Which one should i buy ?
/ Which one should i buy ? #1
200TrueBlue
Member
NL
Max 28 XL
Newby to the site ...
I am looking at buying a compact with FEL and later a Hoe and i have a
budget of $16000 plus tax. Right now the Kubota is out of range but i
have Four options plus one i'm not to sure of.
Kioti CK20
Bobcat CT120
Newholand T1110
Mahindra 2216
Foton FT254 $14500
Which unit would you pick for just around the house and cabin for snow clearing and landscaping, moving gravel ,spreading,digging out stumps etc.
Thanks TB
/ Which one should i buy ? #2
The Bobcat and Kioti are basically the exact same tractor with the Bobcat probably a little more expensive and with different attachments. The Foton is most likely the Chinese Jinma tractor that is sold under about 3000 different names and not a good choice unless you are very good with major repairs and have Chinese parts warehouse close-by.
The New Holland is a 28hp machine so it is a little more powerful than the Kioti/Bobcat but the loader can only lift 650lbs compared to the Kioti's 1074lb lift and Mahindra's 915lb. I can't find any specs for a backhoe for the New Holland either, I don't think they offer one yet. I would be skeptical about a brand new model of tractor before it has a few years of proven reliablity.
Once you compare the specs closely, I am sure you will find the Kioti to have more standard features, stronger attachments, longer warranty, and overall better value. The Mahindra looks like a good tractor also so that really leaves it to which has the best dealer and best price.
I would find the closest dealers, test drive the Kioti, Bobcat and Mahindra and see which you like the best. I bet you would be happy with any of those three.
/ Which one should i buy ? #3
I've never heard of Foton tractors. But then again, I live in rural Maine. :rolleyes:
If you search around this forum, you will find days worth of reading on the same topic you raised. It has been asked and answered by lots of people with lots of experience.
Good luck with your quest, and welcome to TBN.
Jay
/ Which one should i buy ? #4
I am not sure how you can beat a 4 year warranty from Kioti??
I also find their capacities exceed the others as stated previously.
Dealer is very important.
Good luck,
Joel
Almost ready to commit. Which one of the three would you buy if its
just for a 4 car driveway snow clearing and around the cabin digging up stumps and spreding gravel and digging ditches.
Kubota BX 25 Hyd FEL & Bachoe $ 19500
Kioti CK20 Hyd FEL & Bachoe $ 24500
Mahindra 2216 Standard FEL & Bachoe $ 23500
Do you think the Kubota will do the same job as the other two. It just
looks so much smaller and the front wheels are so small ? Just worried
about how much snow it would beable to go through ?
Thanks
TB
/ Which one should i buy ? #6
Not sure where you live and how much snow. But all of those will move a lot of snow. Me, I like the CK20 for the weight, especially when backhoeing. But if that's U.S. dollars, the price is high, I think. I would think under $20K for that setup.
/ Which one should i buy ? #7
I'm certainly not an expert, since the one I own isn't on your list - but it seems like that's a strong price for the Kubota based upon what I read in that forum.
Price aside - how are the dealers for those various brands?
That should also be a very important factor in your decision, since the net differences between the tractors themselves are not likely to be all that dramatically different. But your relationship with the dealer is likely to last for many, many years - regardless of whichever one you select.
Good luck.
Its Canadian Dollars and all three dealers are good guys so its
all up to which one is the better Quality ???
TB
/ Which one should i buy ? #9
HST are nice and easy to drive... my choice would be Kioti CK20 for the size and weight.
/ Which one should i buy ? #10
My *second* choice would be the Kubota for its proven quality and longevity. There are 4 Kubotas in my neighborhood (one of which has been around for a long time) and every owner is very satisfied.
I'm sure the others are good, too, but my first choice is still Massey Ferguson. :D
/ Which one should i buy ? #11
If you were just moving snow and spreading gravel I would say that the Kubota would make a great small tractor for small money. Once you start talking about digging trenches and removing stumps, that is where you will find many weaknesses in the small sub-compact tractors and also find that the CK20 is in a class higher than any other sub-25hp compact tractor and is well worth the extra premium over the other two. You just need to ask yourself if you are going to use that much tractor. If so, then it will be well worth it...
You rarely hear people wishing they had bought a smaller tractor but every other person you talk to wishes they had a larger tractor.
/ Which one should i buy ? #12
Under the BX snow clearance can be an issue with the BX. You can clear 8 inches before the undercarriage starts to want to float. It depends how you plan to clear snow. I used my BX to move snow in Ontario for 4 years and it wasn't an issue. I used a FEL instead of a scraper blade so I could simply dig into those 3 foot high drifts and move them. Lighter snow I'd push with the FEL then move it. I now have a B2620 with 12 inches of clearance and a scraper blade and FEL. That makes the job of clearing the driveway a little faster as I can go through 12 inches of snow now. A 3 foot drift still needs to be chewed away at with the FEL so I'm not really any further ahead on the deep snow days. In my opinion a front mount snow blower on a BX would be just as good as a front mount blower on a tractor with twice the ground clearance. In fact perhaps better as the BX is a nimble little beast that can turn on a dime and and the hydro drive is so simple to operate. I had turf tires on my BX and with the 4 wheel drive never had a problem with traction however I am on a flat piece of ground. With regards to the other models you're looking at I can't comment as I've never tried them.
/ Which one should i buy ? #13
Strange, I would have thought the Kubota would have been more money than the Kioti. I know the Kioti out-specs the Kubota (even though Kubota has a 5HP advantage), but that's quite the price difference.
200TrueBlue,
You are correct, the other two machines would outperform the BX mainly because they are brutes in comparison. You definitely will not be digging out any stumps with the BX unless they are small stumps indeed. Even the other two machines will have a hard enough time depending again upon size of stump.
Kubotas on the other hand of course have their legendary reliability track record.
Tough call on this one if the Kubota is $5K cheaper. Check out the TBN forums on the other two to see of any known reliability issues.
Good Luck,
Vic
/ Which one should i buy ? #14
Kioti CK20
Bobcat CT120
Newholand T1110
Mahindra 2216
Foton FT254 $14500
Thanks TB
Vic
You were in the same boat as me I got a bx 23 for my cabin and haven't regretted it yet yes it is a little small some times but it has been fine for me
I love the way the back hoe clips up to tractor (like oversized car door latches) Verses the 3 point and pin on ones (BX24).
it takes time to do the jobs but I do them at it's pace some jobs take two weekends to do but I ain't paying rental by the hour.
tom
/ Which one should i buy ? #15
1*Under the BX snow clearance can be an issue with the BX.
2*You can clear 8 inches before the undercarriage starts to want to float.
3*I used a FEL instead of a scraper blade so I could simply dig into those 3 foot high drifts and move them. Lighter snow I'd push with the FEL then move it.
1*I don't think that would be a problem with my BXs.
2*Ive cleared many A 6 8 10 12 inch snows and a couple of14 inch snows with my little old 2 wheel drive Bolens garden tractor.
The Bolens ground clearence is a lot less than the BX1500 and the BX23 ground clearance.
3*I use this tractor to plow snow
http://i283.photobucket.com/albums/kk286/lb59/100_2316.jpg
And this tractor to move the piles if needed.
http://i283.photobucket.com/albums/kk286/lb59/100_2321.jpg
/ Which one should i buy ? #16
Do they even make the BX25 anymore...?
Maybe it's getting replaced by the BX2660, that would explain the lower price if it's a discontinued tractor.
/ Which one should i buy ? #17
200TrueBlue,
I dug out dozens of 4 to 10 or 12'' trees when I grubbed 6 tents of an acre with the BX23.
I was pleasantly surprised by the BX23 performance.
Worked very well.
The last haul to the dump was 27 stumps left after I had burnt 5 huge piles of brush trees saplings and stumps..
L . B .
/ Which one should i buy ? #18
I know I am a Mahindra dealer, but I just thought I would put in my 2 cents. The Mahindra 2216 is probably the closest comparison to the Kioti CK20 that is on the market. The BX Kubota is really a lighter smaller machine and not really a apples to apples comparison. Any how I certainly wouldn't rule out that Mahindra. Performance wise I wouldn't think twice about working it side by side with the CK20, and durability wise the Mitsubishi made Mahindra 2216 will take a back seat to none of the competition. I have a lot of respect for the Kioti and the Kubota but the Mahindra is everybit as much tractor as they are.
/ Which one should i buy ? #19
If you plan to trailer the tractor, take weight into consideration. I'm not sure what these tractors weigh with the implements you'll be hauling to the cabin. And don't forget, you need to include the weight of the trailer when towing.
/ Which one should i buy ? #20
The Kioti is a bigger tractor, but since you are considering a Kubota Bx, have you looked at the Massey Ferguson GC? I finally got to a dealer to look at them the other day. I've got prices of $17,000.00 with the loader, backhoe, block heater and loaded R4 tires. The dealer I went to also sells Kubotas, and they showed me something about the difference in hydraulic pumps. The MF will lift itself off the ground with the buckets at a dead idle. The BX's will not. I've also heard that parts for the MF were expensive, but (at least in this area) they are cheaper than Kubota and Deere.
2021 Mac Trailers T/A Walking Floor Trailer (A64556)
2021 Mac Trailers...
2021 JOHN DEERE 17G EXCAVATOR (A65053)
2021 JOHN DEERE...
2025 MACK GRANITE GR64F DUMP TRUCK (A63276)
2025 MACK GRANITE...
2026 MACK GRANITE GR64F DUMP TRUCK (A63276)
2026 MACK GRANITE...
2012 Kenworth T660 T/A Sleeper Cab Truck Tractor (A64194)
2012 Kenworth T660...
2024 CATERPILLAR CP56B PADFOOT ROLLER (A65053)
2024 CATERPILLAR...
