Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,079
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
I presume the answer is yes so let me clarify the question...
We've got an International 866 (or 886?)
Regardless.... seems it's leaked its water/antifreeze into the crank. Discovered it a couple weeks ago.
On a lark, we thought.... what happens if we drain everything, put new oil in (done) and refill radiator with water (done).... "how fast does it lose the water into the engine????"
I cut two fields over this last weekend and can't tell AT ALL that the water level has dropped. So the leak from the radiator to the engine crank seems to be more of a pinhole variety instead of a royal flush
So...here's the situation:
It's not my tractor so I don't care to spend to fix it. Tractor belongs to my father in law who's too cheap to fix it....indeed, he's already thinking on selling it. Problem there is, if he sells it, he'll probalby not get another one and the farm won't get cut.
My brother in law (his son) thought.... we can probably "hobble" along with this tractor for quite a while as long as it's a pinhole type leak.... we can just put more water in from time to time. (it's only used to cut fields maybe 2 or 3 times a year)
I pointed out we're heading into winter and we don't want to have ZERO antifreeze in the water.
So.... is there something we can put in the radiator to keep the water from freezing that might not be caustic to the engine bearings?
I don't want to use plain water, especially with winter nearing
OR.... is antifreeze indeed caustic to bearings?
