Generator PTO generator speed
/ PTO generator speed #11
Where is your tractor going to be setting through out an ice storm while it's powering the Gen.?
This is just one of the problems I see with a P T O Gen.!
L . B .
dodgeman,
it appears you may get a chance to test it out with the ice storm moving into western Illinois. Run that tractor to the rated rpm for pto. It will run for days and days with no problems. Tell us how it works if you loose power. I am sitting listening to rain falling on the roof outside and the temperature is 20. I hope we change to snow soon. We have the tractor hooked to the genny and ready to move into action. I hope that is enough insurance to ward off the ice storm. Good Luck
/ PTO generator speed #12
If it's really coming down, I've got a tarp I can throw over it. Flip the seat forward to keep it reasonably dry in case I need to use it. I've got two tractors, either of which can run the generator.
Remember, again, this is a tool to be used, not a museum piece. In 90+% of the cases, your tractor spent the first few months of its life exposed to the weather. One or two nights in a storm isn't going to cause any malfunction.
/ PTO generator speed #13
L . B .
Mine is sitting in the same place it always sits. Why, is your allergic to rain or ice?
/ PTO generator speed #14
I don't have a hertz meter, or the intentions to buy one. I do, however, monitor the AC voltage at an outlet in the house while the PTO generator is running. My rig needs to be run a little below PTO speed to maintain proper voltage values.
/ PTO generator speed #15
Do what you want, Rick, but your electrical devices are more sensitive to variation in frequency than they are to variations in voltage.
/ PTO generator speed #16
Not to hijack, but my tractor has 2 PTO settings one is the standard 540 and the other is 1080 (I think thats right). The dealership told me it was for over seas and not to use it. Could I set the PTO to this position and run at half the RPM to get the 540 RPM needed?
Tom
/ PTO generator speed #17
Tom
Mine has 3 PTO rpms, 550, 700, 1000(1080?) and I often use the 700 with my snowblower basically because I am gear driven (not HST) mainly to get a bit faster ground speed in lighter snow conditions.
I also use it in heavyier snows at slow speed for blowing the snow farthur, doing that for 8 years without any problems.
Mind you I never let the engine bog down.
/ PTO generator speed #18
Jeff, I'm going to have to respectfully disagree. In fact, many devices are rated 50/60 Hz, because they'll do just fine either way. What typically burns up (non-resistive) electrical equipment is low voltage which results in low power so the equipment ends up drawing significantly more current to drive the load.
One thing to note, with most of the capacitor excited generators on the market today, the voltage (up to rated load) will very much fall in line when the frequency is adjusted to ~60 Hz and vice-versa. As such, adjusting for the voltage is usually a fairly accurate way (+/- a few Hz) of setting up the generator.
One side note: There is a device called a "Kill A Watt" available that runs about $20-$30 and can be plugged into any outlet to give you not only Hz, but all kinds of other power useage information. It's designed to help you track how much power a particular device, such as a freezer, is using over time, but it has the added bonus of frequency, voltage, current, power factor, among other measurements. I got mine on eBay, but they're available elsewhere. They also make an advanced unit that costs more and has some added features, but I'm not familiar with it.
/ PTO generator speed #19
Tom
This comes up often, the short answer is yes for light loads, but it really depends on your tractors pto horsepower in relation to the gennys out put. If you had a 100hp tractor and a 10 kw gen, then you could probably draw the full 10 kw off the gen at the lower engine r's. But if you have a 14 pto hp machine and a 7 kw gen, you would not be able to draw much off the genny at lower r's due to well due to many factors but the main one being you need that full 2 hp per kw and to get and keep the gen in the sweet/safe spot as far as volts/HZ output goes. This is not the best description as to why not but I'm having trouble putting in an easy explanation, others will be able to.
Definitely the # 1 PTO generator question/Issue.
Whoever told you the that 2nd speed pto option was for "over seas" should get the Bozo of the year award and should not be selling tractors.
/ PTO generator speed #20
My rig is a 42HP Branson. I do not have a PTO Gen but hey, maybe some day.
So is the 2nd PTO speed for any particular implement? What is the primary use?
Tom
2000 CHEVROLET SILVERADO (A60736)
2000 CHEVROLET...
2007 JLG 1930ES ELECTRIC SCISSOR LIFT (A59823)
2007 JLG 1930ES...
John Deere Hopper Assembley Kit (A60463)
John Deere Hopper...
2020 DRAGON ESP...
2021 JOHN DEERE 6145R TRACTOR (A59823)
2021 JOHN DEERE...
2025 80in Hydraulic Dual Cylinder Grapple Bucket Skid Steer Attachment (A61567)
2025 80in...
