BX2750 snowblower
/ BX2750 snowblower #101
Dyer,
That's where I initially starting pulling out the rust, from inside the feet attaching holes. The holes themselves weren't bad, and the metal that forms the back of the thrower in that section is plenty thick, where the potential problem is, is the thinner ( like half as thick or less) metal that makes up the lower inside of the auger section of the unit, that forms the front of the triangular hollow area. One quarter size hole right through, and other areas looking like they are getting soft. Luckily it's just flat plate with plenty of clearance to the auger. I could easily make up a patch sheet and weld it right over the whole lower auger cavity piece.
I bought the BX2200 used with the thrower, 2002 I think the BX is, with 550 hours, thrower looks about the same age. Totally acceptable wear and rust everywhere except inside that hollow area. This is only my second winter with the tractor....looks to me like snow/water/salt is entering the hollow area from the two 1" or so diameter drain holes underneath that section.
JohnnyB
/ BX2750 snowblower #102
I'm looking forward to seeing a picture of it when you get it back. The Powder coat will offer up rugged protection and is a good way to go...especially at that price! :D Dyer, retired
Well, the orange isn't close to Kubota orange but it'll do (a little grease and dirt and it will blend right in.) The setup works like a charm. I had about 4 inches of snow and slush to give it an immediate tryout. Did my neighbor's driveway too.
The hydraulic hoses cost me about $100. I should have asked the guy how much before I said to make them. They are high quality and no adapters required. I played it too tight on the length. They work -- but they just make it with but a little play to spare. No problem lifting the blower because it tilts it back and gives me more slack. I "ballparked" the length while the blower was at my son's shop. Stupid of me, but I lucked out.
I used a soft aluminum screw to connect the worm gear. The hope is that if I go too far rotating the chute that the screw will break before the worm gear does. I'm thinking I may remove the chute and cut more notches so the chute can do a full 360 so I'd get a wake up call if I rotated too far, but no breakage.
Here's some pics -- and thanks for all the help!:)
/ BX2750 snowblower #103
Huck,
Excellent looking setup and I especially like the motor mount! It's compact, strong, and looks like a factory installation. As I said before, it sure shows when a good machinist gets working on something. The paint is close enough and the powder coat job looks professional.
I probably mentioned that I cut notches in the chute base all the way around, so I can turn the chute through 360 degrees. I will never turn the chute all the way through 360 degrees, but figured if I hadn't cut the slots all the way around, I would eventually hit the stop and tear the worm out...Murphy's law and all. I read other threads where guys have ripped the worm gear apart doing that and the motor never hesitated, so I thought notching the base was the quickest and easiest answer. If I had it to do over again, I'd have the machine shop do the notching....mine works fine, but I wouldn't enter it in any beauty contest.
It looks like your hoses will be fine as they are and if you got nervous about it, adding two 45 degree adapters to feed the hoses straight back would free up an extra couple of inches for you. I didn't remember the hoses being expensive, but the quick connects price was surprising.
It sounds like you aren't experiencing any trouble with the stick movement? When you push to the right, the chute turns right....you can feather it, etc.?
I'm very impressed and think you'll like it much more than the old hand crank setup you had. Congratulations! John
/ BX2750 snowblower #104
Dyer,
JohnnyB
JohnnyB,
Thanks for the clarification. I'm going out in a few minutes and lifting mine up for a quick look. I think I will follow your suggestion and load that area up with whatever spray rust inhibitor I can get up in there. I bought my tractor and blower in 2003. We don't have a lot of salt issues here, but I think that any moisture allowed to sit in there would probably be bad....just never thought about it before. Thanks again. John
/ BX2750 snowblower #105
Huck-
Very clean setup .... doesn't that PYO about not getting the hose length perfect!
Given the look of strain on the hoses near the quick couplers, I would consider threading in some right angle adapters coming out of the hydraulic motor. I bet you would end up with 3 or 4 more "effective" inches of length on the hoses and I would be willing to bet several more years of life from them.
Nice work.
/ BX2750 snowblower #106
JohnnyB,
Started to do some patch welding on it today....and..well, that whole front panel that forms the front of the hollow triangle section is going to have to be replaced. When I started removing paint for welding I found the metal to be holed in numerous places. Come spring time I'll remove the augers, cut out that whole section, paint the inside of the hollow area, weld on a new stainless front plate. The whole unit looks to be a 7.5 out of 10 at a casual glance, I would never have suspected this level of rust anywhere on it. It appears that when the first hole is worn/rusted in the center of this area the auger proceeds to shove salty snow through it to the inside of the hollow area, acclerating the whole process.
JohnnyB
/ BX2750 snowblower #107
Huck,
John,
I know I read somewhere about notching it to turn 360!:) The only thing I recall is a response that said "I can't because the hoses from the hydraulic chute deflector would wrap." and I thought "well, I don't have that problem."
I don't want to push my luck at my son's shop, but I'd prefer an experienced machinist to make the cuts. Maybe I'll just take the chute off and bring it down and ask for some quick advice on making the cuts. ;)
The stick movement is fine. I need to go to the far right (beyond the detent) when moving the chute to the right. It didn't take much getting used to. In fact, the only thing that was a little odd was when I first started to use the new setup. I felt like something was missing. It was too easy! :)
/ BX2750 snowblower #108
Huck-
Nice work.
Paul,
First of all, I love your avatar. It reminds me of my granddaughter. Beautiful little girl.
Yes, it does PMO that I didn't add 6" to the length of the hoses. I was thinking that I didn't want the hoses drooping down on the tires (like the quick hitch hydraulics can do if you don't tie them up on the frame.) I played it too close.
The guy that did the hoses forgot the dust caps for the quick connects so I'm heading down there today to pick them up. I'll ask him about the right angle adapters.
Thanks for the feedback.
/ BX2750 snowblower #109
Paul,
Paul, here's the pic I was thinking of when I said your avatar reminded me of my granddaughter. See what I mean? Have a great Thanksgiving all!
/ BX2750 snowblower #110
John,
I think if I had to notch my chute again, I'd have it done by the machine shop. Just to clarify, I will probably never rotate the chute around 360 degrees, but I wanted the notches there, so if I went past where the previous stop would have been, I wouldn't tear the worm gear out. I figured that I would be rotating the chute some day and get distracted just long enough to hit the stop and cause big damage, so I went ahead and notched the base. I guess if you had a hydraulic or electric chute deflector, you could not rotate 360 degrees...even if you wanted to.
In the meantime, you're ready for the white stuff and have a great looking modification to help you do it. John
/ BX2750 snowblower #111
Exactly. I too am a firm believer in Murphy's Law. I almost rotated the chute too far this morning as I handled the snow at the end of the driveway. I always turn the chute as far as I can to blow the snow back toward the lawn instead of into the road. I don't want to take a chance on blowing that worm gear.
Have a happy Thanksgiving. And thanks again for all the assistance.
/ BX2750 snowblower #112
Dyer,
How powerful is that motor?
I see this question was discussed before I read all 12 pages (What happens if you look the other way and neglect to stop the rotation? Besides a face full of snow, are you not worried about twisting off the chute?:eek:)
Is there such a thing as a low power hydraulic motor with rotation "STOP" screws?
Nice setup.
/ BX2750 snowblower #113
I've re-welded at least two Kubota snow thrower worm drive screws in the last year. Notches all the way around are a good idea.
My first day using the machine this year I caught myself almost over rotating at least two or three times. I gotta cut some notches.
JohnnyB
/ BX2750 snowblower #114
Dyer,
Nice setup.
Thanks! I had fun doing the project. I've included the specs for the motor below (copied from Surplus Center site.) They make relief mechanisms for purposes of saving the worm gears, but as Dataway said, it was just easier to cut the grooves and not worry about hitting stops. John
3.2 cu. in. WHITE HYD MOTOR
New, White Hydraulics roller stator motor. Model RS200050A1802. Compare to CharLynn S series.
SPECIFICATIONS Disp. 3.2 cu. in. / rev.
Motor Type Geroler
Pressure:
1750 PSI cont.
2000 PSI int.
Torque:
730 in-lbs. cont.
840 in-lbs. int.
Speed:
400 RPM cont.
490 RPM int.
Flow:
6 GPM cont.
10 GPM int.
Rotation Reversible
Mount 2 bolt SAE A
Shaft 1" dia 6 tooth spline-tapped 5/16-18 UNC
Ports 1/2 BSPP
Case Drain none
Size 5-1/4" x 5-1/8" x 4-1/4"
Shpg. 18 lbs.
/ BX2750 snowblower #115
Huck,
Dyer,
How did you cut the notches in the chute base??? I have the electric motor set up each time I go too far I blow the fuse, a pain to have to pull the fuse and replace each time I have done it. I do not have access to a machine shop, so it is up to me to make the notches...suggestions??
/ BX2750 snowblower #116
Dyer,
I cut mine with a 4 1/2 inch grinder and cutting wheel and smoothed out the troughs with a Dremel tool and sanding wheel. It was pretty awful looking! Then I figured out that if I drilled a hole where the deepest part of the groove trough should be and then use the cutting wheel to make my angle cuts into the drilled hole, it came out much cleaner. If I had it to do again, I'd take the chute off and take it to a machine shop to have it done. Mine works just fine and serves the purpose, but it looks pretty amateurish. People look at it and never notice, but I do....you know how that goes! John
/ BX2750 snowblower #117
Hi Guys - just been pummelled with snow up here ( blown 12 times to date - close to 4 feet total) and have not moved forward with my upgrade yet... still doing the manual crank. Congrats Huck on that install it looks great! I am really jealous.
I picked up my hoses today - Hoses were only 10 bucks each but the plumbing fittings really add up. I added the 90's at each end.
Just need to built my mount now but at this rate it is not going to happen until next summer. I think I will now wait for a shop to do it after seeing yours Huck. LOL:)
/ BX2750 snowblower #118
We've been hit a few times. Not a lot of accumulation -- just enough to give me a little tractor time.
I opted not to go for the BSPP elbows in that they cost $25 apiece at Discount Hydraulic. Instead I used couplers and 12" hose extensions to give me a little more play in my lines. I had the guys at my son's shop grind the chute so it could rotate 360 degrees. It looked perfect. I was all set. I turned on the tractor and tried the chute rotation. Bang! Something hung up. It broke the worm gear and bent some teeth on the chute (powerful little motor). So I brought the blower back to them to see what they could do. In the meantime, I priced a new chute and worm gear just in case ($125), I'm sure the guys at my son's shop were thinking "how did we ever get ourselves into this?" Anyway, they welded the worm gear and pounded the chute back into shape.
Everything works fine now.
I can really get some work done in a hurry with that chute rotation but I have found myself working a little too fast on a couple of occasions -- looking off in some direction while turning the tractor and rotating the chute. I've caught myself about to get a face full of snow on a couple of occasions. I can almost hear Mr Murphy chuckling "Not yet ... but soon!!!" ;)
/ BX2750 snowblower #119
By the way, the snowblower worked great during our recent ice storm. I managed to keep my driveway clear while everything else was getting a coating of ice. On Friday night, the storm subsided and the sky cleared revealing a beautiful full moon lighting up the ice covered landscape. I took a couple of photos. Merry Christmas!
(Brian)
/ BX2750 snowblower #120
Back in 2005 a guy named Junkman also made the same type of hydraulic turning device for his BX2750.. I remember reading about it after reading this thread. Here is a link to this old post.
2013 Freightliner M2 106 Altec TA45M 44ft. Insulated Bucket Truck (A60352)
2013 Freightliner...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2004 Subaru Impreza AWD Sedan. (A61569)
2004 Subaru...
MASSEY FERGUSON 231 TRACTOR (A62130)
MASSEY FERGUSON...
2025 Pabreak Hydraulic Brush Cutter Skid Steer Attachment (A61567)
2025 Pabreak...
Hilti TE 2000-AVR Electric Jack Hammer (A60352)
Hilti TE 2000-AVR...
