Generator why aren't pto generators a lot cheaper?
/ why aren't pto generators a lot cheaper? #21
I have one... Have had it since the bad hurricanes in florida back in 04.
I use it frequently on my farm. back before I had power out at one pasture, I used it daily to power up the water pump to provide water for the animals. I had it hooked to the tractor , on the trailer, and just backed up to the pump itself and hooked it up and ran. Powered it with a 1955 for 660. A graphing meter on the output shows it's power to be as clean as my local utility... voltage regulation was as good or better than my utility as well.
soundguy
Thanks Chris. Do you have that model?? There is a HF across the road from a local breakfast place in Harrisburg. Think I may have to bring one home with us next July.
/ why aren't pto generators a lot cheaper? #22
I don't have the model # handy.. but northern tools only sells one 12.5kw pto gen. not sure if this is the same gen you see at the chinese store? but maybee..
soundguy
/ why aren't pto generators a lot cheaper? #23
soundguy
is yours chinese built like the HF??
/ why aren't pto generators a lot cheaper? #24
It's got a northstar lable on it... I have no idea of the country of origin.. but figure it's a good bet it could be chinese.. everything else seems to be coming from there..
soundguy
/ why aren't pto generators a lot cheaper? #25
This HF gen set looked like a option for me too.
This was out of the manual for the HF gen set.
Unconditioned electrical power can 3. damage sensitive equipment. Use a line conditioner (sold separately) between
this generator and the devices.
Here is the manual link
Harbor Freight Tools - Quality Tools at the Lowest Prices
65309
/ why aren't pto generators a lot cheaper? #26
I'll look at my manual when i get home to see if it shows country of origin.
i know mine is a brushless model, or so it claims.. and it is passive (capacitively) regulated.
soundguy
/ why aren't pto generators a lot cheaper? #27
soundguy
Thanks. I figure you have put yours thru a few tests and it has been good, so I don't feel bad about buying one. What is an SF Gen head?? I think that is what was mentioned earler in this thread.
/ why aren't pto generators a lot cheaper? #28
Paperwork says:
K-Bar Industries
Faribault ,mn.
who knows.. might just be ssembled there from chi-com parts?
A search for them shows them to be a manufacturee of power and heating equipment.. and a supplier to northern tools among other things..
soundguy
/ why aren't pto generators a lot cheaper? #29
I'm getting to the point that I feel some guilt when I buy Chinese stuff.
This HF unit doesn't specify the PTO hp required to pull full amperage on that unit. I know a BX would turn the thing at full RPM with no load, but I wonder how many watts/amps of load could be put on it before it starts to lug down.
The NT gen linked below is 7200 watts spec'd @ 14 hp. and priced @ $900 ($240 more for driveline and you'd need to custom fab a frame) would be a good fit for a BX. I am guessing that the HF unit needs a min. of 29-30 hp to pull that 15,000 watt load.
NorthStar PTO Generator — 7200 Watt, 14 HP Required | PTO Generators | Northern Tool + Equipment
Sure wish they'd include the hp spec. on the HF model.
/ why aren't pto generators a lot cheaper? #30
so what.... figure out what load you can pull off it with your BX running it and be happy. If you ever do upgrade youll have plenty of generator to back it up.
/ why aren't pto generators a lot cheaper? #31
Exactly. And who says you have to power everything when the power is down? Just the necessities, nothing more.
/ why aren't pto generators a lot cheaper? #32
That will be about 1.341 HP per KW.
15KW = ~20hp. There is some inefficiency, so to be safe, 25 PTO HP should pull a 15KW generator head.
/ why aren't pto generators a lot cheaper? #33
And if the HP cannot pull it, at say 20HP, will the tractor just bog down??
/ why aren't pto generators a lot cheaper? #34
Will
The tractor will just bog down if you exceed what it is capable of. I have a 7kW unit that I ran behind a 14hp Kubota for many years. I figured I could draw 4-5 kW before loading down the tractor. That was enough to power refrigerator, freezer and a few lights and small fans. As to costs I paid around $1000 for that unit back in 1984 so they have gotten cheaper as the years have gone by.
I still have that unit but need a new control head. The mfg went out of business about 10 yrs ago and the plant is a EPA superfund site.
Anybody on here that can tell me what I need to look for to figure out a new control head. The old one is all potted with a black compound.
Vernon
/ why aren't pto generators a lot cheaper? #35
Will
Vernon
I think fuses have been overlooked here...
I would never hook my tractor to an emergency situatuation (as I've tried to say) Not sure a tractor 'bog down' before the switches are tripping...
I'm no expert here. Jake
/ why aren't pto generators a lot cheaper? #36
soundguy
Like all of them since the 30"s?
ps Why aren't they cheaper?? Give it a little time, they'll (enginless generators) be real cheap. I have a Winco head that I can't pick up, interested? The only thing that's going to be of value is dependability.
/ why aren't pto generators a lot cheaper? #37
I did some research about the PTO gen sets a couple of years ago. If I remember right, it stated something about matching up the tractor with the gen set, for this reason. Like someone else mention, if you put a heavy load on the gen set, the rpm of the gen set changes and is not producing the right voltage/frequency. What they eluded to was that on some tractors there is a PTO rpm selection, that is supposed to give 540 at the PTO. Some of the newer tractors have electronic rpm control, so that if a heavy load was placed on the gen set, the rpm would try and decrease, but the engine regulation would keep it at a PTO rpm of 540. They showed graphs and charts how different systems hooked together would work or not work.
/ why aren't pto generators a lot cheaper? #38
JJ, Now you got me doin the 'When I sits and thinks, I thinks...'
Jake
/ why aren't pto generators a lot cheaper? #39
Rule of thumb is about 2hp per kw generated. yeah sure.. that's not a direct fuel to kw conversion.. but it's a safe one that takes into account reasonable loss thru gearing and driveline. most ptogensets use this rule of thumb.. my 12.5kw unit manual asks for 24pto hp.. etc..
soundguy
NorthStar PTO Generator 7200 Watt, 14 HP Required | PTO Generators | Northern Tool + Equipment
/ why aren't pto generators a lot cheaper? #40
1.341 HP per KW is the direct conversion. Sadly it is not even close to the reality of generating electric power. It does not take into account that most engines cannot survive for long at their peak power output levels. It does not take into account drive train and or gearbox losses, or blower loads to move air to keep the generator cool. It also does not take into account that the generator is only about 85-90% efficient at turning torque into kilowatts.
It takes 2HP per KW of electrical load to produce SUSTAINABLE electric power on a small scale. Very large plants(thousands of HP) can typically run at less than this ratio, but not by much. This rule of thumb has been well proven since the creation of the electric generator. You can see it in practice at just about any store or manufacturers website that produce or sell generators. A quality 5KW generator will have at least a 10HP engine attached. If it dosn't, I would question it's ability to deliver a sustained 5KW of electric power...
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
HANFAB HF-60-DG1-SD-R 60" CIRCULAR SAW (A64276)
HANFAB...
PENDING SELLER CONFIRMATIONS (A59911)
PENDING SELLER...
2007 John Deere 1790 Planter (A63111)
2007 John Deere...
2019 International LT625 Sleeper 48" (A62613)
2019 International...
2014 Hyundai VI2530112 53ft. T/A Dry Van Trailer (A61573)
2014 Hyundai...
