Tire loading adapter?
/ Tire loading adapter? #11
Well someone feels my pain! I had the part num and all, from old posts here, go into TSC, they look at me like I had buggars on my face? That was why I was figuring I could get it at Napa, they have a huge warehouse here, I just can't get them to find it either? Thanks For the help. If I can't find the Napa num, I will wait a week or so and try TSC again.
Thanks Bob
THE TSC MODEL IS CRAP! (Made by Slime, I think)
I purchased the adapter a few months ago from TSC. Finally got around to using it this weekend. Here is what I went through to get it to work.
  1. The "hose end" threads were cut for a 3/4" NPT pipe fitting NOT a standard garden hose fitting. :confused:
  2. I tried to return it for a new one at TSC (1/2 hour car ride, one way) but they did not have any in stock. :mad: So I decided to try to make the one I had work.
  3. Back in the shop, I dis-assembled the adapter and replaced the "hose end" with an old garden hose end splice kit. ;)
  4. Next problem was that the adapter for the valve end would not make a tight seal. The little adapter piece was cut too long and the threads bottom out before compressing the seal at the bottom.:confused: Thus causing it to leak leak all over.
  5. I was able to stuff a couple extra o-rings in the bottom of the adapter and get an OK seal but it still leaked a little.
Glad that ordeal is over. Now my tires are finally filled.:D No thanks to TSC and their lousy products and horrible inventory practices.
/ Tire loading adapter? #12
Just curious what you filled your tires with? Also how did you go about transferring the fluid from a bucket to the tire?
Chris
/ Tire loading adapter? #13
Just curious what you filled your tires with? Also how did you go about transferring the fluid for a buck to the tire?
Chris
If you're asking me:
I loaded 22 gallons of -20* rated WWF into each tire using this:
Shur-Dri Electric Sponge Pump, 115 V AC from TSC - sku #3124976
/ Tire loading adapter? #14
Thanks. I have seen them there and Harbor Freight.
Chris
/ Tire loading adapter? #15
Was the POS kit the Monkey Grip one???
The one coming onto stock is different...
/ Tire loading adapter? #17
Yay.
THX Nate.
Lunk
/ Tire loading adapter? #18
I thank you I thank you I thank you!!!!!
I will be at Napa tomorow AM!
/ Tire loading adapter? #20
I use an adapter I got from Gemplers with a short piece of garden hose and an old boat bilge pump bolted to a piece of scrap metal sitting in the bottom of a 5 gal pail. Work slick. Fast and easy!!
6 New Sealed Apple Ipads (A59317)
6 New Sealed Apple...
Qty 3 Skid Steer Forks (A59317)
Qty 3 Skid Steer...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55315)
2012 KINZE FLAT...
Kalamazoo Abrasive Mitre Table Saw (A59317)
Kalamazoo Abrasive...
2016 Ford Fusion S Sedan (A59231)
2016 Ford Fusion S...
1998 Mazda B2500 (A57149)
1998 Mazda B2500...
