radiator hose heater project rant
   / radiator hose heater project rant #21
Got home from work today and being as impatient as i am I brushed off the snow and pulled the tractor in the garage. Drained the antifreeze and insralled the block heater. Total time. 2 Beers.........The hardest part was getting the old freeze plug out. Almost lost it inside the block because it's a shallow fit to the inside of the block and hard to flip. Here are some pics...The stress of doing it is now gone. Not a bad hour project. If there's a failure in any part it will probably be with the Teflon Tape made in China...
THANKS for the pics JOHN K.Ihope mine goes that good.
ALAN
   / radiator hose heater project rant #24
escavader we place a clip-on light to the oil pan of our B1750. A 60watt bulb is all it takes to keep the oil thin. Been doing it for years...even when it's zero out the tractor spins over easily in the unheated garage.
   / radiator hose heater project rant #25
Total time. 2 Beers............
I worked with a guy that would nearly always drink his first 2 beers for the evening in under 1 min total.
   / radiator hose heater project rant #26
What kind of siphon pump did he have hooked up to the cans??? :)
Iwas told in the old days the guys working in the woods would take a pan of hot coals out of the wood stove and place under their equipment in the winter,to aid in starting:)
ALAN
   / radiator hose heater project rant #28
Here is the instruction sheet for the install. Some 50 seris Kubotas have a little more to do for the install. Hope it helps some if they are thinking of getting one.
It was a little wet when I scanned it so i hope you can read it.....
1999 GMC C7500 S/A Dump Truck (A59230)
1999 GMC C7500 S/A...
MANIFOLD TRAILER (A58214)
MANIFOLD TRAILER...
2018 VOLVO L80H WHEEL LOADER (A60429)
2018 VOLVO L80H...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
1996 Sunflower 1543-38 Folding Disk (A56438)
1996 Sunflower...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A59231)
2014 Glasstream...
