310-510
I finally managed to test the pressure and found my BX24 had 1740 PSI at WOT and warm fluid. I added 4mm shim and the pressure went to 1900 PSI at WOT. WOW, what a difference. I have a tractor that can lift a full bucket, a backhoe that can really scratch the dirt, and I can get by running at 2500 - 2600 RPM for most work. The most noticeable lift is with the front bucket forks. The BX will now lift a 440 pound 5' flail mower on a pallet when before the modification, it would not even curl the weight. Just to be clear, it won't lift the flail mower very high and it won't lift the flail mower very fast, but all I needed to do was be able to lift the flail mower to move it in and out of my trailer.
OK, now that I think adding pressure is the holy grail of making my BX great, what component will I be breaking or shortening the life of?
