Antifreeze "bad" for engine bearings?
/ Antifreeze "bad" for engine bearings? #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
I presume the answer is yes so let me clarify the question...
We've got an International 866 (or 886?)
Regardless.... seems it's leaked its water/antifreeze into the crank. Discovered it a couple weeks ago.
On a lark, we thought.... what happens if we drain everything, put new oil in (done) and refill radiator with water (done).... "how fast does it lose the water into the engine????"
I cut two fields over this last weekend and can't tell AT ALL that the water level has dropped. So the leak from the radiator to the engine crank seems to be more of a pinhole variety instead of a royal flush :rolleyes:
So...here's the situation:
It's not my tractor so I don't care to spend to fix it. Tractor belongs to my father in law who's too cheap to fix it....indeed, he's already thinking on selling it. Problem there is, if he sells it, he'll probalby not get another one and the farm won't get cut.
My brother in law (his son) thought.... we can probably "hobble" along with this tractor for quite a while as long as it's a pinhole type leak.... we can just put more water in from time to time. (it's only used to cut fields maybe 2 or 3 times a year)
I pointed out we're heading into winter and we don't want to have ZERO antifreeze in the water.
So.... is there something we can put in the radiator to keep the water from freezing that might not be caustic to the engine bearings?
I don't want to use plain water, especially with winter nearing
OR.... is antifreeze indeed caustic to bearings?
/ Antifreeze "bad" for engine bearings? #2
why not use some stop leak to plug up the pin holes then fill with radiator fluid ? My grandpappy used to swear by Bars Stop Leak.
I don't know if I was clear or misleading....
The leak is NOT in the radiator.... as best we can ascertain without taking the engine apart, the leak (small as it seems to be) is probably on the sleeves of the engine.
We don't know this....just our presumption given what's happening.
Side note: During the cutting of the field on Sunday, the temperature gauge BARELY got to the green. It spent the first 30 minutes almost on the far left "peg" (totally cold reading). After I got some time on it, it went halfway in the unmarked area, BEFORE the green/normal reading. AFter I was at it for a while, it barely touched and went into the green area.
I wasn't really working the engine as the field I cut was not over grown.
Would someone use 'stopsleak' (or what ever its called) for a potential leak in a cylinder sleeve? I've never heard TOO many good reports on that stuff. Seems to me if its designed to plug a leak in a radiator, it might plug a passageway? :confused:
/ Antifreeze "bad" for engine bearings? #4
I second the Barr's Leaks idea. I used it on a car with a blown head gasket, and it worked (long enough to trade it in, anyway...).
/ Antifreeze "bad" for engine bearings? #5
While I generally hate the "patch in a bottle" products, let me turn it around slightly differently,
What have you got too lose?
You should already be carefully monitoring everything, if it fails, your oil starts climbing etc. you are back to where you started needing a rebuild.
You may also have a leak that is changing or opening on temp differences.
I would say a jug of stop leak of your personal flavor would be a low cost way of possibly buying some time.
/ Antifreeze "bad" for engine bearings? #6
Very cleaer. however.. i hope you understand that your radiator is not the only thing that holds water.. if there is a small leak at a head gasket, in the head, or the block / liner.. then the stop leak -may- find the leak.
Ever hear of builders cubes.. they toss them into a new rebuilt engine to find microscopic leaks. New holland actually sells a liquid/paste stopleak that clams to seal minor head gasket issues.
I'm in the 'what have you got to loose' camp. Maybee even drain it over the winter. then refill with water and run during use..
soundguy
/ Antifreeze "bad" for engine bearings? #7
I used to work in the auto industry. For a long time every new car got a few pellets of leak stop to cut down on warranty claims for small leaks. The stuff works.
/ Antifreeze "bad" for engine bearings? #8
It's not the antifreeze that's bad for engine bearings it's the water/antifreeze(not being oil). Water is just as bad as a water/antifreeze mixture.
I work in the automotive field and every coolant repair be it a hose, radiator, intake, whatever, gets a complimentary bottle of stop leak. It not only stops the leaks you have(up to a point) but stops future leaks too. Bars(the type with pellets in it) works great in not only sealing leaks but also scrubs passage ways to keep them clean and corrosion at a minimum. Almost nothing will stop a cylinder wall leak if it's in the cumbusion chamber or if the piston rings rub past it but like other's have said... what do you have to lose? If I was in your situation I'd put in the stop leak, add antifreeze to the water so that it's at least 50/50 mix, and watch it real close. Keep checking the oil dipstick. If it looks milky the water is getting in there and it's time to change the oil. Also cut the inner rubber seal on the radiator cap that holds the pressure in the cooling system. It'll lower the boiling point of the coolant, but it'll also lower the pressure of the cooling system which will help stop forcing it in the crank case. Leave the outer seal on the cap so the coolant doesn't leak out of the system. Cutting the inner seal just lets the coolant that is expanding go into the overflow without building up pressure in the cooling system. -We call this a "patch job" or "band-aide".
/ Antifreeze "bad" for engine bearings? #9
One point ---
The coolant system will develop pressure as it heats up. That's what it is supposed to do. If you have a leak, using a radiator cap that does not build pressure will slow the leak down dramatically. If you have an old cap, you can tear out the seal. Or drill a 1/32nd hole in the top. Small enough to let out pressure, but not so large that crud gets in.
I would check the condition of the oil every HOUR. If it turns into a milkshake, time to change it.
jb
/ Antifreeze "bad" for engine bearings? #10
In short if the collant leak is allowed to continue it's going to nuke the bearings in no time. It takes a extremely small amount of coolant to destroy the plating of bearings.
/ Antifreeze "bad" for engine bearings? #11
This is the fact...now I've had some good results with a "block sealant" product..NAPA sells one..follow the directions completely, cross your fingers and keep your eye on the oil. The product purpose is for "repair is more costly than machine is worth" type patch.
Block sealants aren't "stop leak, add to coolant" type sealers. You have to get the coolant flushed out, so once again follow directions.
The worse type of internal coolant leak is this one, coolant in oil. Hopefully it's minor enough to address with a block sealant.
Like others have said, nothing to lose if no one will fix it properly.
Good luck.........
/ Antifreeze "bad" for engine bearings? #12
The pinhole variety is a killer. The system is under pressure and even if the hole is small it will be forced into the cylinder.
I just went throught this with my 1066 IH. I did all the normal things to stop the leak but before long the tractor started to overheat and blow steam like crazy. A major overhaul was needed to get it back in shape.
Water filters are important on these tractors, also timely antifreeze checks with test strips.
Thanks for the comments.
One side note, after replacing oil and water (without antifreeze for the moment), when I cut the field as per above comment, I did so with the radiator cap hooked on.
What I mean by that is, it wasn't TIGHTEND down, sealed, but it was at the 'safety catch' stop (or what ever it's called).
My logic was exactly as stated above.... reduce temp, reduce pressure and maybe reduce throughput of water into problem area.
I'll mention the stop leak idea to bro in law and father in law. It's FIL's tractor. BIL might take it to an auction this coming weekend (or next weekend as I reflect). None the less, he might simply get rid of it and bring his IH 986 with cab over for his father.
Weather permitting, I'll cut a different field this weekend to give another sample for water usage.
/ Antifreeze "bad" for engine bearings? #15
One point ---
jb
Good Afternoon jb,
Thats a very good point, and as Richard stated earlier he is trying to stretch out the longevity of this tractor without a major overhaul. Some of those stop leak products are pretty good at what they are intended for. The only problem is that if the leak is coming around the o-rings at the bottom of the cylinders, I would think that they wont seal as easily as a pinhole in the radiator. Im presuming that the larger IH tractors use the large o-rings the same way my Super A does. I remember laying on my creeper looking up at my cylinder sleeves for leaks when I had my oilpan off.
As John states, keeping a close eye on the coolant level and oil should give some temporary piece of mind.
I'm not a mechanic BUT I'm mechanically inclined.... so...
Is this to suggest the possilibty that if I removed the oil pan, it would be possible to look up and perhaps see an issue with a gasket or even perhaps something funky in a cylinder (presuming piston is on TDC side of stroke)
/ Antifreeze "bad" for engine bearings? #17
Good Afternoon Richard,
Absolutely yes ! In your last thread about engine diagnosis, maybe you missed it but RickB suggested this or something similar. Remove the oilpan and pressurize the coolant system. If the 0-rings are leaking at the botton of the cylinder walls you will be seeing green drops of anti freeze. To go one step further, as JB stated, you may also have what is called cavitation where the liners actually have pin holes on the periphery allowing coolant into the cylinders ! Obviously this is a more severe problem, because you would need new sleeves to repair it ! :( Good luck with the diagnosis !
BTW it doesnt matter where #1 piston is durring this type of test, your just checking your o-rings for potential leaks !
/ Antifreeze "bad" for engine bearings? #18
Pump up some compression on the cooling system then look up underneath with the pan off.
soundguy
/ Antifreeze "bad" for engine bearings? #19
Anyone know what these parts are?
Looks to me like the radiator is connected to what appears to be what I'd call a "muffler". There is a drain on the bottom of this as you can just see between the frame & unit.
Then you have the connection point at the back of it that goes to a "conditioner"???? (what's up with that?)
It's a CarQwest filter number 89071 if that tells anyone anything.
Then as you see, it goes from the filter to the top right.
I'm curious as to what this contraption does.
My brother in law called last night....said someone he talked to said he thought this machine had an oil cooler. He suggested THIS was it and the canister (muffler looking thing) was the heat exchanger. His contention was, it's possible that this is another place where oil/water contamination might be taking place.
As I look at this thing, I don't see any place where oil can enter it UNLESS it is simply an open port at the engine block.
I'm still a bit perplexed as to how this works if it is an oil cooler. I don't understand why there are no connectors on the right side of it. It looks like it simply slides onto those stubs (or perhaps, is part of that assembley to the right and is all one unit)
This person went on to suggest that either this "muffler" part or the oil filter itself has an anode, much like your water heater. The anode is sacraficial and helps keep the internals of the engine from being eaten up.
I've done a google search on this filter part number but don't see anything yet explaining the possiblity of it having any kind of anode.
Anyone know about this?
Edit: by "connectors" on the right side of the part, what I mean to say is something akin to a hoseclamp. Meaning, it looks to me like it simply slips together and there's nothing there to tighten the two together.
UNUSED WOLVERINE TDB-11-84W 84" QUICK ATTACH BKT (A62131)
UNUSED WOLVERINE...
2023 Ferris 500S Zero Turn Mower (A61166)
2023 Ferris 500S...
2004 Subaru Impreza STI AWD Sedan. (A61569)
2004 Subaru...
JOHN DEERE 6140M TRACTOR (A62130)
JOHN DEERE 6140M...
72in. Fork Extension (A61567)
72in. Fork...
2016 Peterbilt 579 Wet Kit T/A Day Cab Truck Tractor (A61568)
2016 Peterbilt 579...
