Generator why aren't pto generators a lot cheaper?
   / why aren't pto generators a lot cheaper?
wow, that is the best price i have seen for the output...i will check that one out. i don't plan on powering my computer or anything else i can think of that has a computer in it, the tv and satellite have ups's on them so they should be protected if the power out wasn't just perfect..
thanks
heehaw
   / why aren't pto generators a lot cheaper? #13
I wonder how long one of these will last compared the the big dollar units?? or are they the same??
looks like a standard ST gen head. which are know for there longevity if you do a few maintenance items. including bearings and some redip the windings to make sure the wires don't vibrate and short out.
after those 2 items theres not much else to do to a gen head.
THe other maintance item on the cheep ST gen heads are the "dog house" electronics that do the voltage regulation etc. but most of the stuff is bare bones stuff easy to troubleshoot and replace. (no PCB's which you cant say about the more expensive stuff)
(the doghouse electronics on a 12Kw ST head)
   / why aren't pto generators a lot cheaper? #14
Hey,
Thanks. Any other things to watch for on these? I am not one who believes that if it costs more it will always be better, so any info here is appreciated.
   / why aren't pto generators a lot cheaper? #15
   / why aren't pto generators a lot cheaper? #16
Thats the good question. If they don't last long then they aren't worth it. I like to feel when i buy for HF that if it does dies I haven't been out much money. And this item wouldn't let me feel well if it didn't last a long time.hope someone weighs in
   / why aren't pto generators a lot cheaper? #17
hear is a setup on da-bay complete 20Kw PTO hookup without frame for less than $1K (useing a ST gen head)
ST-20Kw Gen/Alternator, PTO Gear Box, Coupler Combo !! - eBay (item 160297856005 end time Dec-09-08 19:37:21 PST)
If you were local-ish (for local pickup) and already had a PTO shaft from say a tiller or something to use then id go for it!
Thanks for the link showing the drive.
I'm with ya for using an ST genhead. With decent bearings installed and qlty rect, they'll run 24/7 for months/yrs on end.
   / why aren't pto generators a lot cheaper? #18
It depends on what you are comparing it to. A lot of people see a 11KW PTO generator for $1800-$2000 and think they would rather get a gas powered unit from Home Depot for $600. The main difference is that the gas unit is only about 6KW as opposed to 11KW or more. We have a stand-by LP powered 12KW home generator that was $7000 installed so $2000 for a 12KW PTO generator is not that bad...
i think you've inadvertantly doubled the price of the pto generator.
a northern tools 12.5kw genny can be had between 1000 and 1100$ depending on their sales flier... a pto shaft costs a hundred or less...
That's not a bad price for 12.5kw's of power..
Can't touch that with a gasser self powered unit.
soundguy
   / why aren't pto generators a lot cheaper? #19
soundguy
So would you put enough faith in one to buy one? The price is so tempting...
   / why aren't pto generators a lot cheaper? #20
I have one... Have had it since the bad hurricanes in florida back in 04.
I use it frequently on my farm. back before I had power out at one pasture, I used it daily to power up the water pump to provide water for the animals. I had it hooked to the tractor , on the trailer, and just backed up to the pump itself and hooked it up and ran. Powered it with a 1955 for 660. A graphing meter on the output shows it's power to be as clean as my local utility... voltage regulation was as good or better than my utility as well.
soundguy
2010 MULTIQUIP 25KW GENERATOR (A53843)
2010 MULTIQUIP...
2020 CHEVROLET SILVERADO 3500 HD FLATBED TRUCK (A57192)
2020 CHEVROLET...
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
2008 Ford F-450 Crew Cab Service Truck (A55973)
2008 Ford F-450...
