Quick hitch
/ Quick hitch #1
unreconstructed
West Texas
JD 5325 JD 5203 JD 2320 LT 133
I bought a quick hitch for my 5325. I thought it would fit the MX 6 but found the pins on the MX6 are a couple of inches short even with JD's expensive little adapter kit.
Anyone made a modification to make this rig up work?
Thanks.
/ Quick hitch #2
Did you buy the category I (Imatch) or a category II quick hitch??
/ Quick hitch #3
Thanks.
how hard was it to make your MX6 quick hitch compatible?
/ Quick hitch #4
I have a 4120 and a MX6 with IMatch, works great out of the box.
I beleive a JD kit is available to make them work, it is a no cost option when ordered (I think). My dealer mention something about it when I ordered.
Glenn
/ Quick hitch #5
The MX6 comes Imatch (cat I) compatible. I am wondering if on the tractor he is using he might have a cat II hitch.
You can convert the MX6 to CAT II which the OP might be referring to in his post but I do not know if the CAT II conversion makes it quick hitch compatible??
/ Quick hitch
Been out at the place the last few days. Thanks for the replys.
The quick hitch for the 5325 must be a Cat II. I have an I match on the 2320 and is not the same set up. The pins on the MX 6 are roughly two inches short on each side even with the bushing adapter set up. I had not visited with the dealer to see if there are longer pins that can be installed. Will give him a call and see.
/ Quick hitch #7
The MX6 can be converted to CAT II.
Installing Category 2 Hitch Pin Conversion Kit (MX5 and MX6)
1. Remove existing lock nut and hitch pin from masts.
IMPORTANT: During assembly, make sure bracket (B) is positioned correctly so it sits flatly at lower attaching point.
2. Assemble category 2 hitch pin (A) through hole in top of bracket (B). Fasten to mast using hardware (C-E). Leave loose.
3. Attach bottom of bracket to mast support using M16 x 45 flange-head cap screw (F) and lock nut (G).
4. Tighten all hardware to specifications. Specification
Hitch Pin Nut (D) -Torque 590 Nキm (435 lb-ft)
A-Hitch Pin
B-Bracket
C-Washer
D-Flange Nut
E-Bushing
F-Flange-Head Cap Screw, M16 x 45
G-Lock Nut, M16
/ Quick hitch
That's for that info. Called the parts man--he had to go to the salesman to get the kit number. Will run just a little over 100 bucks. Seems like its sort of a mystery to all the salesmen how to get frontier and JD equipment quick hitch and I match compatible at the time of the sale. Its a little irritating, but I suppose a lot of the rig ups are not done that often.
Lincoln SAE-400 Shield-Arc DC Arc Welder - Inoperable (A63689)
Lincoln SAE-400...
2008 Kubota RTV 900 4x4 Fire Rescue Diesel Utility Cart (A61572)
2008 Kubota RTV...
2017 FORD F-450 XL BUCKET TRUCK (A58375)
2017 FORD F-450 XL...
POWELL / COLE 6R RIPPER (A63291)
POWELL / COLE 6R...
1986 Ford LN8000 Fertilizer Truck, CAT 3406 Engine, Ag-Ready Workhorse (A63689)
1986 Ford LN8000...
REDDICK OFFSET DITCHER (A63291)
REDDICK OFFSET...
