Biggest MMM on a cab/CUT
/ Biggest MMM on a cab/CUT #3
there are logistical reasons why mid mount mowers are commonly no larger than 72". mostly it has to do with moving that much grass to a side discharge chute. after about 60", more horsepower becomes less and less useful towards fixing the problem of moving such a large volume of grass from left to right. a rear discharge gets by this problem by just allowing the cut grass to fall to the ground or exit each blade without passing over the other blades.
with my 60", i already get fairly deep windrows if i let my grass go too long between cuttings. a 72" deck would be even worse and the cut would suffer as lift is reduced by the clogging action of the side discharge challenge.
amp
/ Biggest MMM on a cab/CUT #4
The Case Farmall compacts have an 84in rear discharge model MW84R that fits the Farmall 40 & Farmall 45. New Holland also model 914A fits a few different tractor models. They are the same just different color.
/ Biggest MMM on a cab/CUT #11
They use the three point lever for mowing height.
/ Biggest MMM on a cab/CUT #12
my TC33 has a 72" side discharge MMM.
i THINK you can get a 84" MMM rear discharge on the next frame size up TC34-45
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
Zero Turn Mower (A59231)
Zero Turn Mower...
300 GALLON FUEL TANK (A62131)
300 GALLON FUEL...
2015 FREIGHTLINER M2 106 T/A 6X4 FLATBED WITH MOFFET (A59909)
2015 FREIGHTLINER...
40' CONTAINER (A62131)
UNUSED IRANCH WROUGHT IRON SITE FENCE (A62131)
UNUSED IRANCH...
