300cx getting a little loose.
   / 300cx getting a little loose.
Oh Gee, now my fabulous technique for initiating a window replacement:mad: has a name.:rolleyes:
:D Did you get any new implements we can share... :D
   / 300cx getting a little loose. #12
Nuthin new, i did put the Front 3 PT on and then promptly took the A frame off until I really need to plow.;)
I still have not tried out my Sirius Sportster Radio in my cab yet. I had to get a mini-din cable so I could plug it in.
Is that front three point really in the way? I keep thinking about a snowblower, but.... It seems like a lot to put on and off. I already have one on the 445..so....
I use mine out in the field all the time, even in the winter, and just could not see putting things on and off all the time.....
   / 300cx getting a little loose. #14
Boy nmu98, from this and some of the other posts here I gather that you reeeally hate to take stuff on and off your tractor. You must either drive it around bare bones or it must look like a swiss army tractor.:)
I dont reaally hate to do it. I just use my tractor to take care of 20 acres of nursury. So, some implements would make it a pain to work around. The MMM would be imposible for me since it would have to be put on and taken off each time I mowed the lawn. The front three point mount might be the same.
I can put on either one of my buckets or my pallet forks in seconds. I can put on any rear implement I have in minutes thanks tot he imatch. It just seems to be a hinderence of use if its a pain to put on, or take off.
On our larger tractors, we fight a few implements on, and it is no fun.
My tractor was not purchased for home care, maybe thats why i don't like to take home care implements on and off. With 2 small kids, I have limited time, and I would rather be getting a job done, than removing something i really did not need to use.
   / 300cx getting a little loose. #16
Well, there may be some conflict for space between the mounted A-Frame and the hood guard lower strap/rail. So rather than deal with it, I took it off. Plus if i get out the horse mat and put the loader back on for rock work. i would have to remove it anyway. The rest of the hitch is still on the tractor and would take about 40 minutes to remove - plus taking off the MMM too. I bought the part that allows one to keep the MMM and the Front 3PT hitch on the tractor at the same time, and that was fun to install - used floor jack and some minor wiggle adjustments to get it on correctly.
   / 300cx getting a little loose. #17
You can run the Front 3PT hitch and the MM at the same time, with the special front draft arms kit
LVB24810 Mower/Hitch Draft arms kit
I believe the front 3PT hitch without the A-Frame can stay on the tractor without the A-Frame attached.
No kidding on the implement fighting!
   / 300cx getting a little loose. #18
I hate to take stuff off and on too. I was just ribbing you a little bit. Everything I buy for now on will be I-match compatible or easily modified to be compatible. I thought about buying a front snow blade but I seem to use the loader to much even in winter. I get supplies dropped off for my business once a week every week, so to swap the loader for the front blade and back just isn't gonna happen. Especially in the middle of winter. Maybe a loader mounted snow blade would work..
I have been thinking of building a loader mounted snow pusher like the bobcats use. I don't need it, but its a good excuse to keep my welding in practice....:D
2016 GMC SIERRA 3500 SERVICE TRUCK (A51406)
2016 GMC SIERRA...
UNUSED FUTURE SG45 - 45" HYD STUMP GRINDER (A54757)
UNUSED FUTURE SG45...
CRAFCO INC. MAGUM PORTABLE SPRAY INJECTION PATCHER (A54756)
CRAFCO INC. MAGUM...
2018 Ford Explorer SUV (A55758)
2018 Ford Explorer...
UNUSED 4 GAUGE 25' JUMPER CABLES (A54756)
UNUSED 4 GAUGE 25'...
2022 BOBCAT T770 SKID STEER (A52705)
2022 BOBCAT T770...
