Interesting Welding Statement.
/ Interesting Welding Statement. #1
AlanB
Elite Member
Clarksville, TN, USA
NH 1925
I thought some here may find this interesting.
I am getting a large tank made for here at my day job.
The body is 8' tall and 5' diameter, made from 3/16 hotrolled.
So I was at the fabricators yesterday to work out some questions / problems and got to hang around to watch the body get formed.
3 guys, working real well together rolling a BIG (at least in my scale of things) sheet through a big roller.
So they get the primary rolling done, and get too the point where they are going to tack the thing together, and the guy goes out and gets an old lincoln Buzz box. There is a new Millermatic 350 digital Mig sitting beside the roller, plugged in. My point I am trying to stress is he went out of his way, to go get this thing and do the welding with 7018 stick. (DC+ by the way, Murex (by Lincoln) rods)
I could not stand it, so I asked the lead guy why, my teaching has always been that mig yeilds about 70,000 lb strength (same as 7018) and his answer was that the 7018 would be a more ductile weld and would respond better to running through the roller and getting the "roll" in the area as opposed to the straight edges you get on the leads of a sheet.
Anyway, in the 3+ days I have been welding I had never heard that one, and it was coming from someone that has been doing it at least 5 days in a row ;) so I will assume there is something too it.
Just thought I would share, I have to ask the Lincoln guys now what the science is behind it, or is it just a shop belief.
/ Interesting Welding Statement. #2
True! MIG welds are very hard and brittle. Any time I tack pieces together for slip rolling with a mig, they break if there is any deflection. Where as 7018, or TIG welding them provide a more maluable weld. I also learnt this from doing auto body, tack it with MIG then try to hammer form it, it cracks every time. Also if the vessle is a pressure vessel, I have never seen anyone use MIG to build them up here and up here all we do is pressure (mostly) because MIGs have a cold start and dont get full penetration off the start which usually leads to pinholes. Stick and TIG you can use your arc to preheat before applying filler metal.
/ Interesting Welding Statement. #4
..........and up here all we do is pressure (mostly) because MIGs have a cold start and dont get full penetration off the start which usually leads to pinholes. Stick and TIG you can use your arc to preheat before applying filler metal.
Isn't full penetration dependant on the weld joint preparation? Full double bevel with (or without) backing?
Interesting thread and info.
I can appreciate info from those that have been there with stick in hand.
/ Interesting Welding Statement. #5
Absolutely! In this case the Fitters are fitting the piece together 7018 will bend and distort if needed without breaking. Once the entire piece is put together with ends and those seams will be fitted with 7018 also I would assume. Once it is all together it could be welded with a Flux Core Mig on the inside then grind out the seams to expose the inside weld to the outside. There by welding it with a Flux Core Mig or by Stick from the outside making it a a full 100% weld.
/ Interesting Welding Statement. #6
I didn't make it to pipe welding level but my instructor always said something about MIG wasn't approved for pipe.......dunno.....
I broke out the ole' stick the other night and realized just how much I missed it......
/ Interesting Welding Statement. #7
it......
Not entirely true. There are processes that allow MIG for pipe I know because I have been welding it for over 30 years. Some of the largest pipe lines have been welded with automated MIG process. These pipe lines supply oil from the high Arctic to the US through Canada. Also these procedures were developed by ASME - American Society of Mechanical Engineers, an American Government Agency.
Only thing about MIG is the cold start and for Tacking/fitting it is not desirable.
/ Interesting Welding Statement. #8
i recall him saying something about the automatic migs too....
i guess it just suprised me because i was always impressed with mig not having and slag to build up.....just all metal.......
/ Interesting Welding Statement. #9
Sorry I shouldnt have used the term full penetration it is an issue of lack of fusion. With MIG when you first pull the trigger your depositing material right away, however the substrate isnt fully heated yet and doesnt allow full fusion. Do a sample weld and cut out your start and it will most likely fail. With Stick you strike your arc, pull away slightly and it preheats without deposition allowing full fusion right off the start.
But as far as brittle, MIG is the most brittle.
And I have heard of people getting their MIG root ticket, however all procedures by the companies up here call for 6010 root 7018 fill and cap. Im not B pressure myself, nor do I want to. Ive been around it long enough to know none of the companies up here call for it or allow for MIG in their procedures, at least not yet.
/ Interesting Welding Statement. #10
I was old school as well until I took a cert test with .045 hardwire on 3/8" plate DOWNHAND!!! I couldn't believe you could spray arc downhand and pass both a root and face bend!!! I guess you are never too old to learn...
/ Interesting Welding Statement. #11
I dont know if it is aproved but I do know it is used. Many years ago I went for a job interview. The company was laying 12 inch pipeline on the ocean floor. they would take and 80foot section of pipe clamp it into a machine the machine had three mig welders 120 degrees apart. they would run around the pipe and then it was inspected and if it passed it was sent down into the water and another piece was put in place.
/ Interesting Welding Statement. #12
Different results for different requirements. Most codes allow for various degrees of results, along with any applicable site specific procedures.
My limited knowledge of hands-on stems from 25 years of U.S. nuclear power applications under AWS, and various sections of ASME. The API 1104 and B31.1 power piping codes were never allowed (less stringent codes). I was a welding engineer for years in the nuclear world, all beginning with Quality Control responsibilities (AWS CWI). However, neither job consisted of hands-on welding. Always good to hear from the welders. I can quote metallurgy and processes all day long but can barely stick a rod to bare metal.
What I enjoy most for fun is weld symbols on a drawing.... I see a lot of incorrect symbols that folks will just weld away reading an incorrect symbol... :D
Good thread....
/ Interesting Welding Statement. #13
Well said!:D:D:D
Could the size of the machine be a factor also?:confused:
/ Interesting Welding Statement. #14
.............. Also these procedures were developed by ASME - American Society of Mechanical Engineers, an American Government Agency..........
The ASME is a private organization. It is not an agency of the US government. However, governments, US and otherwise, and governmental agencies sometimes reference ASME codes and standards in their laws and regulations.
/ Interesting Welding Statement. #15
I was waiting for someone to clue into this statement.
ASME is as well connected to the Government as the Food and Drug Administration.
/ Interesting Welding Statement. #16
Its a lot of personal preference!!
"The body is 8' tall and 5' diameter, made from 3/16 hotrolled."
If a weld coupon of that material ..welded with a MIG welder can stand a bend back test and not snap ( which it had better not!!) then why wouldnt it be able to be "rolled and formed" to a much lessor degree?
/ Interesting Welding Statement. #17
when you hammerweld, the weld is actually is being forced to move.....since mig is a hard weld, it cracks...
when you bend something, the metal around the weld is what does most of the moving.....so the pressure is spread out...
well, at least in my thinking:rolleyes::D
/ Interesting Welding Statement. #18
Sully is talking about a bend test. No matter the type of weld if it is bent against the face and or the root without breaking or splitting in the slightest degree the weld passes. Whether it is a MIG weld or not.
Lets get this straight, many things that are used on a daily basis are MIG welded. For instance a Propane Cylinder ( which is a pressure vessel ), your car, and lets not forget the Airplane. Anything automated these days is MIG processed and in production as well.
There are ways around the cold start of a short circuit method of MIG operation.
/ Interesting Welding Statement. #19
Airplane??? What is mig welded on an airplane and please define which airplane you are refering to.
/ Interesting Welding Statement. #20
MANY items are Mig and TIG welded on airframes...far too many to attempt to list for sure.
Only airplanes Im semi familiar with are combat aircraft. F16;F14;F15...etc
2021 VERMEER LP573XDT VACUUM TRAILER (A63276)
2021 VERMEER...
2018 CATERPILLAR 326FL EXCAVATOR (A65053)
2018 CATERPILLAR...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A64553)
Pallet of...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
2006 Western Star 4900 Concrete Mixer U98358 (A62613)
2006 Western Star...
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
