Cub Cadet 2145 - will not start
/ Cub Cadet 2145 - will not start #1
rflowers
Hello, all. I am new to this forum. As a matter of fact, this is my first post and it is a 2-part question.
I have a Cub Cadet 2145 that my father-in-law gave me. At the time, he knew it was having trouble starting, and he told me so. This is a starter problem - it doesn't crank, and you have to keep turning the switch. Eventually it will catch. Well, today there was no "eventually." By shorting over the solenoid, I made the starter turn, but of course it would not engage.
First question: I started looking for a new solenoid, and found a couple of parts places that called it a "magnetic switch." Both places wanted $400+ for this part. (One was the Cub Cadet site itself.) This seems excessive. Do people really pay this much for Cub Cadet parts? (That's the question.)
Second question: There is a warning light telling me to disengage the mower blades. I am guessing there is a safety shut-out to prevent starting when the deck is engaged. However, the blades are disengaged. Could my problem be a faulty reading from somewhere in the circuit, and not in the solenoid?
Thanks much.
Just to let you know, I now think it's the battery. I was able to start the tractor with a 'jumper box.'
/ Cub Cadet 2145 - will not start #3
I have a 2145 with the same starter issue. It has a new battery that not the problem. I think it may be the start switch,
/ Cub Cadet 2145 - will not start #4
Welcome. It is much more likely to be the connector on the red wire behind the switch, a fuse, connector behind the PTO switch or the starter solenoid. Best to work this kind of thing through.
2007 DRAGON  130BBL VACUUM TRAILER (A65643)
2007 DRAGON...
2012 International (A59230)
2012 International...
(1) 30 Yard Roll Off Dumpster (A65579)
(1) 30 Yard Roll...
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
2013 DRAGON  130BBL VACUUM TRAILER (A65643)
2013 DRAGON...
2016 Volkswagen Jetta Sedan (A61569)
2016 Volkswagen...
