59" snowblower 2520 compact
/ 59" snowblower 2520 compact #1
biyou
John Deere only shows a 47" front snowblower to fit a 2520 compact the trouble with that is it doesn't cover the tires I have a 59" I bought off eBay
and I want to put it on my tractor. Any ideas ?
Thanks biyou
/ 59" snowblower 2520 compact #2
Welcome to TBN:D
To my knowledge, this has never been done by anybody here on TBN-discussed a few times but never done...
You will have to fabricate the front hitch, as well as the front PTO hanger to get it to work...Being able to see in person both setups would probably help immensely, as well as proficiency in navigating through jdparts.com also.
/ 59" snowblower 2520 compact #3
biyou
take a look at the front quick-tatch "m01471x" on the jd parts site. there is a chance it could work
the box around the gearing on the thrower should have a 1" dia stud sticking out either side on the upper back corner and a 3/4" hole below to receive pins
you will also need the front pto kit which extends the mid pto up front via a driveshaft and pivot going upfront
lookup jd part number AM124588 it is the frame that is part of a "quick-tatch"
the part # are for ideas only
tkoza
Welcome to TBN:D
Thanks biyou
biyou
tkoza
Thanks for the reply Biyou
2006 Ford F-450 Crew Cab 9ft. Stakebody Flatbed Truck (A66736)
2006 Ford F-450...
2004 FRAC TANK 500BBL WHEELED (A68842)
2004 FRAC TANK...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A66734)
2025 Kivel 48in...
PORTA POTTY (A67714)
2007 PETERBILT 378(INOPERABLE) (A67714)
2007 PETERBILT...
UNUSED SDLANCH SDL2030GT-20' X 30' PREMIUM HEAVY (A64281)
UNUSED SDLANCH...
