Snow Advice - Pushing Snow
/ Advice - Pushing Snow #1
psdx
Gold Member
London, OH
Kubota B3030
I pushed snow last year with a B3030 using a Woods rear blade and a front loader if I needed to move any piles. That's not much of a consideration here in central Ohio however. I've pushed snow with a rear blade for 20+ years and somehow I don't enjoy it that much anymore - just hate looking backards that much...
I have 500 feet of driveway so I priced out the Kubota front blade in the spring and after the shock wore off and my heart re-started I put the quote in a pile of papers to be forgotten. Now that snow season is about here, I'm trying to decide on spending $2300 for the Kubota blade vs. $300 on a used blade for a 4wd King Quad ATV. The driveway is currently gravel so I only plow when there's drifts of 6" or more. I'm sure the tractor would be faster, but does anyone have any experience using both a tractor with front blade and an ATV? Trying to find out if using a 4wd ATV on a 500 foot driveway is just a pointless exercise, hence a waste of money, or if others have been satisfied with this set up. Thanks in advance.
/ Advice - Pushing Snow #2
Since you already have a loader, you have the necesarry valve. I bought the Kubota manual angle blade and mount for much less. In fact, as I recall it was about $1200 less for the manual angle. Like you I have a long drive so I only need to get off a few time to change the angle which I had done for a few years with a big Cub garden tractor and snow blade. Kubota's sales material doesn't really mention this in their ads but once an honest salesman mentioned this to me I couldn't justify spending the extra money to save few trips off the tractor. In fact it's usually about the time I need to stretch anyway. I've used my blade to push snow, dirt, gravel, sticks, and even a huge pile of leaves. I too used to plow with a back blade and it sucks.
/ Advice - Pushing Snow #3
This is my BX1500 with the Hyd. angle blade.
http://i283.photobucket.com/albums/kk286/lb59/100_2316.jpg
/ Advice - Pushing Snow #4
I use a front blade and a front end loader both.
http://i283.photobucket.com/albums/kk286/lb59/100_2321.jpg
/ Advice - Pushing Snow #5
I push snow with My RTV with a Curtiss snow plow. Works very well and having a cab with a heater is just icing on the cake as the tractor does not have a cab. I keep our 660' drive and the elderly neighbors plowed out. The only complaint is the skid shoes don't sit high enough and need to be bigger for a gravel drive. I made my own skid shoes that work better. I don't have any experience with with a front blade on a compact tractor so I cannot offer a comparison on that.
/ Advice - Pushing Snow #6
I have the Kubota 6' foot power angle blade and Kubota quick hitch on my B3030. It works very well. I don't recall the price being $2300 but I purchased mine over 2 years ago with the tractor so it may have gone up in price since then. It works very well, highly recommended. Also much cheaper and faster than the Kubota front blower for medium to small snow falls.
/ Advice - Pushing Snow #7
IF the blade is quicker and cheaper then why are people waisting time and money on blowers?
/ Advice - Pushing Snow #8
With a front or rear blade you need a place to push the snow. I have an area across from my driveway that is open town land that I can pile snow on. The snow in Connecticut also tends to melt somewhat between storms so snowbanks next to my driveway are not a problem. The snow storms here generally dump less than a foot at a time to. For the most common 6 - 8" storm the blade is very fast. For heavier amounts some of the snow tends to come over the top of the blade and more goes out the sides so you have to make more than one pass.
For areas that get large amounts of snow with little melting the benefit of a blower is it will blow the snow away from the area being cleared. You only make one pass and it does not create a bank next to the area being cleared like a blade will. If I was in a heavy snow belt area I would own a blower and not the blade.
/ Advice - Pushing Snow #9
So, for the price difference between manual and hydraulic angle, how hard would it be to add the hydraulic angle aftermarket? If you have the loader valve, there would be an open circuit so I'd guess you'd only need the right size cylinder and hoses. I haven't seen their quick hitch so I'm not sure how practical it would be to mount the extra cylinder to the manual angle version.
/ Advice - Pushing Snow #10
I just adapted my trucks poly angle blade to my new Grand L4240. The tractor has the skid steer adapter on it making the change over from blade to bucket fast. An angle blade on the front of a tractor is very fast and efficient for plowing snow and that will be the way I'll be plowing most of our snow this winter unless it gets to deep, then I'll use the rear blower.
If you want to see how I adapted the plow click the link.
http://www.tractorbynet.com/forums/customization/131136-snow-plow-adapted-fel.html
/ Advice - Pushing Snow #11
I've plowed snow for years with a 42" or so blade on the CC1440. When the snow was real deep or especially wet I'd use the FEL on our 200 ft gravel driveway with the B1750.
The reason I'm responding is that this will be the first year I'll be putting on the back blade but I intend to pull the snow with the blade angled to one side. I was wondering your experience trying it that way...I hate to backwards too.
Had the back blade for years but used it for excavating projects...decided to use when I saw the neighbor efficiently pull snow out of his driveway with his yorkrake. Thanks
/ Advice - Pushing Snow #12
Is it possible to buy a cheap used truck blade and build a frame to mount it to your tractor either like 4shorts did or making it frame mounted. You can pick up plow blades on craigslist for very little money. Even if you couldnt do it yourself maybe paying someone else to build it for you. Could cost maybe all of $500 instead of over $2000.
/ Advice - Pushing Snow #13
I have the B3030 Kubota quick hitch (B 2791) that came off a friends tractor, never used just mounted. It has the up/down cylinder and hoses. Make me an offer, you will be half way home. Will have to figure out how to ship.
Rick
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
BOX BLADE (A58214)
BOX BLADE (A58214)
832786 (A61166)
832786 (A61166)
2015 FREIGHTLINER CASCADIA ROAD TRACTOR (A62130)
2015 FREIGHTLINER...
New/Unused Quick Attach Double Hay Spear (A61166)
New/Unused Quick...
New/Unused IRMC Massage Chair (A61166)
New/Unused IRMC...
