How much does that dirt weigh? or, Overloading 101
/ How much does that dirt weigh? or, Overloading 101 #1
allen in texas
Levelland, TX
Kubota Grand L 5740, loaded R1's w/640 lbs cast weight, 854 loader
I hauled three loads of topsoil this weekend in my new dump trailer. I knew that I couldn't just fill it up but man, I never knew I was going to get this much weight on it so quickly.
I weighed a load just for grins.
The combined weight of the truck, trailer and dirt was 24,900 lbs
I dumped and weighed again.
12,720 lbs
12,280 pound of dirt on the trailer.:eek:
This trailer is rated at 14000 lbs gross and weighs 5000 lbs itself.
I was about 3280 lbs over loaded.
Dumped it just fine though.
I need to be more careful when I load it from now on.
/ How much does that dirt weigh? or, Overloading 101 #2
I'm glad you discovered this early in the game.
I was in a similar situation many years ago. I worked for a small printing company in Ames, Iowa and as part of my duties, drove a Volvo straight truck hauling six or so 2700 lb skids of paper from Des Moines. The truck was rated for 29,000 lbs, but licensed for 26,000.
One day, just for kicks, I weighed the empty truck at the recycle center. It was 16,500 lbs. That means I was running over 32,000 lbs!!!
I'm guessing that is enough over to make the DOT officers really fussy. It was just dumb luck that the scales weren't open when I was that loaded.
/ How much does that dirt weigh? or, Overloading 101 #3
I made the mistake of asking how much sand I would get in a ton if it was wet vs dry.
I got a very fast paced lecture on the perc rate through sand, when it had last rained and how the loader operator knew what he was doing and wouldn't drive into the pile at ground level.
Almost as an afterthought, how much water sand COULD retain, which was what I had asked.
I don't remember, other than it was very little.
Wet loam is a different beast.
/ How much does that dirt weigh? or, Overloading 101 #4
Anybody weighted some wet sand and then weighted it when dry? Just a small bucket show be sufficient for definitive results.:D
/ How much does that dirt weigh? or, Overloading 101 #6
Soil is about 90-125 pounds per cuft depending on soil type and moisture content. So you had about 4 to 4 1/2 yards of dirt. Sound about right?
/ How much does that dirt weigh? or, Overloading 101 #8
When I first got my 6x10 Moritz dump I got a load of dirt. It was 3 or 4 scoops from a backhoe. On the way home I weighed it at the mill. It weighed 12K+ and its a 10K trailer. I found out quick that these dump trailers for use behind pickups are really mulch haulers. Mine is very small and can be overloaded easily with sand ,gravel, or dirt. Mulch or firewood is no problem.
john bud.
At 100 lbs per cuft, I would have had 4.5 yards.
Pretty close considering how much dirt was physically in the trailer.
I dumped it in the center of the trailer until it just touched the sides.
It was not heaped, and I figured that it was half full.
The trailer, loaded level with the sides would hold 8.1 yards, so 4.5 yds has got to be a pretty good estimate.
Certainly, I will never be able to fill the trailer but as I've said, I got it the size I did so I can put my tractor in it. Still 4.5 yards is a lot of dirt.
wkpoor,
I found out quick too. :)
/ How much does that dirt weigh? or, Overloading 101 #10
If you put in too much, you press the button and nothing happens (it doesn't go up), then you are really in trouble.
DAMHIK :eek:
DAMHIK :eek:
It had no trouble lifting this load.
I'd like to load it and see how much it will lift.
Trouble is, if it won't lift it, then I have to shovel it out by hand.
I'm not sure I remember how to use a shovel. ;)
/ How much does that dirt weigh? or, Overloading 101 #12
DAMHIK :eek:
Nahhh, just lifting the front, or shoveling the back. :D
At least that is what I heard :eek:
/ How much does that dirt weigh? or, Overloading 101 #13
DAMHIK :eek:
Yeah, that's a problem! You have to drop the tailgate then back up real fast and slam on the brakes until you can shift the load and dump it.:D Or use a shovel:eek::eek::eek::eek:
/ How much does that dirt weigh? or, Overloading 101 #14
If you got the bigger trailer to haul your tractor too, just drop the gate and drive in with the loader to remove the dirt - No shovel necessary!
:D
:D
:eek: never thought of that
/ How much does that dirt weigh? or, Overloading 101 #17
The best way to find the weight of any dirt, sand, or gravel is to pick up a shovel full of it, over and over. Hands down, the heaviest muck out there is wet clay. Not only is it harder to pick up, it's harder to put down.
AMZ Spray Injection Patcher (A65579)
AMZ Spray...
Caterpillar TH255C Forklift (A63689)
Caterpillar TH255C...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
2023 TEXLINE BOBCAT HAULER (A65643)
2023 TEXLINE...
Location (A65640)
Location (A65640)
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
