Rear Blade New Rear Blade!
/ New Rear Blade! #1
Timberman444
Member
Northwest, CT
John Deere 2320
Well I finally bought a 5' King Kutter rear blade with offset and tilt, 90% of the use will be for winter snow work and then the occasional light grading of a few gravel paths. Went with the King Kutter because the price was right (compared to the frontier and others) and like I said mostly snow work, so I don't need a heavy duty blade. I work for ConnDOT so by the time I get home from plowing the roads my driveway will really need some attention. Went with the offset so that way I don't have to get the tires close to a couple drainage ditches next to the driveway as I'm plowing and risk getting stuck. I special ordered it from my local Tractor Supply and picked it up Thursday night after work. Today was the first chance I had to rig it up and attempt to test it out, I had the tractor out for about 30 seconds and it started pouring(just my luck). It has since cleared up so I played around and decided to take some pics to share with you guys. Hope you like.
/ New Rear Blade! #2
Looks good, but I can't see, what is offset? is the whole frame built slightly offset to the right/passenger side, that would make it easier to get in close. You should be all set with the 4x4 but if you think you might want tire chains, let me know I found surplus chains in our area for a fraction of usual price.
I use my 6' rear blade exclussivly for snow work, mostly pushing backwards but some pulling forwards. I put extra weight on mine to help when driving forward, back dragging blade over gravel or pulling forward thru plow packed driveway aprons, that's where it really shines.
As far as grading with a rear blade goes, it must take alot of practice, as every time I tried it I ended up making a mess, IMO a box or a rake is much easier.
I wished I had a way to power angle it, so when I got an old western plow for free I figured I'd try it on the 3PT, have to wait for some snow to try it.
JB,
/ New Rear Blade!
JB thanks for the info on the tire chains, I'm going to see how it does the first couple of storms then decide if I need/want chains for it. The blade offsets up to 12" left or right, all you do it loosen up the 2 bolts on the back of the blade and slide the blade down the "track" how ever far you want to offset. Simply tighten them back up once it is in the position you want and your good to go. These 2 bolts also control the tilt of the blade, tilts up to 35degrees I believe.
/ New Rear Blade! #4
I bought the same KK blade in the 7ft model about 3-4years ago.No problems,pretty stout blade for the $$ spent IMHO.coobie
/ New Rear Blade! #6
hey guys, just had to take a sec and put in my 2 cents worth, about the king kutter blades. JUNK!!!!!!!! i bought 7 ft model last year and used it twice, before it bent. i was back blading a round pen, and i have 2 x 12 boards, at the bottom to hold the sand in the round pen. i was blading backward, which i know is always harder on the blade, and just skimmed the face of one of the boards, and bent the blade considerably. what amazed me is it barely scuffed the board, but yet bent the blade. i know that king kutter is economy grade equipment for the most part, but geez, shouldnt they take a little more abuse than that? i am going to take a pic of the bent blade and send it to king kutter, along with a letter, expressing my disappointment and aggravation, about spending my hard earned money on equipment i had hoped to last, at least more that a week. anyway, thanks for letting me vent a little, and good luck with your new equipment......
/ New Rear Blade! #9
I have been looking at rear blades and settled on this King Kutter Blade King Kutter Incorporated
It differs some in design from yours but includes the offset feature as well.
I have that same model blade but 84" wide. It's a well made unit for the $$ IMO. I've not used the offset but the tilt is very handy. It allowed me to work on the edge of my crowned county road to make a turnout for my mailbox.
That blade is also my snow removal tool. For that job I'd like to add a hydraulic cylinder to change the blade angle.
/ New Rear Blade! #10
Looks like you are the only one that got a defictive one.:eek:
/ New Rear Blade! #12
A couple of the local hardware/farm supply stores have some King Kutters that are reinforced on the back with some ribs. They look like they would hold up well.
/ New Rear Blade! #13
I bought a KK 5' finish mower in 2004 and it was junk. I paid $900 for it new and by the time I sold it to some fool I had spent another $500 in fixing/maintaining it. It literally broke a weld, spun a bearing, had a flat, broke a bolt, shredded a belt, ect every other time out. I bought a new Caroini this spring and it did not miss a beat mowing my 3 acres. Not one adjustment, broken part, down time, ect. It was well worth every cent.
Chris
/ New Rear Blade! #14
it was the economy line of king kutter blades, but my gosh, skimming a steel blade along a pine board, causing that kind of damage, makes you wonder if these blades are just meant to sit around looking pretty, or if they should be able to be used for what a guy buys em for, WORK!!! i try to use all my equipment in a way, that gets the job done, but at the same time does not abuse my equipment, and this was definitely the case in this situation. i could see it if i had really hit something substantial, but a board? gimme a break. anyway, lesson learned on my end. good luck guys
/ New Rear Blade! #15
...makes you wonder if these blades are just meant to sit around looking pretty...
Of all of the KK blades I've seen at TSC or the local supply store, I've yet to see a pretty looking one. Chipped and weathered paint, rusty spots etc... The first time I saw them, I thought they were used. :eek:
/ New Rear Blade! #16
Not to pick on the KK brand, but you pretty much get what you pay for. Sometimes, like in the case of their tillers, you get a little more, and sometimes you get a little less. Overall I think they have proven to be a pretty good low-end (and low-priced) line of products. We have a rotary cutter that has held up fantastically well.
In this case, I have to say from the photos that the frame, both at the 3-pt and behind the blade looks pretty decent. I would however be concerned about bending the blade with any heavy use. It has very little curve to it and absolutely no support at either the top (such as a complete 90 degree bend) or at the bottom.
/ New Rear Blade! #17
Timberman, hope you enjoy your blade.
As to the person who had a KK to bend, nope he is not the only one who bought a bad one. Mine was not the light weight model either. Guess he picked up the problem with them, they seem to hold up well when nothing sudden in the load such as the board. Seems a reasonable shock load damages them. When I buy a blade of larger HP than the tractor is should be safe.
2006 Peterbilt C15 (A64127)
2006 Peterbilt C15...
GMC C7500 (A64127)
GMC C7500 (A64127)
Root Rake Loader Attachment (A59228)
Root Rake Loader...
1991 CAT 3406 Generator Set 400KVA/320KW, 480V 3-phase, 60Hz, Industrial Standby (A63689)
1991 CAT 3406...
2001 WESTERN STAR  4900E (A65643)
2001 WESTERN STAR...
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
