How to recharge an Optima battery?
   / How to recharge an Optima battery? #21
No need to raise the war budget.;) I'll let Optima describe their own product.
The Optima Edge
I'll also say that my main application for my Optima is my tractor that had a regular lead-acid battery that seeped acid and acid vapors. Those vapors got drawn through my radiator and rusted the whole battery shelf. That caused a lot of damage to my tractor (pictures on request). I had to replace the radiator and HST cooler lines under warranty. The Optima ended that problem: no leakage, no damage, perfect starting. I'm a happy Optima camper.
Red or Yellow? I may do the same for out MF 35, and 1523. Yellow top for the deep cycle features.
I'm not saying it's true or not or good or not... but read about their blue topped batteries also. Guy in store said it was the best of both worlds. Also, being marine grade, that it (the one I was looking at) was THE strongest battery they had of any of them (red/yellow/blue)
Optima Blue Top Marine Batteries
   / How to recharge an Optima battery? #23
On my PT, they do not have a glowplug, so you have to crank, and crank, and crank... When this battery dies I am over to the Yellowtop (It is on my charger, why I will never know except for ego).
But, the real question is that no one answered how to charge an Optima. I thought I had read somewhere that you wanted to use a larger charge current (not a trickle charge) with the Yellow tops. Anyone want to weigh in on the original question?
I was told to charge it like a normal/regular battery.
As an aside...I just read this http://www.dcbattery.com/optimacatalog.pdf
My guess is their yellow/blue batteries MIGHT be the same and the blues have an extended warranty (hence, cost more)
I only looked at the one I had, the blue D31M. It's CCA's are 900, CA's 1125 and ambient CA of 1,300. Virtually identical to the yellow top BUT the blue is 36 months warranty and the yellow is 24 months.
hmmmmmm.....
   / How to recharge an Optima battery? #25
I put the NAPA version of the red top in my work truck to charge rechargable batteries. I did it so as to hopefully stop the fume and loose acid issue since it is inside the rear box of my walkthru van. I was running my truck battery dead if I charged more than one battery before lunch. Two would leave me afoot. The battery isolator has kept it charged and never let me down. Note, I am on my third battery under warrany. I don't know why but 11 months is all I have been able to get out of one. So far all three were replaced no charge and given another year. I don't know what I'll do if one lasts 13 months.
   / How to recharge an Optima battery? #26
One thing if the Alternator is charging is to look for a low current load that is draining the battery I usually just disconnect ground terminal at night and look for a spark it might be real weak. if you can see it start disconnecting stuff till it doesn't spark. You can put an amp meter in series with the ground if you know how to use it.
tommu56
   / How to recharge an Optima battery? #27
What are you charging? Please describe your use in more detail.
larry
   / How to recharge an Optima battery? #28
I've used Optima for years now. What I've found on charging an Optima is like filling a 55 gal. drum with a tea cup. I've also found that 3 total discharges that the batteries won't come back to life on the 4th charge. I have 6 optima's in use now and buy nothing else. Like one post stated about battery acid, I had to replace a cruise control on a Dodge truck because of acid and had one lead acid battery to over charge and fill the radiator with acid.
I've had better results charging Optima's with a Vector charger. If you search the net(google) I think I saw an optima charger some place. I corrected the discharge problem on the one battery I tried to recharge the 4th time and haven't had any to use a charger on in the last 3 years. But the Vector charger worked better than any charger I tried.
I did a search before I submitted this post and here's a link. I haven't read it all but this may help.Optima Battery Charger
   / How to recharge an Optima battery? #29
This is from Optima's website:
Recommended charging information:
Alternator:
13.65 to 15.0 volts, no amperage limit.
Battery Charger:
13.8 to 15.0 volts, 10 amps maximum, 6-12 hours approximate.
Cyclic Applications:
14.7 volts, no current limit as long as battery temperature remains below 125ーF (51.7ーC). When current falls below 1 amp, finish with 2 amp constant current for 1 hour.
Rapid Recharge:
Maximum voltage 15.6 volts (regulated), no current limit as long as battery temperature remains below 125ーF (51.7ーC). Charge until current drops below 1 amp.
Float Charge:
13.2 to 13.8 volts, 1 amp maximum current, time indefinite (at lower voltage).
All limits must be strictly adhered to.
Safety Information:
Always wear safety glasses when working with batteries.
Always use a voltage regulated battery charger with limits set to the above ratings. Overcharging can cause the safety valves to open and battery gasses to escape, resulting in premature failure. These gasses are flammable! You cannot replace water in sealed batteries that have been overcharged. Any battery that becomes very hot or makes a hissing sound while recharging should be disconnected immediately.
Failure to fully charge a battery can result in poor performance and a reduction in capacity.
   / How to recharge an Optima battery? #30
Will, I went with the Red top because I have no discharge problems on my tractor. I only needed a starting application, no deep cycle. Also, at the time I bought it, Sams Club had a sale and I got it for less than $120.
Here is a picture of my battery shelf before the Optima and a picture of the Optima installed. The reason I have a battery box is that I added that to keep the OEM battery from spewing acid. It worked, but finally the OEM battery just died. I replaced it with the Optima.
My Optima has been in my tractor since August of 2006 and has worked flawlessly. Notice that it is not only in the box, but I also have it sitting on carpet padding and there is about 1-1/2" of carpet padding in the front of the box. That probably reduces shock, or at least it can't hurt.:)
54in Loader Fork Attachment (A59228)
54in Loader Fork...
Westendorf TA-29 Loader (A59814)
Westendorf TA-29...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A59230)
Pallet of...
2007 FELLA SM350 3 PT DISC MOWER (A55315)
2007 FELLA SM350 3...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
