheap tires he got his hands on. If the size mismatch is as bad as it looks, the front tires would skid and hop if he left it in fwd on dry ground.
Be sure to check for excessive wear in the entire driveline.
/ Yanmar YM240D #10
I looked in the Optional Equipment chapter of the YM240 Operation manual, Turf Option described, and discovered that this tractor is fitted with the correct tires:
Front 27x8.50-15(2PR) Rear 11.2/10-24(4PR).
(Wheels that are 10 inch front, 16 inch rear are for the 2wd Turf option.)
So tire size is one less problem to worry about. Sorry about dragging your thread off-topic.
/ Yanmar YM240D
Thanks for the extra effort. Still looks high in the front. Maybe it's just the photo. Doesn't matter anyway, strapped for cash. Hopefully it'll still be there after tax refund and the Surburban is paid off :)
/ Yanmar YM240D
Does anyone know if there any difference between a YM240D and a YM2000D? They sure look the same (other than color). I think someone said the 240Ds were made from 1978 to 1981. How about the 2000D?
/ Yanmar YM240D #13
Well after displaying my ignorance in the matter of tires, above, take this FWIW: :D
YM2000 came first. (Early 70's??). The early ones were green and had headlights alongside the hood, not in the grille. An American version was adapted from this with minor differences to meet American standards. For example the US YM240 has an overrun ratchet in its PTO, and its PTO speeds are 540/1000 instead of the three speed PTO of most Japanese Yanmars. The US throttle pulls down to stop; YM2000 push up to stop. All the main stuff is identical and these were just adaptations to make the tractor conform to US standards.
About 1977??? the second series YM2000/YM240 came out. The big difference is the headlights are now in the top-front of the grille. Mechanical improvements were minor. At that point YM2000 started using red paint while YM240 continued the weird leisure-suit green. YM2000 production ended about 1977-79??. YM240 production, or at least the US marketing, continued through 1981.
These two tractors had smaller siblings, YM1700 (Japan) and YM195 (US) that had smaller cylinder bore and smaller tires, and not much else different. Maybe the gear ratios. (No water pump on YM1700).
And the 'D' option indicates 4 wheel drive, as you probably know.
/ Yanmar YM240D
It's good that they are alomost the same since that probably helps with parts availability. Ever see a YM240D repainted in the red? At first the green was rather sickly, but it's kinda growing on me because it's different. :)
Thanks for the awesome history lesson. Someone should do a Yanmar garden tractor book with all this.
/ Yanmar YM240D #15
You don't want to paint your 240D red.
Many Deere dealers once sold Yanmars as well, and remain authorized Yanmar Parts sellers. They still have the shop manuals for your tractor and will work on your legitimate US Yanmar alongside their Yanmar-powered Deeres, if you ever need a really major repair. But they won't touch a gray market Yanmar (or what they fear is a ******* combo of US/gray parts) for fear of losing that Yanmar Parts franchise.
I asked about service at my local Deere dealer and the service manager threw a tantrum. They can only see the US parts catalog so they get blindsided if they order parts from Yanmar-USA and the customer's tractor turns out to be some gray variant that isn't described in that US catalog. I couldn't get the guy calmed down. He was sure I was trying to slip a gray market Yanmar into his All-American shop. I haven't bothered to go back. In five years I've never needed anything I couldn't install myself - filters etc, plus some renovation parts right after I bought it that came off ebay. (My initial setup included replacing bashed headlights, a few knob tips, etc. that the previous owner had neglected.)
I've had much better service from the gray market parts sources. I bought a ROPS, a seat, the hydraulic internal screen, etc, that are unique to YM2000/YM240 by mailorder, much more simply than if I had gone back to that Authorized Parts dealer. Third-party parts support for the grays is excellent, about like maintaining an old Jeep, VW, or 65 Mustang. There will be aftermarket parts out there for years. That is a better parts channel than going through the former dealers - although it is nice that we have both channels available.
Besides: That color has some history. The first thing I thought of when I discovered my Yanmar was the old Euclid TC12's made 30 years earlier that were painted that color. 420 horsepower, twin engines, and 12 ft wide across the tracks. Not exactly wimpy.
Crank up the sound! :D
Youtube Vid1 - TC-12
Youtube Vid2 - TC-12
Just for fun.
It's good that they are almost the same since that probably helps with parts availability. Ever see a YM240D repainted in the red? At first the green was rather sickly, but it's kinda growing on me because it's different. :)
/ Yanmar YM240D
Do you have the green and white color codes? Not sure what that is. What is normally used, a "duplicolor code" or something?
I only have a postage sized lot, but we're in a subdivision without a homeowners association. We have common grounds to mow and streets to plow. Be a fun toy for that. Plus, I can plow the driveway in three passes. 3 minutes :)
/ Yanmar YM240D
Problem is, match it to what? Old faded manuals or old faded tractor :)
Ans, is Mark also the one who restored a YM1601? I saw pics here:
http://www.yanmarowners.com
/ Yanmar YM240D #19
When Mark shows up he will have the right answer. He is an experienced restorer and has completed several units to museum-quality. I don't know how he can bear to take them back out in the dirt!
I think he has said take in some piece that has never been exposed to daylight, like the underside of the dashboard, and let the pros match to that. It might be easier to just pull the hood, rub out a portion of the underside to expose the original color, then take the whole hood in.
The color on the latest VW bug isn't a perfect match but I think it is better looking than Yanmar's choice, which was a very 70's taste. Even Yanmar couldn't stand it after a while! :D
/ Yanmar YM240D
Since it seems to be a fairly rare beast to match, probably get close and use a bit of artistic license.
Is the attached file one of his restorations?
