winterizing the B7100
   / winterizing the B7100 #1
grossgary
midatlantic
1994 Kubota B7100 HST 4WD
I did read through the owners manual I have and found nothing.
I'm going to remove the MMM and attach a snow plow and tire chains to my B7100. This being my first tractor is there anything I need to know about using this thing in the snow/cold? -5 degrees is about as cold as it gets here.
i'm guessing this has already been asked but it seems like mounting a blade to the 3 point hitch is a good option since you already have hydraulics there?
   / winterizing the B7100 #2
What type of tire are you running? Where did you get the tire chains?
   / winterizing the B7100 #3
Well, maybe check the antifreeze for strength.:D
I just changed mine yesterday. Blew all the summer accumulated debris out of the radiator, pressure washed it and put a new duct tape cover over the ignition key area as it does sit outside at times:). There was also a new headlight installed. One that provides much more light than the original lights do. This time there was even a guard for the light installed.:eek:
I'll put the chains on later. Usually this means it's delayed till it's just plain miserable out before they get put on.:D
the tires look like standard turf tires. the chains just came with the tractor when i bought it from the guy so i know nothing about them.
i took the radiator off this summer to clean it out and then drained the coolant again to replace the dynamo. so it's been drained and filled with 100% antifreeze both times.
   / winterizing the B7100 #5
If you pressure wash, be careful with high pressure around fins. I've seen a lot of damage done by getting too close. If anyone is looking for tire chains try Tire Chains by TireChains.com. I've dealt with them with good success.
   / winterizing the B7100 #6
Just re-read the post. Comment on 100% antifreeze. The following was taken from an antifreezee website. "Many engine failures are the result of improper antifreeze usage. To protect equipment from coolant-related damage, it is critical to know the different antifreeze types, required mix ratios and problems that could result from improper use. A 100 percent antifreeze solution will turn to a solid at 9°F (-13½°C). For best all-around protection, use a 50:50 mixture of antifreeze and water. Concentrated antifreeze needs water for chemical balance and optimum performance."
okay, thanks guys. i thought i had read that somewhere else on the board, but couldn't recall where. i guess it's not 100% since it had old mix in it and i did add a quart of water or so, but i'll drain it and get it to %50 as i'm sure it's well over that.
i'm going to leave a bottle of antifreeze out this winter, i'm curious to see it turn solid or gel, never seen that before.
   / winterizing the B7100 #9
A mix of 65% antifreeze/35% water gives maximum freeze protection,about -68F.After that,you're going backwards.Best ratio for most people is 50/50-using distilled water is a plus.Under a buck a gallon-no lime or other minerals to drop out of solution to contaminate your radiator/cooling system.
   / winterizing the B7100 #10
just remember A FEW THINGS
1. NO BIODIESEL, It gels around 40 u can mix it 50:50 with desiel nd be ok
2. PREHEAT about 15-30 seconds before cranking
3.let it idle to warm up
other than than have fun it the banks i do
2012 DRAGON 130BBL VAC TRAILER (A58214)
2012 DRAGON 130BBL...
2015 Ford Escape AWD SUV (A59231)
2015 Ford Escape...
2020 DRAGON ESP...
CATERPILLAR 108" WHEEL LOADER RAKE (A52707)
CATERPILLAR 108"...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2016 KOMATSU D65EX-18 CRAWLER DOZER (A60429)
2016 KOMATSU...
