Biggest MMM on a cab/CUT
/ Biggest MMM on a cab/CUT #3
there are logistical reasons why mid mount mowers are commonly no larger than 72". mostly it has to do with moving that much grass to a side discharge chute. after about 60", more horsepower becomes less and less useful towards fixing the problem of moving such a large volume of grass from left to right. a rear discharge gets by this problem by just allowing the cut grass to fall to the ground or exit each blade without passing over the other blades.
with my 60", i already get fairly deep windrows if i let my grass go too long between cuttings. a 72" deck would be even worse and the cut would suffer as lift is reduced by the clogging action of the side discharge challenge.
amp
/ Biggest MMM on a cab/CUT #4
The Case Farmall compacts have an 84in rear discharge model MW84R that fits the Farmall 40 & Farmall 45. New Holland also model 914A fits a few different tractor models. They are the same just different color.
/ Biggest MMM on a cab/CUT #11
They use the three point lever for mowing height.
/ Biggest MMM on a cab/CUT #12
my TC33 has a 72" side discharge MMM.
i THINK you can get a 84" MMM rear discharge on the next frame size up TC34-45
2021 BOBCAT E32I EXCAVATOR (A62129)
2021 BOBCAT E32I...
2010 New Holland Boomer 3050 Tractor Loader (A63116)
2010 New Holland...
UNUSED KJ 42'X30' METAL STORAGE SHED (A62131)
UNUSED KJ 42'X30'...
UNUSED KJ K1522 PORTABLE RESTROOM (A62131)
UNUSED KJ K1522...
2015 CATERPILLAR 259D SKID STEER (A62129)
2015 CATERPILLAR...
INOP/NON-RUNNING 2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL4DL295841 (A61165)
INOP/NON-RUNNING...
