300cx getting a little loose.
   / 300cx getting a little loose.
Oh Gee, now my fabulous technique for initiating a window replacement:mad: has a name.:rolleyes:
:D Did you get any new implements we can share... :D
   / 300cx getting a little loose. #12
Nuthin new, i did put the Front 3 PT on and then promptly took the A frame off until I really need to plow.;)
I still have not tried out my Sirius Sportster Radio in my cab yet. I had to get a mini-din cable so I could plug it in.
Is that front three point really in the way? I keep thinking about a snowblower, but.... It seems like a lot to put on and off. I already have one on the 445..so....
I use mine out in the field all the time, even in the winter, and just could not see putting things on and off all the time.....
   / 300cx getting a little loose. #14
Boy nmu98, from this and some of the other posts here I gather that you reeeally hate to take stuff on and off your tractor. You must either drive it around bare bones or it must look like a swiss army tractor.:)
I dont reaally hate to do it. I just use my tractor to take care of 20 acres of nursury. So, some implements would make it a pain to work around. The MMM would be imposible for me since it would have to be put on and taken off each time I mowed the lawn. The front three point mount might be the same.
I can put on either one of my buckets or my pallet forks in seconds. I can put on any rear implement I have in minutes thanks tot he imatch. It just seems to be a hinderence of use if its a pain to put on, or take off.
On our larger tractors, we fight a few implements on, and it is no fun.
My tractor was not purchased for home care, maybe thats why i don't like to take home care implements on and off. With 2 small kids, I have limited time, and I would rather be getting a job done, than removing something i really did not need to use.
   / 300cx getting a little loose. #16
Well, there may be some conflict for space between the mounted A-Frame and the hood guard lower strap/rail. So rather than deal with it, I took it off. Plus if i get out the horse mat and put the loader back on for rock work. i would have to remove it anyway. The rest of the hitch is still on the tractor and would take about 40 minutes to remove - plus taking off the MMM too. I bought the part that allows one to keep the MMM and the Front 3PT hitch on the tractor at the same time, and that was fun to install - used floor jack and some minor wiggle adjustments to get it on correctly.
   / 300cx getting a little loose. #17
You can run the Front 3PT hitch and the MM at the same time, with the special front draft arms kit
LVB24810 Mower/Hitch Draft arms kit
I believe the front 3PT hitch without the A-Frame can stay on the tractor without the A-Frame attached.
No kidding on the implement fighting!
   / 300cx getting a little loose. #18
I hate to take stuff off and on too. I was just ribbing you a little bit. Everything I buy for now on will be I-match compatible or easily modified to be compatible. I thought about buying a front snow blade but I seem to use the loader to much even in winter. I get supplies dropped off for my business once a week every week, so to swap the loader for the front blade and back just isn't gonna happen. Especially in the middle of winter. Maybe a loader mounted snow blade would work..
I have been thinking of building a loader mounted snow pusher like the bobcats use. I don't need it, but its a good excuse to keep my welding in practice....:D
2016 CATERPILLAR 259D SKID STEER (A52705)
2016 CATERPILLAR...
2019 Chevrolet Cruze Sedan (A55758)
2019 Chevrolet...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
2020 International MV607 Dump Truck (A55788)
2020 International...
UNUSED FUTURE FT-ZWB MINI BACKHOE DIGGER ARM (A54757)
UNUSED FUTURE...
