Spreader Preserving a steel spreader
/ Preserving a steel spreader #1
Jerome
Elmvale Ontario Canada
Kubota L245dt
I have a tph spreader that I use mainly to spread sand/salt on my drive. the inside needs a coat of paint and I was wondering if the paint on bed liner product would be a good alternative to preserve the steel. or is there something better?
thanks
POR-15 has to be top coated as per the web site. I was looking for something more durable that could take the scratching of the sand/salt and protect the metal.
/ Preserving a steel spreader #4
If you do the roll on bed liner do not get it from Wal-mart ... Will not stick!!
/ Preserving a steel spreader #5
We have a steel spreader at my hunt club that was donated because it was froze up from rust. Plus, the pan that the 4 scoop blades bolted to was eat up with rust. I managed to get it apart and replace the round plate with a nice piece of 3/16" thick round aluminum, rebolted the blades back to it, and got it back together. I didn't bother to repaint it though, the hopper wasn't in that bad of shape. Whenever we use it to spread out fertilizer now, we always rub down the hopper and the blades with some diesel fuel. We also put some used motor oil on the slotted plate at the bottom of the hopper where the product drops out of the bottom. So far, it's been worth the effort cause it works great. I think you just need to find something that will neutralize the corrosive affect of the salt, and treat it with that after every use.
/ Preserving a steel spreader #6
Keep it painted.
soundguy
Yes I want to keep it painted the question is would the bed liner paint work better than regular paint to prevent the damage from the sand and salt or is there something better on the market.
/ Preserving a steel spreader #8
I second the POR15.
Then top coat with the bed liner for durability. The top coat on the POR I believe is due to its UV issues not durability. POR will fade in the sun after only a few days of exposure.
The POR will stop all the active rust and is quite durable by itself but will also provided a great clean surface for the bedliner material to adhear to. The bed liner alone may allow the rust to continue under it and blister.
If the spreader was new factory paint the bedliner should be fine alone but since the metal is rusted, even if you sand blast it I believe your results will be better with the combination of the two.
/ Preserving a steel spreader #10
There are lots of paints that are much much much better than POR.
Industrial IMRON 3.5 HG from Dupont over a primer of Corlar 2.8 PR will be there long after any trace of por is gone. I have that combination on a backhoe bucket and it is TOUGH.
jb
/ Preserving a steel spreader #11
POR 15. UV may fade the paint, but its superficial only and wont effect the protection. Its relatively non hazordous relative to paints with ISO hardeners and its easy to get.
/ Preserving a steel spreader #12
I use a steel spreader for fertilizer and what works for me is an air hose clean-out immediately after use followed by a wash, blow dry and spray with diesel fuel&oil mixture. It's five years old and looks new.
I cannot speak of the other methods since I have never done the coating thing so I am not sure. But I do know the clean and oil approach has worked for me for a long time.
/ Preserving a steel spreader #13
There are some other post treatments that will be a tad friendlier than the oil mix.
soundguy
/ Preserving a steel spreader #14
soundguy
But how doyou get the covering in and between all the nooks and crannies? How doyou coat something and be sure no rust trapped underneath?
I know you understand paints and coatings from reading your prior posts on things so you have a good track record and I have learned from you. How would i treat my fertilizer spreader, for example? I am all ears to a better idea and cleaning like I do each time is a pain.
/ Preserving a steel spreader #15
Remove rust, then paint.. don't paint over rust.
things like naval jelly eat rust.
soundguy
/ Preserving a steel spreader #17
Having spread a lot of fertizer over the years I would like to offer a partial alternative to some of the above posts. Yes, for protecting solid panels of steel these are the right things to do with coatings and such. Most of the rust, however, won't form there.
The nitrogen-urea-fertilizer that we use and is the topic at hand is like sulfuric acid in it's ability to eat steel. I have found it is not so much the solid surfaces that are the problem but the connectors BETWEEN them and all the small parts associated with these low-priced spreaders.
The inability to coat all of these parts and the tendency of them to vibrate usually cleans them to bare steel shorty after use. Even if a coating would stick to them initially, it would vibrate off from sharp edge contact and the urea would certainally attack or wick under those connecting parts and surfaces without being wash removed and re-coated with something that would wick into the tiny surfaces to protect the clean bare steel. No one suggests a slathering of motor oil but an air-pressure cleaned, washed and air-pressure dried spreader sprayed with a small about of diesel fuel and oil (synth if you want) will do the job better than other methods I have seen. I've found it to be the only way.
Even the plastic/metal Vicon small parts will rot if not properly cleaned. The Vicon I had had a lot of carbon steel and castings blended in with the plastic and stainless.
Just my two cents here but coat away at the solid surfaces but spray some sort of wicking oil into the nooks and crannies after clean and dry would be my personal opinion.
/ Preserving a steel spreader #18
That does sound like sound advice.
Would a commercial undercoating for vehicles work for this purpose?:D
Thank you all for your ideas. I think a combination of all is what I'll go for as soon as I source out the products
