BX 2230 3pt hitch question...
   / BX 2230 3pt hitch question... #1
Tags
Connecticut
BX2360/ Kubota SVL90-2/ Kobelco 115SR/ Takeuchi TB260
I recently bought a PTO operated leaf blower for my BX and I'm wondering if it is possible to keep the three point hitch in the raised position while still operating the mid mount lift for the mower deck. Also on a totally unrelated note, I can't seem to get the mower deck to lock into the "Top" position when its raised all the way, I can only get the knob turned to the 4" marking, Any thoughts or ideas would be greatly appreciated.
   / BX 2230 3pt hitch question... #2
I have disconnected the lower trailing arms and connected them to the 2 stationary points near the 2 real lift arms. Its just 2 holes in flat stock near the rear fenders.This allows the 2 lift arms to move with out moving the implement, I can try to get a picture tomorrow.
I think I understand but a pic would be great too, thanks.
   / BX 2230 3pt hitch question... #4
Chain up the 3pt hitch.
Remove the adjuster for the deck and grind about 1/16" off the top "step"
   / BX 2230 3pt hitch question... #5
I didnt get a chance to get a picture this morning of my machine before heading into work. But here is a shot off the web with the area highlighted
qT-gR5El20jA6ORCyXGnfA
Picasa Web Albums - Matt - Tractor
The green circle is the area where you can put the arms so they dont move
   / BX 2230 3pt hitch question... #6
I had the same issue when my BX1850 was new. Standing behind your BX (and assuming it's the same as mine) there should be a long rod pointing down and toward the front of the tractor at the top left side of the 3PH with an adjusting nut on it. The nut limits the motion of the deck lift arms. I forget which way you need to turn it, but adjusting that nut should let you rotate your deck height knob to the "Top" position. Good luck.
Perfect, thats what I thought you were talking about. I knew I'd get some answers outta you fellas...
2012 DIAMOND C  40FT GOOSENECK TRAILER (A58214)
2012 DIAMOND C...
2016 UTILITY 53X102 REEFER TRAILER (A59905)
2016 UTILITY...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
2006 CATERPILLAR 242B SKID STEER (A60429)
2006 CATERPILLAR...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
VOLVO A25G OFF ROAD DUMP TRUCK (A60429)
VOLVO A25G OFF...
