fire wood splitter
/ fire wood splitter #21
I looked at those units at NH. I don't care much for the design. They had the Powerhorse splitters on display alongside this machine, which made them look like toys. As to their functions, there is no auto return valve, so you have to place logs from both ends of the machine, or run the wedge back manually. They only handle 19" logs, which may be all you need, but the majority of splitters seemed to be designed for something a little bigger.
You would hook the unit up to the PTO QDs. You probably would not have to run the PT at full throttle.
SnowRidge,
Thanks for the input.
Would you have to do anything to the connections on the PT PTO QDs or on the Powerhouse splitter to make them go together?
/ fire wood splitter #23
Here are a few.
I saw one like these bolted on to the rear wheel of a truck about 60 years ago.
My dad and I had one of these - exactly like the "STICKLER" in the picture - and used it a lot. I still have it in the back of one of the barns - I don't (and wouldn't) use it today, but it's great to show people and see the look on their face when I tell them what it does. We were always a little impatient - the idea was to let the truck idle and let the screw work its way through the log. Dad had me sit in the truck and goose the throttle a little to make the thing split faster. Picked the truck up one day and almost set it off the jack stand when we hit an extra tough log. Ahhhh, those were the days...
/ fire wood splitter #24
SnowRidge,
You would have to fit matching QDs to 1/2 inch hydraulic hoses and connect those to the Powerhouse splitter. Any good hydraulic shop should be able to make them up for you.
/ fire wood splitter #25
we are wanting to purchase areplacement screw auger of the same design on hibeams kioti log splitting attachment.
/ fire wood splitter #26
Just an idea for a cheap log splitter that might do for lighter splitting. It would have more power than the screw types that I have seen.
/ fire wood splitter #27
Using those figures. That makes that shaft size 1 in, and that is not a good thing. Bare minimums at best.
/ fire wood splitter #28
Well there JJ. Explain that so these good people will know what you mean. It might be they can fugure it out but i can't.
/ fire wood splitter #29
I think he's saying you need a larger cylinder as one with a 1" shaft is kind of tiny and could bend under that kind of load. And, if you increase the shaft size, your cycle time will slow down.
/ fire wood splitter #30
Now this is starting to get plum silly. Bigger shaft= stronger cylinder yes but, shorter cycle time. Cause less area to fill on the return stroke. I can fill this going on and on so I will just say that my post was much more for an example than it was a blue print. I should have written a disclaimer.
For example only, Author not responsible for calculations, design or materials represented.
Also I must confess, guess I was fishing for one of those legendary responses from JJ. He will keep you on your toes. Got to love him,
/ fire wood splitter #31
No, I was not trying to embarrass anyone, but to show that the cylinder chosen is not a good choice. A 2 in shaft has much better advantage if you have any potential bending forces. I had to calculate back-wards to find the shaft size, because it was not stated. I used trial and error. You could even use the same cylinder bore and change out the shaft and still have the same push force. The difference would show up in the return stroke. You might get by with that same cylinder for a while, but one day it will come into that big knot, and bend the shaft.
As an illustration your diagram is fine. It looks similar to this commercial model.
Pictures are for reference only.
/ fire wood splitter #32
A nice simple concept. Thanks for sharing.
/ fire wood splitter #34
Yes when I first built the upside down splitter it didn稚 take long to see that it was only handy on splitting and moving the large cuts. That痴 when the upright feature was added. Still haven稚 fixed the frame where I bent it but by not treating it so rough it hasn稚 gotten any worse. It is on my to do list though.
I can't turn mine side ways. Never thought about that when building it. But so far we have been able to make do without that feature.
/ fire wood splitter #36
I thought that this would be a cool idea, like the pictures you showed, but then I watched this thing in action. Man, it looks like you would be chasing wood all day, and for sure you need a wide open area to get your split on...
Hydraulic Log Splitter | Bobcat Log Splitter | Skid Steer Log Splitters
O.K. That video was neat, but geez... the guy had to spread out all those logs so he wouldn't run over them. Then he took about 3 swipes at that second log, then turned it sideways, then another 4-5 swipes. I thought he was going to back over his picnic table or dog there, for a minute.
But is was cool. Had a really fast cycle time, too. I would probably opt to set it up stationary.
/ fire wood splitter #37
I understand that people really like these "jack of all trades" machines we have, and that they don't necessarily like to maintain another engine. But, there's some things, IMO, that just might be more productive stand-alone, for most people. Two examples come to mind -- a chipper/shredder and a log splitter. I'm not sure but what I'd want to use the PT to move the materials to/from the work area, and let those two attachments have their own power source...
Just my thoughts.
I can see the need to need to mount it to the PT, if you need to move the tool to a remote, inaccessible work area. But, is that always the case?
/ fire wood splitter #38
Just my thoughts.
One other thing is a generator. Usually, when the power is out, there is storm damage, ice or snow. I want to be able to use the tractor to clean stuff up and not have to shut down the house power to do it.
However, I could use a log splitter powered by the PT. In my situation, I can haul the logs to a staging area, cut them to length and split them right there and toss them on the trailer to take home. If, for some reason, I need to use the PT, the quick attach is so fast, it just isn't a hindrance to change an implement. Remember, it only takes 30 seconds to change out a powered implement and only 15 for non powered. :D
/ fire wood splitter #40
Yes, that's true regarding the log-splitter. But, with the PT-425 I'm putting hours on a $2,000 25HP engine when essentially the same job could be done by a 5-8 HP $400-500 engine. The PT-425 only outputs about 8 hydraulic HP, perhaps 10 HP max (with no load on anything else, sitting stationary), while running a 25HP engine at full-throttle...
WIth a long-splitter you likely wouldn't need full throttle, but stil...
2000 Dodge Ram 1500 4x4 Ext. Cab Pickup Truck (A61568)
2000 Dodge Ram...
2022 East Manufacturing 48ft. T/A Walking Floor Trailer (A61568)
2022 East...
TAYLOR POWER SYSTEMS SKIDDED GENERATOR (A60736)
TAYLOR POWER...
2018 Komatsu D61PX Crawler Tractor Dozer (A61567)
2018 Komatsu D61PX...
1999 Fontaine 48ft. 38 Ton T/A Flatbed Trailer (A61568)
1999 Fontaine...
New/Unused 20x30 All Steel Carport (A61166)
New/Unused 20x30...
