Battery Failure
/ Battery Failure #1
RoofDawg
Indiana
JD 2305 450 IH
Hello everyone, awesome site, just found it today and I had to register.
I have a JD 2305 since May of '06 and yesterday the battery just upped and died. It will take a jump and run forever until you shut it off then nothing. it has 60 hours on it. I guess the question is has any of ya'll who own this model have had the same issue? I'm guessing there is a dead cell or 2. What would be a good replacement battery? I'm not real happy with the OE
/ Battery Failure #2
With engine off, check battery with voltmeter and it should read 12.5 volts or higher. Turn lights on and it should still read about 12 volts. If it doesn't, it's very likely the battery. I'd go to Tractor Supply or Advance Auto Parts for a new battery.
/ Battery Failure #3
I caused a battery failure in my 4100 because I thought it was a no service required battery, and it wasn't.:(
Check the water level.
/ Battery Failure #4
The OEM battery may or may not be a "good" battery. Even the good ones can go bad at times. Ten days ago, I drove our old 2001 Ford Windstar that morning and everything was normal. A couple of hours later, my wife was going somewhere and it wouldn't start, couldn't even get a solenoid click. I checked and it showed 6.1 volts. I put the charger on it until the charger showed 88% charge and 12.7 volts, turned off the charger, hit the starter for no more than a second or two, and nothing. Checked voltage at the battery and it was back to 8 volts. For reasons unknown it had suddenly developed an internal short.
The good news . . . it was a Motorcraft battery; free replacement warranty the first 36 months, prorated month 37 to 100. It lacked one month and 5 days being 36 months old, so the new one, parts and labor, was free at the Ford dealer.:)
And welcome to Tractorbynet, RoofDawg.
/ Battery Failure
Thanks guys, I'll put a meter on it when I get home. I checked the water Gary it appeared fine.
/ Battery Failure #6
If it can be used a hydrometer will give you more accurate results and be able to pinpoint a bad cell.:D
/ Battery Failure #7
Yes, but it's sure been a lot of years since I owned, or even used, a hydrometer.:D
/ Battery Failure #8
Since your tractor is a 2006 model, the battery may still be under warranty. I'd check with my JD dealer to be sure. Even an OEM battery should have a 3-yr warranty. You may not get full credit, but partial credit could help pay for a new battery. Of course, an OEM battery may have an inflated price, so a good aftermarket battery like an AutoZone Duralast Gold battery might be good. That battery has a full 5-yr warranty with some trade-in value out to 8 years.
/ Battery Failure #9
Well, I had a Hydrometer till a year ago when it got dropped. :eek: Never bothered to replace it as batteries are tending to be maintenance free and one cannot access the fluid levels.:D
/ Battery Failure #10
Jim, I'm sure there are some different Duralast batteries, but I recently priced batteries (for a neighbor while he was at work) at Walmart and the AutoZone across the street from the Walmart and for batteries with the same 3 year free replacement and prorated after that warranty, the AutoZone battery was about $20 higher. About 10 years ago, I needed a battery for a Cub Cadet riding mower, stopped at the Walmart in Corsicana to see about their price, then went to AutoZone. AutoZone was one penny higher than Walmart, but I bought at AutoZone rather than go back to Walmart.:D
/ Battery Failure #11
Bird, I used to buy the cheapest battery possible and still would for some things, but for my diesels, the best battery is more important than price to me. I bought Duralast Gold batteries for my Dodge-Cummins when an Interstate battery exploded. One of the Duralast Gold batteries (Autozone's premium) failed at about 5-1/2 years and I still got a discount of about $15 on a new battery. One of my Duralast Gold batteries is still going strong at over 8 years. That's the kind of service I like in a diesel pickup.
My wife stopped by the Autozone in Decatur to buy a battery. They took the old battery out of her van and replaced it with a new one right there on the spot in front of the Autozone store. I know Walmart has good service, but I don't think it is quite that fast or good. That Autozone store gets a lot of my business just because they know the meaning of service and treat their customers right. I'm probably a little biased because of that.:)
Of course, I have an Optima in my tractor because I cannot afford to have any acid leakage. All battery worries with the tractor have stopped since I bought the Optima. However, you have to commit to paying about twice as much as a normal battery when you purchase an Optima.
/ Battery Failure #12
I've been getting about 8 plus years out of Ford/New Holland oem batteries.
In my 2120 which I pourchased in 1987 I'm on my 3rd battery. Yhis time I've been on a Diehard marine battery for about three years as I happened to have one that I snatched from my boat when the oem battery went dead. Of course many times one of my machines will sit for 3-4 months unattended and start right up when needed. I virtually never have had to charge my batteries.
Andy
/ Battery Failure #13
Jim, Walmart does advertise "free" installation of any battery you buy there, but how fast they'd be or how competent their employees are is something I don't know. And I'm sure AutoZone is like most businesses; it just depends on the employees. I did a lot of business with the AutoZone in Corsicana during the 8 years we lived in the west end of Navarro County and was happy with them. The nearest AutoZone to me now is another matter. I've been in there several times, and bought a few small things, but I have yet to find an employee in there who has any idea what he's doing.:D Maybe that's the reason you can drive by there almost any time and the parking lot is empty. It appears that they don't have enough business to pay the light bill.
So I can certainly understand why you'd stay with AutoZone and I would, too, in your area.
/ Battery Failure
Well, I put a volt meter on her after running her for about an hour (mowing) and she was only registering 'bout 6 volts and would not restart. Also, there is a pro-rated warranty. I'll take it to the dealer and see what they say. Thanks for all your input gentlemen.
/ Battery Failure #15
The only reason I even have a battery charger is that I bought it for the trolling motor battery in the boat (the engine would charge the starting battery, but not the trolling motor battery), but then I sold the boat.:eek:
RoofDawg, did you put a voltmeter on it while it was running to see if the alternator was putting out any current? It's probably a battery that's gone bad instead of the alternator, but that would be one thing to check.
/ Battery Failure
I have a better meter coming from my boss and I'm going to check it all. I also have a problem with the emergency flasher fuse, that keeps blowing. I think I may have pinch a wire when I took off the ROPS. I wish the ROPS folded it would make things alot easier. I let you know Bird what I find out.
Great Dane Van Trailer 1989 (A63118)
Great Dane Van...
1985 GREAT DANE 45' SLIDE AXLE FLATBED TRAILER (A59910)
1985 GREAT DANE...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
2025 X-Pro Victor Mini Dirt Bike (A61574)
2025 X-Pro Victor...
2016 CATERPILLAR 259D SKID STEER (A64279)
2016 CATERPILLAR...
2015 JAYCO JAYFEATHER TRAVEL TRAILER (A63569)
2015 JAYCO...
