Ballast ballast box and quick hitch
/ ballast box and quick hitch #1
rtm038
New Jersey
Hello all,
How much do the JD ballast boxes usually cost? Also, has anyone bought one of those non-JD quick hitches, like the ones on Ebay? If so, how do you like it?
Thanks,
Ryan
/ ballast box and quick hitch #2
The JD ballast box's are about $220.00 or so now do the the price of steel. I have the real I-Match myself and wouldn't buy anything else. There are LOTS of threads about the ones from Horrible Fright and others like the Speedco unit that TSC sell if you do some searching...
O.K. I'll have to do some searching on the other brands of hitches
Thanks
Ryan
/ ballast box and quick hitch #4
I had a Deere I-match, sold it and bought a Speeco quick hitch from Tractor Supply. No doubt the Deere hitch is prettier, with a better quality paint job, and they cleaned the welds up nicer, however, the Speeco unit is just as stout, and ADJUSTABLE. The Speeco unit also came with the u-shaped upper link that allows you to adapt non quick-hitch ready items to your quick hitch. I've got a finish mower and a rotary cutter that I use with this upper link, they work great. For everything else, I toss the hook on. If you have an implement that has a higher or lower top pin, you can move the hook up or down. So, if everything is "I-match" compatable, no reason you can't go with the I-match. If you need some adjustability, go with the Speeco. BTW, I think the harbor freight unit is probably made by Speeco. The fitment problems folks had with them was due to the fact that they offered two units, one of which was an inch narrower, which was too narrow based on cat 1 specs.
/ ballast box and quick hitch #5
Not to start a war-but in my way of thinking the "adjustability" of the Speedco and the HF unit makes it not a "quick-hitch" if it needs to be adjusted to fit different implements. For me-modifying the implement once to fit the ASAE standard is a better solution, or if your starting from scratch just make sure the new implement meets it assures you won't have to adjust anything-making for a true "quick-hitch"
/ ballast box and quick hitch #6
I have the i-match and had to mod a few things but now they all work, also got a harbor freight unit for an older machine, fairly well built but not compatible with the bushings used for i-match mated implements, had to take 1/4" + from the lower j-hooks opening and 1/8 from the top hook. not an easy task! I wanted to be able to use all implements with both tractors.
Worst thing about the HF unit is the way that top j-hook is made adjustable, with the 2 bolts it is impossible to engage the top pin on my JD blade and my landpride rake, had to remove the bolts and just force oversize pins in their place that do not extend outside the top j-hook mounting members.
As far as that special link needed for the mowers goes I now understand the issue, it doesn't affect me but I see why some would not be able to use the i-match.
I was grinding the lower j-hooks again today, if I knew how much work I would have to do I would have just spent the extra money for the i-match.
Overall I'm OK with the HF QH as it only cost 79. I think i-matchs are close to $250. now.
JB.
/ ballast box and quick hitch #7
I have had the iMatch and both Harbor Freight cat 1 models. The 27.5" HF model is the best in my opinion (the original is 26.5 which is too narrow). I returned the iMatch because you have to have adapter bushings for everything and that is a pain when you have no local supplier - my dealer had none of the right width on hand for even the Frontier box blade they sold me, and the finish on it wasn't that good - lots of rust. I replaced the bolts holding the top hook on the HF with pins to make it easy to adjust, although I don't need to - and no special bushings are required.
/ ballast box and quick hitch #8
No war, you're right, it does make it non-quick hitch in a sense, however I don't have the means to modify my equipment, and I also like buying used rather than paying the bloated prices for Frontier equipment, so I have a couple of things that are not quick hitch compatable out of the box. Actually I do have a Frontier finish mower, which does not have the quick hitch kit on it (that is a $200 option by itself). With the top link adapter on the Speeco hitch, I can use that finish mower. Can't do that with the I-match because the top link adapter would hit the J-hook on the down stroke, since the hook is not removeable.
Big thing for me is the Speeco, while not truly a "quick hitch" in the sense that I need to adjust the hook, still makes life very easy, never have to adjust sway links, and with about 30 seconds of prep work I can switch between all of my implements.
/ ballast box and quick hitch #9
In my opinion there are two options:
1. Be prepared to modify things and use an iMatch
2. Cover the bulk of the quick hitch issues and get Pats Easy Change hooks
For me it's always been quality over price, so the iMatch would be my choice because it's built to the ASAE standards while the others usually require some fine tuning with a large sledge hammer. The Landpride clones with the adjustable toplink support are nice, but they still don't allow for different sidelink widths and if I need to make an adjustment anyway it's just as easy to hook up a hydraulic toplink (and more fun, I get to play with levers!). With Pat's I can back up to the equipment and connect the sidelinks from the seat and then I just need to connect the toplink - I don't change implements enough to bother with modifying my stuff but it's still on my list of things to do.
/ ballast box and quick hitch #10
I have an iMatch and love it. Since I bought most of my stuff when I bought the tractor, I just made sure to get attachments that were compatible (Frontier). As for the two things I have that are not compatible (KK rake and carryall) I made an interface adapter that goes between the attachment and the iMatch.
/ ballast box and quick hitch #11
The i-match in Canada was way more that 220$, something like 500$ I think. I bought a Speeco and have been pleased with it. I will need to modify a couple of implements to make them work, but that wouldn't be any different with a Deere.
I've seen the Speeco advertised for 89$ US, which is a great deal. If you don't like the color, blast it and paint it.
Speeco also makes the adapter bushings that make the connection interface much more stable, and are a good idea. Somewhere on TBN I have written the info for both CDN and US distrubutors.
-J.
/ ballast box and quick hitch #12
Personally, I would go with Pat's Easy Change [mine is great] and I wouldn't bother with the JD ballast box. I would get a Rubbermaid trash can, or oil drum, pass a drawbar through it, drop some scrap steel plate in the bottom and fill the rest up with concrete. Oh, and before filling it, I'd put some casters on the bottom so it can be rolled around the shop.
/ ballast box and quick hitch #13
This is the problem I referred to about the adjustment bolts I had to remove because the got in the way on the blade and rake. they would not allow the upper j-hook to engage the upper pin as the bolts obviously wouldn't fit in that channel where the upper pin is.
I was surprised as aren't many implements designed the same way with the mounting of the upper pins in a channel type frame?
JB.
/ ballast box and quick hitch #14
I have had the HF quick hitch for about 2 years with no problems. I currently only have a ballast box so I have not had to alter anything. Painted green...looks like an I-match (maybe little bulkier) If you only have the ballast box I see no reason to spend the extra money. Put it towards another implement. Either way from following the posts here if you get more implements plan on having to modify something no matter which hitch you buy.
/ ballast box and quick hitch #15
I am looking into wheel weights or bb myself.My roto tiller gets too beat up to use it as ballast and I need more weight than my back blade for pushing snow with the bucket.
I have seen the King Kutter quick hitch on the shelf at the local Fleet Farm but for a difference of $20 I bought the green one from JD. The KK unit looks okay.
/ ballast box and quick hitch #16
I do the same thing, if the JD is close in price, I will but the JD, but if not, nope, i will go with a good aftermarket version. Like the Horst Pallet Forks I got.
/ ballast box and quick hitch #17
I have the iMatch, tiller, ballast box, 45 (?) gallon sprayer, and a knock off rear blade.
The tiller came with iMatch bushings (or with the iMatcth, I bought them the same day) but the bushings for the tiller do NOT work with the ballast box, they do work with the sprayer.
I tried the hitch from the Tractor Supply Store, and returned it the next day. not even close to fit on ANY of the implements.
The only issue I have is the rear blade is from TSC and is not compatible. Have to find a way to make it compatible.
I love the iMatch, and makes my life a LOT easier... going to John Deere today to buy the bushings for the Ballast Box, and another set of "tiller like" bushings for the sprayer.
What REALLY sucks is the dealer is 1/4 of a mile away, and have to drive by it EVERY day to go anywhere. Now keep looking at new BIGGER tractors every time I drive by, or the new backhoe they just got in.. or any of 100 different items I'd like that I see in the grass when I drive by.
/ ballast box and quick hitch #18
The bushings at TSC are a third of the cost from JD and in my opinion are better made.
I made an adapter for my KK Carry all- so that I can use my I Match. From what I have learned - by error and not by research here- is that the top hook on the I Match is 15" from the center on the lower pins ( this is ASAE standard)
It appears that some manufactures including KK do not always comform with this standard. I have heard this standard was self imposed by JD -I cant confirm this- interesting never the less.
My adapter thread :
http://www.tractorbynet.com/forums/attachments/163244-king-kutter-carry-all-i.html
2021 JCB 35Z-1 Mini Excavator (A64553)
2021 JCB 35Z-1...
2005 CATERPILLAR 416D BACKHOE (A65053)
2005 CATERPILLAR...
2016 Komatsu WA320-8 Articulated Wheel Loader (A64553)
2016 Komatsu...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2015 Ford F-450 4x4 Crew Cab Utility Flatbed Truck (A64556)
2015 Ford F-450...
2021 Chevrolet Silverado 2500 HD Royal Service Truck (A64194)
2021 Chevrolet...
