Dump Trailer
/ Dump Trailer #11
Has anyone mentioned that you need brakes?
:D
/ Dump Trailer #12
What year truck are you using? You mention that you don't have a break controller, they are not hard to install. My truck has a towing package and had a wire harness in the glove box. Just plug it in way up under the dash and hooked it to the controller. JC
/ Dump Trailer #13
I have a 12x6 10k dump trailer that I absolutely love. However, I will say that I wouldn't even consider towing it with a 1/2 ton and a load of gravel. I have a 3/4 ton diesel and looking at my last ticket load of 5/8"-0, I was hauling 3.5 tons which put me about ~300 pounds over weight actually (trailer is around 3300). I can tell you that you most certainly need the additional power if you are going to pull across any grades, but as mentioned a number of times, even more important is your ability to stop this much weight. I have a brake controller, but I know people that tow the same size trailer without one and to me that is just a huge accident waiting to happen. Why take the risk? Cost me around $100 for the brake controller and adapter and took less than 5 minutes to connect and mount it.
BTW, even with my trailer, it isn't cost effective for me to haul any sizable amount of gravel. I usually order it in 30 ton increments from the rock pit. The distance is about 20 miles over backroads. So, for me to get 3.5 ton of rock in my trailer, it costs me about 5 gallons of diesel, so at $2.50/G right now, that is an additional $12.50 each run, not counting my time or vehicle and trailer wear and tear. So, for me to do the equivalent of 30 tons, it would take me around 9 trips, so an additional $112.50. It costs me about $200 for delivery for all 30 ton in a single delivery and doesn't cost me a cent in maintenance or time, so in the end it is absolutely cheaper to have it hauled.
Now, that said, I love my trailer and use it for a lot of different things, from hauling bark dust, to moving my tractor, to you name it. So, I would definitely recommend a trailer if you can get one, just don't expect to haul heavy things in it with a 1/2 ton, and no matter what, get a brake controller. :)
/ Dump Trailer #14
Like the others said you can have a lot of loads hauled before you pay for a $5000 trailer plus all the gas and wear and tare on your truck. My local pit is 1.5 miles from my house and they have nice drivers with nice equipment. They will bring up to 24 tons 25 miles for $75. I have tried to talk them down if I get 100 tons and they will not do it. He says he has to pay his drivers, pay insurance, and buy $100,000 dump trucks. He will let them sit before he discounts a load. I guess I cant blame him. He is in business to make money, not lose it.
What is funny is my neighbor has a Ford 700 single axle dump truck that can haul about 8 tons. He charges $40 or $45 dollars. It would take 3 deliveries for him to equal the pits trucks or $120 in fees. I have actually seen him bid jobs then pay the pit to deliver it instead of using his own truck. It just puts money back in his pocket.
Chris
/ Dump Trailer #15
Not to hijack the OPs thread but this is good info. I to am looking at a dump trailer. I work about 3/4 of a mile from where I get ground asphalt so have to go past it anyway. Having it hauled out to my place cost $100.00 per hour and is a 2 hr total round trip (not really but that is the lowest estimated fee from three different trucking companies). The material is $4 a cubic yard in addition to haulage. Hauling the regrind is a lot more expensive than buying it.
/ Dump Trailer #16
Yeah, my '02 with the tow package had a plug on the fuse panel "if I remember correctly" or somewhere in that area. I simply bought my controller "Prodigy" , and the appropriate harness. Then, it was literally plug and play !!
/ Dump Trailer #17
I have a 6x10 Moritz that weighs 3300lb empty. My first load with it was dirt. I weighed it on the way home and it was 12K. That was 3-4 1 yard bucket from a BH. Aside from the brake issue no way a 1/2tonner can hold up the tongue. I've seen them on the highway draggin azz bad pulling those dumpers. Last load of gravel I got was 3ton and it was cost effective since I didn't need a full dump truck load. That put me right up to the 10K my trailer is rated for. And when I got home and dumped it, it looked really puny. The only load 1/2 ton trucks are good at are boats, cause they typically are light on the tongue.
/ Dump Trailer #18
I also drive past where I get crushed concrete on my way to work so it works out for me to haul it myself.
/ Dump Trailer #19
DON'T DO IT!!! Maybe with trailer brakes, but even then....
Not to rain on your parade, but I'd say that unless you get a 3/4 or 1 ton truck, I'd let the pro's bring your gravel. The dump full of gravel that you could pull safely with your truck would be pretty small.
-Jer.
Here we are back to the nothing less than a 3/4 will do
mentatality.
1*I'm with Diamondpilot ! Some of the new 1/2 tons are rated to tow (according to the ads on TV) 10,000 when "properly equipped". My BIL's 1/2 ton GMC is rated for 6000 (believe its a 06). What does your owners manual say?
2*I own a small (5X10) BriMar dump, rated @ #7000. I can put 5000lbs in it legally. I drive an F-350, and i can tell you that my trailer weighing #7000 is HEAVY !!! And with my F-350 i would NEVER consider towing my trailer with brakes that weren't working, or working properly(nevermind a half ton!!!). Dirt is HEAVY...... and damp dirt is HEAVIER !!!! You would be stunned to see how little dirt it takes to bring a 7000lb trailer to max capacity.
1* If this is so why do I keep hearing the old tired It's gota be at least a 3/4?
2*Then right in the same breath urging a/34 over a 1/2!
/ Dump Trailer #20
I made a wooden box enclosure for my 16 ft. equipment trailer a few years back. Over the summer, I had the pit load #57 on for me, and the slip showed 3.6 ton plus of course the trailer weight of 3900. And yes, the 1/2 ton was difinitely squatting. Actually, the tires appeared more distressed than the springs. Luckily I've only got a 3 mile sprint down the road from there,,,,, ok, it wasn't a sprint,, but a slow jog. :D
After reading your post WK,, and your mention of the tongue weight,, I wonder if perhaps it was because more of the weight was centered over the axles and spread out over a greater distance that I was able to pull it off with the tires blowing or worse.
At any rate,, I don't plan to overload like that again !!
Giyi Mini Ex Attachment Set (A60463)
Giyi Mini Ex...
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
2025 CTRA 4X2 T/A 16FT ENCLOSED TRAILER (A59906)
2025 CTRA 4X2 T/A...
CAT Chassis Only (A59076)
CAT Chassis Only...
2014 International DuraStar 4400 Service Truck with Crane, VIN # 3HAMKAAN0EL771639 (A61165)
2014 International...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
