Grapple Grappling for answers on Grapples
/ Grappling for answers on Grapples #41
I agree with you guys if the primary use is clearing and removing roots the rake design would be better and less strain on loader components than trying to use an open bottom design. I am not sure why the prices for the root rakes appear to be higher than the open bottoms for same width and number of tines. Must have more material in them. Good luck on the choice. Kinda glad the selection is behind me and ready to get the plumbing fixed and move some brush!
When I pull the trigger I'll add the Kubota third valve with the button on the FEL control. My dealer seems to prefer this design over the WRLong design. Maybe because it's more expensive and he gets a better mark-up :eek:
/ Grappling for answers on Grapples #42
Happyman, I thought WR Long or perhaps another brand, but want two claw and the 66-inch width. When raking the 66-inch would cover tire tracks. I have hydraulic set up from the rear remotes already in place to accommodate my loader angle snowplow. I知 trying to stay under 2K.
With all the grapple threads, there痴 not much mention of best type for de-rooting surface roots and was unsure until just recently that the two claw operates off one hydraulic (I think).
Any suggestions on best grapple rake capable of raking?
/ Grappling for answers on Grapples #43
BillBee, check this one out: RBG
The RBG2 60 is probably the one I'll go for.
/ Grappling for answers on Grapples #44
It is too bad that almost no one gets to use both styles of grapple to make comparisons. I have an open bottom style grapple but I do a lot of root raking with it and it works fine. I do not start at one end of a field and "root rake" across like you would with a York rake however and I haven't heard of people actually using grapples that way. Mostly grapples are used to pull out individual tree stumps or bushes as well as to carry debris or logs or brush. For that purpose either style of grapple works. I like the open bottom because the bottom tines can be either vertical or horizontal to dig or get under an object and also because gravity holds the load in place once you have it in the grapple. If I were literally buying a grapple to pick up small sticks on a forest floor I can see that the clamshell style would be better but for general use I don't see that there is a significant benefit from the clamshell style to justify the extra cost and weight.
I haven't used a clamshell but the lower jaw is so short and vertical that I don't see how you could use it to lever a root out of the ground. That means you are left with only your lifting force to get at a root. I can stick my horizontal lower jaw under a root then apply quite a bit of leverage using both lift and curl (=breakout which is always higher than lift capacity) and by lifting the rear of the tractor off the ground then dropping down and driving forwards a bit then repeating. It's hard to describe clearly how that works but it ends up putting a lot more upwards force on the roots than just grabbing and lifting.
/ Grappling for answers on Grapples #45
No advantage to having a grapple as wide as your tire treads. A wider grapple just means you are dividing your lift capacity and breakout capacity over a wider area as well as lifting a heavier more expensive grapple.
Unless you have a bulldozer you will most likely take smaller bites of brush then back out to deposit the brush in a pile. Only big bulldozers can just lower their rake blade and plow through territory. The rest of us do it piece by piece so there is no benefit to having a grapple as wide as your bucket.
/ Grappling for answers on Grapples #46
Good advice. Thanks.
/ Grappling for answers on Grapples #47
That's what I keep thinking, those clam grapples look like they'd be fun if they were mounted on a dozer. Maybe in sandy soil they'd work, but not around my place.
/ Grappling for answers on Grapples #48
Island, do you think the Markham would be as capable as the Millonzi in root raking or are the Markham tins flat configuration a disadvantage for this purpose?
I guess if I had a Markham I would do more picking up and carrying than pushing and raking with a WR Long, but I need to remove stumps and roots.
I had my land logged and now clearing the steep slopes to open the mountain view. I have logs and treetops scattered about. I have been pushing into piles with the loader and burning, but this is a slow process and I can only push down or up due to the steepness.
Thought I'd post some pictures (or at least I hope I will) of the Markham Light weight grapple. I hope this helps some of you to get a picture fix.
This is of the single tine unit. The single tine is about 30" wide as I remember from my conversation with Mrs. Markham. They will also make this with two narrower top tines of about 15 or 16" in width. They will also add extra spacers, as you can see in one of the pictures. The spacers cut the gap between the tines from 9" to 4.5". While I ordered the 60" unit they also make a 48" unit. Their prices were great.
I check multiple dealers for the WR Long unit and each had a different price for the 56" unit which has two top tines. All the costs I received were greater than Markham's.
/ Grappling for answers on Grapples #50
Make sure they dont use Skid Steer style Quick Disconnect, but Agricultural. Unless your tractor has the SS style QD's.
Wedge
/ Grappling for answers on Grapples #51
Big being a key word there. We use a toolbar/ripper (like on a box blade) and or disc set (add considerable weight) to cut roots before final rake, grade and seed.
/ Grappling for answers on Grapples #52
With a clamshell grapple the bottom tines are vertical or close to it and there is no horizontal base for logs to rest on so they can be held in place by gravity. Instead all gripping is "active" and depends on the shape and size of the load.
I'm going to disagree with this statement. I've only used my grapple, so I'm no expert and I can't say one way or another which is better. I can say that with a Rake Grapple, which is what I believe is also being called a "clamshell grapple" that the ability of the grapple to tilt back allows the weight of the load to rest on the grapple. You do not have to carry the log, or whatever you are carrying, in the virticle posting. Just tile the grapple back like you would a load of dirt in your bucket. All the weight is then on the rake grapple, and the grapple itself is just holding it in place.
On mine, I chose the Rake style because I didn't want to have to slide the grapple under what I was picking up. I wanted the ability to just open the grapple and pick up what what there without any pushing or sliding. It doesn't actually work that way because I do a small amout of pushing to add more branches to the load that I'm picking up. If I want to pick up one or just a few things, I can do it that way, but in a big clean up, I'm out to get as much as possible.
On my grapple, I have two arms that lower on either side. They are on the same hydraulic line and when the first one hits something, it stops moving and the second one keeps going. When they both come into contact with the load, they tighten up. This way, I can carry verry uneven loads that do not come loose.
Here are a few pictures of my setup.
Eddie
/ Grappling for answers on Grapples #53
The rest of us do it piece by piece so there is no benefit to having a grapple as wide as your bucket.[/QUOTE]
I disagree....there are several advantages to grapples wider than your tires, it just depends on what use you are putting it to.
I am removing debris from a fenceline, if my grapple wasnt wider than my tires, I would have to approach the line, grab a small 8-9' section and back away....
since my grapple is wider than my tires, I can run it along the fenceline till I have alot piled up, then close and back away. If my tires were inside my bucket width, I would have make literally hundreds of addittional passes.
/ Grappling for answers on Grapples #54
I see what you are talking about but that is a very specific indication where an offset grapple or one wider than your tires is indeed beneficial. An offset flail mower could also do that job.
For more typical grappling, especially brush or root clearing however a wide grapple would often just either get in the way or more importantly limits your ability to focus all the lift or digging in a small area. There is a reason that backhoes don't have six foot buckets and the same principle applies to grapples. A narrow grapple not only allows you to focus power in a smaller area but allows you to get between bushes or small trees to selectively grapple things. Brush sticks together so a narrow grapple can basically grab as big a pile of brush as you'd ever want (way more than you can see around) and logs or trees really don't care what size grapple you are lifting them with as you can stablize the load regardless of grapple size. If I am "root grappling" as in putting the tines under the dirt and driving forwards, I will lose traction or stall with a wider grapple well before I would with a narrow grapple too.
The bottom line is that for most grapple uses a narrow grapple works just as well or better and is more flexible. It also weighs less and costs less. There are certainly some people who will benefit from a wider grapple, your example is one, but I've yet to hear someone on TBN who bought a 48 inch grapple and then complained that they wished they'd gotten the 72 inch model.
/ Grappling for answers on Grapples #55
I have never used a truly flat bottomed grapple but most open bottom grapples are made that way (just like the Markham). My Millonzi has a slight curve to the bottom and I find it useful to get leverage on roots etc. I suspect that any difference in function is pretty small though and I wouldn't hesitate to get a Markham 48 to replace mine if it walked off some day.
I don't know why builders choose the flat bottom other than that they can just start off with flat stock rather than CAD cutting a curved bottom. Maybe that is cost savings enough to justify the flat bottom. For some uses like picking up construction debris the flat bottom is probably preferred. I wonder if Markham has the CAD equipment to do a "rocker" bottom grapple though. They do build them one at a time so it is essentially a semi custom shop anyway.
Wedge, Thanks for asking questions to help me ensure I cover the bases. The loader I have has the Univeral Skid Steer Quick Attach. I do need to ensure when I pick a valve that the line connections are the same and quick disconnects. I want to have the quick disconnects at the grapple as well a near the loader attachment so I can quickly disconnect from the loader or the grapple. I am not familar with hydraulic fittings. The Markham grapple comes with flat face Parker couplings and Hoses.
/ Grappling for answers on Grapples #57
Not sure what you mean by wanting to disconnect at both the grapple and the loader attachment. Usually the grapple has a set of hoses connected via SAE or JIC fittings (not quick connects) at the grapple cylinder and then about 5 feet or so of hose that terminates with quick connects at the FEL torque tube. The FEL would typically have lines that run to the torque tube with the matching quick connects to fit the grapple.
For some reason Markham continues to provide the flat faced skid steer style quick connects instead of the more commonly used Pioneer style quick connects on tractors. Both types work but I would personally switch the flat face for Pioneer "CUT" style quick connects which are the same as what you would use on rear remotes.
/ Grappling for answers on Grapples #58
I'm going to disagree with this statement. I've only used my grapple, so I'm no expert and I can't say one way or another which is better. I can say that with a Rake Grapple, which is what I believe is also being called a "clamshell grapple" that the ability of the grapple to tilt back allows the weight of the load to rest on the grapple. You do not have to carry the log, or whatever you are carrying, in the virticle posting. Just tile the grapple back like you would a load of dirt in your bucket. All the weight is then on the rake grapple, and the grapple itself is just holding it in place.......Eddie
Yep, I see what you are talking about on your first photo. Here are the equivalent grapple positions achieveable with a open bottom grapple. There does seem to be a lot more room for a load that is held in place by gravity alone with the open bottom style but as your photo clearly shows you can also do that with the clamshell.
/ Grappling for answers on Grapples #59
I have a remote on my tractor that I'm going to use. It has agricultural (pioneer) style connectors. I already have two hoses coming off this remote. The remote is part of the 3pt hitch and is under the seat. It has "banjo" fittings at the tractor, then QD's on the end. I plan on having some "extension" hoses made to run up to the hoses already supplied with the grapple. All will be with agricultural/pioneer style QD's. My grapple came with Skid steer QD's which will have to be switched out with ag QD's.
I'm hoping my hydraulic shop will give me credit for the SS QD's. Seems like they are about twice the cost or Ag. QD's.
When I remove the grapple, I can leave the extension hoses with the grapple and then will only have two short hoses at the tractor.
Wedge
Island,
What I am wanting to ensure is when I remove the loader from the tractor I can disconnect the lines running to the front torque tube as easliy as I can the ones that feed the loader up down and curl. These QD's are near the loader mount.
I also want to be able to via QD's remove the grapple and reinstall bucket at the troque tube.
I am not familar with hydraulic connections so I will have to work through ensuring the grapple connections and connectoins from the loader mate.
2008 Lexus IS250 Sedan (A61569)
2008 Lexus IS250...
2025 80in Hydraulic Dual Cylinder Grapple Bucket Skid Steer Attachment (A61567)
2025 80in...
Mini concrete mixer (A61567)
Mini concrete...
TRENCHER ATTACHMENT (A61567)
TRENCHER...
2019 Chevrolet Tahoe SUV (A60352)
2019 Chevrolet...
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52709)
2015 GENIE...
