LA724 loader concern
   / LA724 loader concern #1
amigauser
Unionville, Connecticut USA
Kubota B2601
I just purchased my Grand L 3240 less than three weeks ago. When I first took delivery it was covered pretty well with ice/snow so I could not give it any type of real inspection. I gave it a once over today and I noticed that there are some waves in the metal of the FEL arms. I don't recall seeing anything like that on my LA403 loader that I had on my old B3030. Is this normal?
I only have about 5 hours on it. The only loader work I have done is floating the bucket on my tar driveway to remove snow. I have never hit anything with it.
Please see attached pictures.
   / LA724 loader concern #2
Wow! It is looking like someone in quality control at Kubota is not doing their job. (Sloppy welds, wavy metal) IMHO, that loader should have never been painted much less shipped to the dealer. The dealer should not have installed it on your tractor. I don't know about you, but my tractor was a significant expence and it should be perfect when new.
   / LA724 loader concern #3
What's up with Kubota and shipping these things out. The middle picture really shows it well, the picture shows that the metal is warped, it's not just a surface defect. I would want another loader.
   / LA724 loader concern #4
Boy, Kubota is really letting some ugly loaders through.
I though the welds were bad but would probably never amount to any performance problems... This, I can't believe this. I'm nearly speechless, I wouldn't accept that loader. I'm not an engineer and I'm not qualified to say this but I call that a structural defect.
What's going on with KUBOTA??
   / LA724 loader concern #5
I don't think you will get very many negative responses on this issue within the TBN membership. Hopefully your saleman will go to bat for you on this major problem. Good luck and let us know how it turns out.
   / LA724 loader concern #6
I don't think this is a production defect - I think it's damage. It's hard to be sure without seeing it in person, but it looks like the tractor ran into something, buckling the loader arms. My bet is it was a hard hit - not the kind of thing a new owner would do, but easier to imagine at the dealer's yard.
The loader arms are the curved design with formed outer channels straddling a reinforcement inside. Instead of a box cross-section, the legs of the outer channel extend down making a space at the bottom for the hydraulic tubing. The fact the free edges of the outer channel are buckled differently below the inside reinforcement indicates the shape change occurred after the arm was welded together. It's hard to imagine it could be buckled this way before being installed on the tractor. And being the "new curved look" I can't imagine Kubota would allow it to pass production inspection. The bad part is they are now yielded and permanently weaker for pushing - you'll always worry about them. Sorry to see this - I hope there's a good solution.
Any other LA724 owners, please look at your loaders and advise. I am wondering if this is just the way they are shipped? The dealer checked and he said all of the LA724's on his lot have a similar ripple to the metal. Maybe this is how they are welded? I believe the tractor itself if made in Japan but the loaders and other attachments are made here in the USA.
   / LA724 loader concern #9
Well if Kubota will give me a life time warranty against failure of that for any reason due to the fact of how the metal is now and all the other are I would keep it. It not, I would not and would not wait more than two weeks either for refund, replacement without defect of lifetime warranty for any reason. Does make you wonder who is making their fel. Is making my recent fabrication look better all the time. :(
   / LA724 loader concern #10
Don't know if it makes you feel any better but my L3240HST bought this summer also has the waves on the arms. Can only see them at an exact angle and they disappear from view when you move the least amount of angle. I'm not the least worried about mine. Couldn't see them when I pulled the tractor out of the building.
TOYOTA 7FGCU25 LP SIT DOWN FORKLIFT (A50854)
TOYOTA 7FGCU25 LP...
2022 INTERNATIONAL MV607 26FT BOX TRUCK (A51222)
2022 INTERNATIONAL...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
2004 CATERPILLAR 963C CRAWLER LOADER (A51242)
2004 CATERPILLAR...
2011 NEW HOLLAND W130B WHEEL LOADER (A50854)
2011 NEW HOLLAND...
